Front end noise after installing 3.5 kit with 35 tires
Discussion in '2.5 Gen Tundras (2014-2021)' started by williamsimons7613, Nov 6, 2018.
  1. Nov 6, 2018 at 2:46 PM
    williamsimons7613
    williamsimons7613 [OP] New Member
    2018 crewmax trd
    3.5 lift with uca, 18x9 fuel vectors , 35x12.5 toyo rt open country
    Hi all , new here .. recently put a 3.5 lift with 35x12.5 on 18x9 wheels getting a clunk from the front end now .. I’ve taking the skid plate off and have no running problems, any ideas
  2. Nov 7, 2018 at 7:34 AM
    JohnH
    JohnH From PA
    Pennsylvania
    2017 Tundra SR-5 4x4 TRD MGM
    ADS 3.0 with clickers ADS bypasses Deaver U748 springs Magnum steps (with Line-X applied) Powdercoated bumper ends Powdercoated TRD wheels Pro grill Husky X-Act
    Is the clunk while turning hard? If so, you may have to bend the front corner “ears” up due to the tires hitting them?
    Also, what lift did you install?
  3. Nov 7, 2018 at 7:40 AM
    williamsimons7613
    2018 crewmax trd
    Hi , thanks for your response, I did the rough country 3.5 , it makes the noise when turning and driving straight and it’s very random .. I’m taking back to the installer later today , I’m starting to think it could be a break issue antilock or something
  4. Jan 17, 2019 at 10:20 PM
    oleyeti
    oleyeti New Member
    Greg
    Southaven, MS/ Memphis, TN
    2007 White Tundra Limited
    Toytec boss coilover Toytec boss reservoir shocks Icon progressive AAL pack Rough country UCA Ceramic coating Debadge Assault soft tonneau cover bully dog BDX tune
    Did you ever find out what the clunk was coming from?
