Rear block size
Discussion in 'Suspension' started by 510Krish, Jan 14, 2019.
  1. Jan 14, 2019 at 11:22 PM
    510Krish
    510Krish [OP] New Member
    2018 Toyota Tundra Platinum 4x4
    Hey, so I have a 6in procomp on my 2018 Toyota Tundra. I put on some new shocks up front and a preload spacer that sits on top of the spring. My truck is sitting one in higher in the front and one inch lower in the back. Does anyone know if I get a 5in block in the rear will this fix my problem? If so can some one link me compatible 5in blocks for my truck that will fit. I think I can keep the u bolts on there since it it’s kind of long.
    Thanks!
  2. Jan 15, 2019 at 5:36 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Yes, that will raise the rear. If it was me I would put a 1 inch shackle, much easier to install.
  3. Jan 15, 2019 at 8:07 AM
    510Krish
    Can you give me a link to purchase some good shackles that are lifted 1in
  4. Jan 15, 2019 at 8:14 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    I was afraid you would ask that..People on here can be real sensitive to name brands. Every shackle out there will work just fine. I have a pair of 45 dollar shackles from Ebay that have been on since 2014. They are adjustable 1, 1.5 and 2. They are set on the 1 inch..My buddy and I installed them in about 45 minutes. Here you go.shackle.jpg
  5. Jan 15, 2019 at 9:58 AM
    510Krish
    Does that level your truck?
  6. Jan 15, 2019 at 12:09 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Yes
  7. Jan 15, 2019 at 12:13 PM
    Nice rig !
    jeremyd[QUOTED] likes this.
  8. Jan 15, 2019 at 12:19 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    The airbags are strictly for towing.
