Drivers side wiper sitting high
Discussion in '2.5 Gen Tundras (2014-2021)' started by Berettafan, Dec 11, 2017.
  1. Dec 11, 2017 at 6:48 AM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    Ran wiper with ice/snow on windshield and it seems the drivers side now rests an inch or two further along its arc than before. how do I fix this? never had this issue before.
  2. Dec 11, 2017 at 7:09 AM
    Slayer
    Slayer Member
    Slayer
    Is there a chunk of icebuilt up or lodged in there?
    Still frozen ?
    Wiper seatted properly?
  3. Dec 11, 2017 at 7:41 AM
    Berettafan
    2017 CM
    ice is melted.
    not frozen.
    seated against windshield properly.
    wondering if it maybe skipped a gear or something?
  4. Dec 12, 2017 at 7:02 AM
    jonjc23
    jonjc23 New Member
    Jon
    Pittsburgh, PA
    2015 Tundra Limted White CM
    Might need repositioned. Mine actually came loose and I had to re-tighten the nut for the arm. Once I did this I noticed it was sitting high, so just I just loosened the nut and repositioned the wiper arm.
  5. Dec 12, 2017 at 9:08 AM
    You can unbolt the wiper and reposition ther are slotted groves
    kstateskier likes this.
  6. Dec 12, 2017 at 12:52 PM
    Berettafan
    2017 CM
    thanks guys I will check it out.
  7. Jan 20, 2019 at 3:36 PM
    Ntmid8r
    Ntmid8r New Member
    2018 Tundra TRD Sport
    TBA
    What does this entail to get to the nut?
  8. Jan 20, 2019 at 5:05 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    Just pop the plastic cap off
  9. Jan 20, 2019 at 5:29 PM
    Icematt
    Icematt Toyota4life
    Black 1794 TRD
    Fuel wheels
    My wiper nut came loose to a couple days ago just repositioning tightening up
  10. Jan 21, 2019 at 10:55 AM
    Berettafan
    2017 CM
    Well mine just got jammed on some ice that slid off the roof. Get to loosen it and reposition again. Not sure why I never had this issue with prior vehicles? I suppose that's better than possible motor or mechanism damage.
