Finally a no mess oil change!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Berettafan, Dec 1, 2018.
  1. Dec 2, 2018 at 10:56 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I'm hesitant to reply under the circumstances... ;)
    But I think it's better to change it while it's warm. You'll get more crap out if it's still warm, suspended in the oil and hasn't had a chance to settle.
    B737, 15whtrd and MotoTundra like this.
  2. Dec 2, 2018 at 11:04 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I could see that. I have found it’s an oil bath when you pull that plug when it’s hot. I may give the OPs large tub a shot or consider the Fumoto. I’ve got a few thousand miles to figure it out.
  3. Dec 2, 2018 at 11:10 AM
    PA452
    PA452 New Member
    Yeah, I experienced a bit of an oil bath last time too. I might do the cut jug thing next time, or just don't worry about it. It was worse than most, but not that terrible.
    I think it's an unintended consequence of the trend toward lighter weight engine oils. ;)
  4. Dec 2, 2018 at 12:20 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    not sure whats so difficult here, how you guys are getting covered in oil?
    - have (any) catch ready, remove one m10 bolt, oil flows out into catch. put bolt back in.
    no special valves, hoses, pans, tools needed. Can't even start on the guy changing his oil cold...
  5. Dec 2, 2018 at 12:39 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    2018 Black TRD OR CM Limited
  6. Dec 2, 2018 at 1:25 PM
    rodm1
    rodm1 New Member
    I personally wouldn't use one you need to get as much slug from the bottom of pan you can or you contaminate your new oil.
  7. Dec 2, 2018 at 1:33 PM
    15whtrd
    15whtrd Mr. Blonde
    Cool, more condescending responses from a certain T member.
  8. Dec 2, 2018 at 1:35 PM
    ardnutoz
    ardnutoz
    OZ
    SE-PA
    the pump doesn't eliminate the step of removing the drain plug. you will still have to remove it and drain the rest that the pump can't get to. however it makes an oil change as clean as possible
  9. Dec 2, 2018 at 1:50 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I use a Fumoto drain valve and have the aluminum oil filter cover. Once vehicle is up on the ramps with a warm engine. I slide a 5 gallon bucket under the truck and with a one foot piece of plastic hose on the valve, open it up. Doesn't seem to take more than a couple minutes if you pop the oil fill cap. Once it starts to drain I use the filter drain thingy ( screws into bottom of filter and spin nut to drain), once both are at a slow drip, close the valve, change the filter, wipe everything down and top off the oil with 7 1/2 qts to get it off the ramps. Then about a quart or so on flat ground to just at the full line. Spend most of the time enjoying a adult beverage and doing a little inside detailing while oil is draining.
  10. Dec 2, 2018 at 2:10 PM
    15whtrd
    15whtrd Mr. Blonde
    I will say changing the oil is pretty damn easy. But if you don’t have the pen close enough to the drain outlet it tends to splash everywhere. And it does come rushing out of there pretty quick at an angle. I don’t understand why you have to be so smug about your replies. I kind of hope that it makes the total mess next time you change your oil, just because you deserve it.
    Ronin and tinman10101 like this.
  11. Dec 2, 2018 at 2:32 PM
    Professional Hand Model
    Fred
    Hand Protectors
    IF for some reason I needed a Fumoto (to eliminate the messy gush), then I’d open it for the initial flush and THEN remove the entire Fumoto to get the last remainder of oil.
    As a 1st Gen’r our oil drops straight down, but if it shot to the side I’d use a different method (thats what she said).
    I never heard of Fumoto until this site. Cool item, but not for me.
    Pretty soon we’ll all have to do pan drops at the stealerships to keep their service repair going. No plugs. Honda makes it very difficult to change their transmission fluid with their skid plates in the way.
    15whtrd likes this.
  12. Dec 3, 2018 at 2:42 PM
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    Just got my last free one done at the stealership and adding these goodies to my Amazon cart as I type this. Quick question about the filter tool (1st time changing a Toyota too). Does the drain tool stay in filter cap?
  13. Dec 3, 2018 at 2:59 PM
    15whtrd
    15whtrd Mr. Blonde
    No you must re-install the drain plug in the filter assembly.
    ScooterInNV[QUOTED] likes this.
  14. Dec 3, 2018 at 3:38 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I ignore the dude so I didn’t see his response until you quoted it. So, thanks!
    Alright @B737, feel free to start in on me. I literally can’t find anything negative about dumping cool oil except that it takes longer and you “might” leave a little behind.
    So, since your a genius will you show me some solid info so I can be enlightened?
    This is a quick grab from the net....
    https://www.cartalk.com/content/which-better-changing-your-oil-when-engine-hot-or-cold
    tinman10101 and 15whtrd[QUOTED] like this.
  15. Dec 3, 2018 at 3:53 PM
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
    I have drain the oil cool on my last 3 tundras since the 0-20 pisses everywhere when hot (I do not have a garage, even the slightest wind sucked!), approx 550k and no issues.
    On the '18 I installed the Stahlbus drain valve, I liked it better as it has an o ring sealed cap to reduce any worrys of ever leaking. The TRD Pro skidplate stays nice and clean now.
    15whtrd and BTBAKER like this.
  16. Dec 3, 2018 at 4:05 PM
    15whtrd
    15whtrd Mr. Blonde
    I think he ignores me too LOL!
    BTBAKER[QUOTED] likes this.
  17. Jan 22, 2019 at 10:32 AM
    Ronin
    Ronin Hoof Hearted
    2019 CrewMax 5.7 Tanker
    8.5 quarts? Mine took that much too to the top of the fill dot. First time I've changed it. Not wanting to over-fill it. Oil was so dang clear it was hard to see it.
  18. Jan 22, 2019 at 10:39 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    With the Fumoto on the Tacoma I could just put a 5 QT oil container under it. With the Tundra I will need something bigger. I have an old 2 gallon gas can and that will be my new oil change container.
