Will this work??
Discussion in 'Suspension' started by Muddog, Jan 19, 2019.
  1. Jan 19, 2019 at 10:28 PM
    Muddog
    Muddog [OP] New Member
    Bay Area California
    Kings front and Rear BMC Sliders 17s on toyo 35s
    So found a killer deal on a Icon Stage 1 front coilovers and rear piggy back shocks with Method wheels 5x150 on toyo rt 20x9 35x12.50. The wheel offset is +25. My question is will this setup work on my 2018 platinum without doing any other mods. I know eventually i will need to do UCA but im wondering if this setup will work right away without doing any cutting to the body or frame. Also anything else i would need to buy before installing.
    Thanks
  2. Jan 19, 2019 at 10:44 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I do believe you need to do a little more work to the front plastic lining and remove the front mudflap
  3. Jan 20, 2019 at 1:21 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I just had this installed this on my truck. How much lift are you going to try to get? The front wheel well piece behind the fog lights will need to be trimmed slightly. That’s all.
    To get 3” of lift you’ll most likely need to go past the 2” of exposed thread (start of thread on top to adjustable ring) limit set in the instructions. The description says 0-3.5” of lift. No way to achieve this without going past it.
  4. Jan 20, 2019 at 2:09 AM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Slap them on, take it home - and cut the shit out of the inner plastic fender liner behind the fogs until it stops rubbing. (4.5” angle grinder with a grinding wheel)
    Toyo’s run smaller than the Nitto Trail Grapplers I have on now.
    I was running 35x12.50x20 Toyo A/T’s prior with only a 2” front lift and had zero rub with minimal trimming.
    After the 35x12.5x18 Nittos and now at 3.5” front lift, I had a lot of trimming to do.
    (Remove mudflaps)
    OR18TRD likes this.
  5. Jan 20, 2019 at 6:48 AM
    Muddog
    Bay Area California
    Thanks for the info guys. I will go ahead and make this happen. Pics to come shortly. :fingerscrossed:
    Rica25 likes this.
  6. Jan 20, 2019 at 6:58 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    (eventually) on the UCA? With you possibly aiming at 3+ inches of lift you'll see the need of a UCA a lot sooner than later especially if you want to preserve those tires. You're gonna sacrifice something, either drive comfort or caster/camber without em. Just a heads up so take it for what its worth.
    Omohundro likes this.
  7. Jan 20, 2019 at 8:01 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    did 4wheel parts do it ?
  8. Jan 20, 2019 at 8:07 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Yes
  9. Jan 20, 2019 at 8:15 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    they do your alignment too? I actually just called them on Friday lol.You had a leveling kit before? did you end up going with different control arms?
  10. Jan 20, 2019 at 8:18 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Yes they did the alignment. They refunded the pro comp kit. So I got the icon Coilovers and rear shocks. But I need UCA’s. Trying to get them on the total chaos group on here but I need them sooner rather than later.
  11. Jan 20, 2019 at 8:34 AM
    2010bigdog
    Chuck
    Chicago
    2018 MGM SR5 TRD
    sent you a PM
