Fuel additves?
Discussion in 'Performance and Tuning' started by SteyrM40A1, Jan 15, 2019.
  1. Jan 15, 2019 at 5:02 PM
    SteyrM40A1
    SteyrM40A1 [OP] New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    On my 05 Tacoma I used to run a bottle of fuel system cleaner about once a month. Now that I have my 18 Tundra I was wondering if and what everyone here is using, if anything at all? Also is once a month to much or not enough?
  2. Jan 15, 2019 at 5:21 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I don’t use anything but am curious to know as well
    SteyrM40A1[OP] likes this.
  3. Jan 15, 2019 at 5:26 PM
    Grumpy Uncle
    Pat
    CO
    I use this every 3k to 6k miles, in all of my vehicles. Never had any problems because of it.7080006_lco_10020_pri_larg.jpg5
  4. Jan 15, 2019 at 5:29 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    I run a bottle of Lucas Upper Cylinder through each of the vehicles once/twice a year. Maybe it does something.
    I still get 36mpg in my 2007 Toyota Matrix, 165k miles, same MPG since the day we bought it, and I've always used Lucas Upper Cylinder in this vehicle. It also doesn't lose 1 drop of oil between 10k mile oil changes.
    Everything else (mowers, bikes, generator) only get the blue Sta-bil.
    Grumpy Uncle likes this.
  5. Jan 15, 2019 at 5:30 PM
    SteyrM40A1
    Gregg
    Thats what I have been using. Although motorkote has a similiar product and I used it last time.
  6. Jan 15, 2019 at 5:31 PM
    BIGUGLY
    BIGUGLY I the SheepDog. I have the capacity for Violence.
    Paul
    2018 Limited
    Use Lucas here as well .run it 2 to 3 times a year. Of you buy it in the gallon size it's much cheaper than the little bottles
  7. Jan 15, 2019 at 5:37 PM
    Grumpy Uncle
    Pat
    CO
    I dont like change.:D my Dad always used Lucas, and for the last 30 years, it's what I use. And like @OBXTundra said, for lawn equipment storage Sta-bil. There are a lot of different ones out there, I just choose to stick with what has worked for me. I hope that doent sound snarky.
  8. Jan 15, 2019 at 5:44 PM
    SteyrM40A1
    Gregg
    Not at all @Grumpy Uncle I am always curious as to what everyone else is using.
  9. Jan 15, 2019 at 5:51 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    I will say the blue sta-bil has been better for me than the red. I've had bikes and equipment not start or start very rough and run rough for an extended amount of time after using the red. I've had no issues in the last few years of using the blue sta-bil. Everything starts and runs everytime. No rough running or acting up either.
  10. Jan 15, 2019 at 5:57 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I run Seafoam thru the tank and the crank annually. I put it in about 1/2 tank before I'm going to do an oil change.
    TRD-tv, Black Wolf and SteyrM40A1[OP] like this.
  11. Jan 16, 2019 at 9:15 AM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Lucas oil products ONLY for me too, been using the upper cylinder lubricant as well as the Fuel System treatment for 20 years. :thumbsup:
    StrayCat4x2, Black Wolf and OBXTundra like this.
  12. Jan 16, 2019 at 10:14 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    2013 Tundra SR5 CM TRD 5.7 4X4
    Another vote for Lucas. I use the upper cylinder lubricant 2/3 times a year. I don't know if it's helped but I do like the fact that it's not solvent based.
  13. Jan 16, 2019 at 10:20 AM
    I use Lucas Upper Cylinder Treatment in my gas tank and MotorKote for the crankcase. MotorKote is totally different. Motorkote is not an additive like Lucas UCT. MotorKote can be added to a full crankcase and will not displace oil. A great anti friction product that works. It clings to all metal engine surfaces and doesn't affect seals. Not cheap though.
  14. Jan 16, 2019 at 10:23 AM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Marvel mystery oil every now and then. Been using it to build, and maintain motors for over 10 years. Love that stuff if I have a motor going to sit for several months I put a lil bit on top of the Pistons
    Black Wolf likes this.
  15. Jan 16, 2019 at 10:33 AM
    It's easy to make your own MMO. It's simply 75% mineral oil, 1% lard, and the problematic ingredient>>>>>25% Stoddards SOLVENT...Yes 25% of MMO is solvent. Back in the 20's MMO was used as a cleaning/solvent additive to gas tanks because refineries back then put out inconsistent fuel. Somehow over the years it's now considered a lubricity product. Technically yes due to the 75% mineral oil. :thumbsup:
  16. Jan 16, 2019 at 10:40 AM
    Stormtrooper81
    Lost coast
    2011 DC
    Thanks . Honestly I never even checked it out. I was taught to use it 20 years ago. Carbureted Harley motors, orchard equipment, tractors, etc. I live in a rural area. I wouldn't use any fuel additives if I lived in a city with good gas stations. The dust alone on country roads needs something to clean up the cylinders every once in a while. Imho
  17. Jan 16, 2019 at 10:58 AM
    MMO is good and relatively inexpensive. Has multiple uses too. I've even used in my lawnmower. The military uses it by the barrel. MMO has been around a long time.
  18. Jan 16, 2019 at 10:58 AM
    teedubbya
    teedubbya I like fat booty
    Austin TX
    2019 trd pro voodoo 4runner
    There’s a feller on YouTube that tested most every one. There were maybe one or two that showed minor cleaning of the valves. Worth it? Not IMO. Using quality fuel such as Shell has shown to help reduce buildup and clean just a wee bit. I rather do that.
    I use to have a GDI vehicle and it was recommended every 5k miles. If you start doing it with a new vehicle, perhaps overall longevity will improve.
  19. Jan 16, 2019 at 11:07 AM
    Yeah, if you use top tier gas you should be good to go. Some folks like buying the cheaper gas. In that case you could add Techron I guess. I think I know of the YouTube guy you mentioned. Cool.
  20. Jan 16, 2019 at 4:53 PM
    SteyrM40A1
    Gregg
    I was referring to a different product that Motorkote makes, its an upper cylinder lubricant, it was sitting right next to the Lucas oil product.
  21. Jan 16, 2019 at 5:22 PM
    That's cool. Wasn't aware of it.Going to have to try it. Tufoil has very decent products too.
  22. Jan 16, 2019 at 5:36 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    All I know is these little bottles are friggin expensive !!
    SteyrM40A1[OP] and Black Wolf like this.
  23. Mar 2, 2019 at 1:52 PM
    lewi3069
    lewi3069 New Member
    2017 Crew Max 4x4 Sunset Bronze
  24. Mar 3, 2019 at 6:44 AM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    I buy a gallon of Lucas injector cleaner and a gallon of Mistery Motor Oil and add the two every three to six months to all my vehicles.
    No issues ever. Good luck. D
