Regearing
Discussion in 'Performance and Tuning' started by muhman_527, Jan 14, 2019.
  1. Jan 14, 2019 at 8:37 PM
    muhman_527
    muhman_527 [OP] New Member
    Houston Texas
    Hello fellow tundra dwellers. So I have recently put on a 6 inch RC suspension lift on my 2011 tundra 4.6L V8 double cab. Therefore I also put on some fury country hunter mts 35x12.50xr18 with 18x9 American racing wheels. So I’ve noticed a loss in power especially on the highway and at speeds 60+ which was expected and was considering regearing my truck. I believe the current gear ratio is 3.91 if I’m not mistake and was wondering was the best gear ratio would be to go to. Really want to maintain a similar drive to factory or better if I can. The truck is also 2wd so i would only need to regearing the rear?
  2. Jan 14, 2019 at 8:44 PM
    TheBeast
    TheBeast The Beach
    yes rear only. there is a chart here somewhere showing which gears for which tire size is preferred
  3. Jan 14, 2019 at 8:50 PM
    muhman_527
    Houston Texas
    Yes I think I’ve seen this chart. The green section for 35’s says to install 5.29 gears. I thought the most it went to was 4.88? This is where I’m confused. I dont want to “over gear” if that makes sense and make the truck disproportional
  4. Jan 14, 2019 at 8:52 PM
    TheBeast
    TheBeast The Beach
    for 35"s most of us with 5.7L just stay stock. you could go 4.88 but 5.29 would be 37's and bigger for sure.
    Rica25 and 15whtrd like this.
  5. Jan 14, 2019 at 8:53 PM
    15whtrd
    15whtrd Mr. Blonde
    The 5.7 L comes with a 4.3 gears. That would probably get your 4.6 with 3.91s feeling like it used to. Next option would be 4.88s. Someone is supposed to be coming out with a 5.29 gears. Right now on stock tires and gears, at 72-75mph I’m right around 2000 rpm in 6th gear and the torque converter locked out.
  6. Jan 14, 2019 at 8:54 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    I have my OEM/stock 4.3 gears for sale if you're interested. I'm on 4.88s now but I'm also on 40" tires. I'm going to 5.29s and 42" tires later this year.
    Rica25 and TheBeast like this.
  7. Jan 14, 2019 at 8:55 PM
    muhman_527
    Houston Texas
    4.88 was what I was thinking. Thanks for the time
  8. Jan 14, 2019 at 8:55 PM
    TheBeast
    TheBeast The Beach
    there you go :)
    Rica25 likes this.
  9. Jan 14, 2019 at 8:56 PM
    15whtrd
    15whtrd Mr. Blonde
    I wouldn’t mind 4.88s on my stock tires. BA!
    Rica25 and Darkness like this.
  10. Jan 14, 2019 at 8:56 PM
    muhman_527
    Houston Texas
    I’ll probably move to 4.88
    15whtrd likes this.
  11. Jan 15, 2019 at 9:11 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    A 4.6 uses the diff from a land cruiser which is only 9.5” not 10.5” nothing from a 5.7 will work in a 4.6
    For 35’s if you want to spend $ on gears and make it feel stock go 4.88.
    But if you want your money to go toward making it more fun than stock go 5.29
    I prefer to spend my money making it more fun than stock rather than making it stock.
    There is just about no such thing as too much gear. The steeper the better. Gotta remember we are not carbureted. We have adaptive memory efi. Vvti. Variable runner length intake. The ecu determines afr based on load. Increasing wheel speed in relation to mass air meter volume fools the ecu into thinking there is less load. It in turn adds timing and takes out fuel. This actually keeps more Hp on the table. And gives you better fuel economy.
    When using a chart to determine gear ratio the rule of thumb is find the ratio they goes back to stock. Then step it up 1-2 more to make up for the extra weight.
    Call for details.
    Keith 760-877-4234
  12. Jan 15, 2019 at 9:37 AM
    muhman_527
    Houston Texas
    Exactly the answer I was looking for. Thanks for the explanation.
    Rica25 likes this.
  13. Jan 15, 2019 at 10:03 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Only downside is strength on the 5.29 vs 4.88s
    Rica25 likes this.
  14. Jan 15, 2019 at 10:07 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    What Keith said sounds reasonable.
    What 15whtrd sounds fun. :D
    I went a bit over on my truck, very different truck but my fuel usage did drop to Keith's point.
  15. Jan 15, 2019 at 10:08 AM
    15whtrd
    15whtrd Mr. Blonde
    Are the 5.29’s made differently? Or are you saying this because they are now spinning so much more creating more torque to break something? Just curious
    Rica25 likes this.
  16. Jan 15, 2019 at 11:10 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    I believe the constant mesh/contact patch for the 5.29s is 1 and the 4.88s is 3. I also believe this to create more heat due to more work/stress due to teeth contact. Someone please correct me if I am wrong.
    Darkness and 15whtrd[QUOTED] like this.
  17. Jan 15, 2019 at 4:55 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Seems fair. Less teeth on the pinion possibly?
    Rica25 likes this.
  18. May 5, 2019 at 5:05 PM
    tufftundy11
    tufftundy11 New Member
    2000 tundra limited
    King shocks, spc upper control arms
    I will be regearing some time this year. I am thinking 4.88 for a truck with 305/55r20. Does that sound right or should I go 5.29? Also interested in upgrading other components while I'm in there. What locker/lsd is recommended for a daily driver? I've heard of an issue in the front diff where you get a vibration but it goes away while in 4x4. Is there anything like that or anything else I should upgrade while I'm in there on front or rear diff?
