Alignment Question
Discussion in 'Suspension' started by bamelanc, Jan 13, 2019.
  1. Jan 13, 2019 at 5:56 PM
    bamelanc
    bamelanc [OP] New Member
    Orange, Texas
    2018 Magnetic Grey Platinum 4x4
    Addictive Desert Designs Stealth Fighter bumper w/ 40" Baja Designs Onyx6 arced dual control combo light bar and Smittybuilt X20 Comp 10k winch. Baja Designs S8 10" amber fog lights. sPod Control for lighting and compressor. ICON Stage 3 Suspension with tubular UCA set at 3". ICON Alloys Six Speed 17" machined/satin black wrapped in 285/75/17 Nitto Ridge Grapplers. TRD Performance Intake. TRD Cat Back Exhaust. LED Kit inside and out. ARB onboard compressor. Amp Research Power Step w/LED kit. Retrax XR Pro bedcover. Armadillo Bed Liner. Tint - 35/5/5 ceramic. Center Console Safe. Weather tech mats.
    18 CM with Icon Stage 3 w/Icon tubular UCA. Icon Sixspeed 17x8.5 25mm offset on 285/75 NRGs.
    I've had the truck aligned twice by 4WP and it still pulls to the right. Tires are wearing unevenly. I did the string check and found this.
    FD - 7/8 and 3/4
    RD - 7/8 and 7/8
    FP - 1 1/32 and 1
    RP - 7/8 and 7/8
    Used two jackstands and a string with a ruler and got these measurements. They indicate a slight total toe, but I think it's odd the front passenger is tucked in so much.
    Last alignment performed about 4k ago. About to take it to someone else that's recommended for aligning lifts for a second opinion.
    Thoughts?
  2. Jan 13, 2019 at 5:58 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
  3. Jan 18, 2019 at 5:39 PM
    bamelanc
    Orange, Texas
    Turns out the alignment was way off. 4WP equipment must be out of calibration because it was pulling the instant I left their garage.
    Southern Tire Mart in Sulfur, La did the alignment. Took about 30 minutes. I’m happy now, truck drives straight as an arrow.
