MaxTrac 6" lift with TSS Wheels
Discussion in 'Suspension' started by KLLVMDCL, Jan 20, 2019.
  1. Jan 20, 2019 at 9:46 PM
    KLLVMDCL
    KLLVMDCL [OP] New Member
    Brandon
    Austin, Texas
    2017 Super White DC SR5
    I've done just about all the research i can on the 20x9 TSS wheels and best i can come up with is that they have +50 offset for the ones with about a 2in lip. Mine are the other version that have no lip so im assuming even more positive offset. My real question is, I want to put a 6" spindle/ coilover lift but not sure if i can use my stock wheels(maybe with spacers)?
    Lift: http://www.maxtracsuspension.com/toyota-tundra-2wd-3-5-inch-lift.html
  2. Jan 20, 2019 at 10:58 PM
    Donkeypunch
    Donkeypunch New Member
    To my undertanding, both TSS wheels, old with lip and convex with no lip, are +50mm offset.
    Cuzican and Cement_Trd like this.
  3. Jan 21, 2019 at 12:50 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    thanks, that powdercoat looks so clean on white btw!
    Donkeypunch[QUOTED] and OR18TRD like this.
  4. Jan 21, 2019 at 5:01 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    The maxtrac spindles kick the width out approx 1 inch. You need spacers to run the stock wheels.
    If I was 2wd, I would do that 6 inch lift in a heart beat.
  5. Jan 21, 2019 at 5:05 AM
    Those wheels look great.
    Donkeypunch likes this.
  6. Jan 21, 2019 at 5:11 AM
    Cement_Trd
    Cement_Trd New Member
    2018 Cement TRD offroad
    Cement color match (dechrome), Tyger Side steps, TRD rear sway bar, Black badging (dechrome), TRD dual exhaust
    +50 offset is correct
  7. Jan 21, 2019 at 6:11 PM
    KLLVMDCL
    Brandon
    Austin, Texas
    2" spacers would probly be too much considering the added 1" from the spindle. probly less work to just buy new wheels rather than have to cut my studs to fit a 1" spacer. thanks for the info
    jeremyd[QUOTED] likes this.
  8. Jan 23, 2019 at 12:10 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    @Donkeypunch did that convex center cap covering the hub come factory or did you buy it? i pulled off the cap from my wheels and it was just a concaved shape
  9. Jan 23, 2019 at 12:14 AM
    Donkeypunch
    The front had the “grease cap” in the center. I’m new to tundras but I beleive the 4x4 models have and axle nut in the front thus the need for the grease cap.
    For the rears mine is exactly as you described. I just painted the center concaved area a flat black. Hard to see in the pic below but can zoom in and can see it a bit.
  10. Jan 23, 2019 at 12:19 AM
    Donkeypunch
    BTW,
    There is a thread on here that is a “DIY grease cap mod” for the rears. A member made the same convex grease cap look in the rear. Basically bought the front grease cap, modified it to fit the rear and used a little JB weld to secure it.
  11. Jan 23, 2019 at 12:28 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    ohhhh, i guess thats why i dont have them since im 2wd. im debating on ordering one of those grease caps to see if they fit over that hole. im not a fan of the stock TSS cap either
  12. Jan 23, 2019 at 12:45 AM
    Donkeypunch
    Should work for the front and rear.
    Here’s the grease cap mod thread.
    https://www.tundras.com/threads/diy-rear-hub-grease-cap.5019/
    Or you can just paint the center flat black. I kinda like the concave look also in the rear of my truck.
    Newm and KLLVMDCL[QUOTED][OP] like this.
  13. Jan 23, 2019 at 1:20 AM
    KLLVMDCL
    Brandon
    Austin, Texas
    thanks for the link i was having trouble finding that thread
