Lubricate Power Folding Tow Mirrors?
Discussion in 'General Tundra Discussion' started by SOB, Sep 13, 2018.
  1. Sep 13, 2018 at 11:38 AM
    SOB
    SOB [OP] Big Member
    Ohio
    2013 Red Crew Max Platinum
    My power folding tow mirrors have been giving me issues when un-folding. Sometimes they don't un-fold all the way and if I forget to check I may drive off and notice that one mirror is pointing at the side of the truck instead of traffic beside me. It's dangerous sometimes. If I cycle them 2-3 times they will usually fold/un-fold completely but that's getting annoying.
    I'm thinking (hoping) it's just a lubrication thing as they do squeak when moving - like a plastic on plastic squeak. What would one lubricate these mirrors with? I have a whole slew of lube sprays but I don't know which would be best. White Lithium, WD40, chain lube, dry lube, etc.
  2. Sep 14, 2018 at 9:54 AM
    SOB
    SOB [OP] Big Member
    Ohio
    No one's into lube?
    MotoTundra likes this.
  3. Jan 16, 2019 at 4:18 AM
    Punisher5353
    Punisher5353 New Member
    Pennsylvania
    2013 Black Tundra CrewMax TRD
    JBA Long Tube Headers, X pipe, Duel Borla Exhaust, Air Box Mod, Dap Tune, 22” Black Rhinos
    I’m having the same issue. 2-3 times to get the mirrors to fold open and close all the way.
  4. Jan 16, 2019 at 5:23 AM
    SOB
    SOB [OP] Big Member
    Ohio
    Are these OEM or from 1AAuto (or other aftermarket)?
  5. Jan 16, 2019 at 5:27 AM
    Punisher5353
    Pennsylvania
  6. Jan 16, 2019 at 6:01 AM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    @Roman May know something about this
  7. Jan 16, 2019 at 6:11 AM
    15whtrd
    15whtrd Mr. Blonde
    Is it possible for you to take them apart to see where it is binding? Maybe there’s a way to clearance some of the plastic and lube the gears. Or maybe just some dry silicone spray blasted up in there. Or even something as simple as spraying wax addict to treat the mirrors plastic may also act as a lube.
  8. Jan 16, 2019 at 6:47 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    I honestly haven't heard of this. I would think it would be related to dirt or gunk build up, but the only way to know that would be to take them apart somehow and then clean and lube it all up. I'd be super cautious with trying to take them apart, though.
    15whtrd and TokerJoker like this.
  9. Jan 16, 2019 at 10:34 AM
    SOB
    SOB [OP] Big Member
    Ohio
    I tried the dry silicone spray with no luck. It seemed like anything I tried was just surface lube and just dries up with no actual benefits. I assumed it was a sealed system to keep dirt and grime out. So in turn no lube can get in without taking the mirrors apart.
    15whtrd[QUOTED] likes this.
  10. Jan 16, 2019 at 10:35 AM
    SOB
    SOB [OP] Big Member
    Ohio
    Taking them apart isn't something I would personally try on $400 mirrors (or $800 if you bought OEM). 1AAuto was kind enough to replace mine under warranty.
    15whtrd and Roman[QUOTED] like this.
  11. Jan 16, 2019 at 11:59 AM
    15whtrd
    15whtrd Mr. Blonde
    So I take it you are getting them replaced under warranty through 1AAuto? When you hook up the new ones, put a little dielectric grease on the connections just to ensure that’s not your issue.
  12. Jan 16, 2019 at 1:39 PM
    lawfarm
    lawfarm New Member
    2018 Tundra SR5 Premium TRD Crewmax
    Is it always binding at the same location in folding, or does it vary?
  13. Jan 16, 2019 at 6:13 PM
    SOB
    SOB [OP] Big Member
    Ohio
    I had them replaced a while ago. I first started this thread in September. It’s just now getting some responses :rolleyes:
    It def didn’t seem like a connectivity issue. I remember hearing a plastic squeaking noise most the time when it would get hung up. I even tried applying grease to the outer plastic pieces in case they were rubbing.
  14. Jan 16, 2019 at 6:18 PM
    SOB
    SOB [OP] Big Member
    Ohio
    They would pretty much bind up at the same point. Almost like they would torque out. With a little assistance they would fully travel but it’s a little hard to reach the passenger side mirror from the drivers seat.
    15whtrd likes this.
