20 inch platinum rims
Discussion in 'Wheels & Tires' started by Tundra apostle, Jan 16, 2019.
  1. Jan 16, 2019 at 6:43 AM
    Tundra apostle
    Tundra apostle [OP] New Member
    Leo
    Black 2018 tundra sr5 5..7
    None yet but just got 20" rims from a limited and am planning on getting more agresive tires and a lift kit after Christmas. Installing running boards now so i guess its starting .
    I just got a set of 2019 tundra platinum rims an want to put them on my 2018 sr5 the 20"rims dont have the air sensors. My question is am I able to use my sr5 metal rim sensors on the 20"s and if I use them do I have to reprogram the sensors back to the truck again. I dont want to go through the hassle of having to go to the dealer to get them re programmed. If its nesesary then I will get a new set and save this set as is and use it when I need to go to the job site for a month straight.20181206_112017.jpg
  2. Jan 16, 2019 at 7:25 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    They may work, tire shop can tell you yes or no. If useable, no programming required.
    Thinking alloy wheels do have different sensors than sreelies. @Roman might chime in.
    Tundra apostle[OP] likes this.
  3. Jan 16, 2019 at 8:44 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  4. Jan 16, 2019 at 8:49 AM
    Trooper2
    JR
    Most tire shops can program.
  5. Jan 16, 2019 at 8:57 AM
    Tundra apostle
    Leo
    Now if I program the new set will it bump the other set or can I keep it programmed on the system still
  6. Jan 16, 2019 at 10:26 AM
    Trooper2
    JR
    Thinking it will bump out the 1st set, only one set at a time, only set on vehicle. Tire shop or dealer could clarify.
  7. Jan 16, 2019 at 10:27 AM
    Roman
    Roman
    Franklin, TN
    Yep, it will delete the older set.
