Volent Snorkel for tundra
Discussion in 'Off-Topic Discussion' started by Woodtickmp, Jan 14, 2019.
  1. Jan 14, 2019 at 4:31 AM
    Woodtickmp
    Woodtickmp [OP] Black beast/beauty/pearl
    Mathew
    west bend WI
    2010 tundra double cab black TRD rock warrior
    3in front leveling kit with camburg engineering upper A-arms, 2in block in the rear and 6 pack leafs, 295/65/17
    Has anyone on here ever installed a Volent Snorkel or know someone that has. I'm looking into one for my db rw. I know that they pull cleaner air into the engine and i made my own for my 1994 Chey suburban out of 2in pvc and it made a difference in hp but im try to figure out if it is worth it for the tundra.
  2. Jan 14, 2019 at 4:49 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  3. Jan 14, 2019 at 4:50 AM
    15whtrd
    15whtrd Mr. Blonde
    You mean Volant cold air intake? Or are you looking for a snorkel so that you can submerge the truck for water crossings? If you’re looking for just a CAI you’re not going to gain much if anything.
  4. Jan 14, 2019 at 5:02 AM
    Mnorris1206
    08 tundra
    Man don't do that if you want a snorkel buy a jeep. Lol
    Rica25 likes this.
  5. Jan 14, 2019 at 5:06 AM
    The Volant snorkel is a total PITA to install. Upside....price has dropped drastically since they aren't selling too many.
  6. Jan 14, 2019 at 5:14 AM
    KMG
    KMG New Member
    Kevin
    Yacolt, WA
    2018 White Tundra Limited DC 4x4 TRD
    BFG KO2s, TRD Rear Sway Bar, Firestone RideRite Air Bags, B&W Gooseneck Hitch, Trail Ridge Extendable Towing Mirrors
    Total waste of money! Good luck with resale value.
    Black Wolf likes this.
  7. Jan 14, 2019 at 5:26 AM
    Woodtickmp
    Mathew
    west bend WI
    I always like the look of a Snorkel on trucks. I don't plan on selling it i plan on giving it to my kids wien i have em. Im just kicking around the idea of getting one. And yes i ment volant they make the intake and snorkel kit.
  8. Jan 14, 2019 at 5:33 AM
    Vr0ck
    Vr0ck New Member
    Virginia Beach, VA
    2016 5.7 MGM DC 4x4
    Toytec Boss C/O, Toytec Shackles, 5160s, nfab step bars, 8" BAMuffler, OVTune, AuxBeam LEDs, Vahalla protection plates
  9. Jan 14, 2019 at 5:55 AM
    Woodtickmp
    Mathew
    west bend WI
    The first time looked at that system there wast very many reviews on it.
  10. Jan 14, 2019 at 6:11 AM
    Definitely not many reviews probably because it's such a pain to attempt install. The TundraHQ guys had a hell of a time with install. It hurt just to read their review..
  11. Jan 14, 2019 at 6:19 AM
    It doesn't look too bad once installed. Price is right now. You will need help with install for sure...and beer...and a long weekend...heh...heh.
  12. Jan 14, 2019 at 6:28 AM
    Woodtickmp
    Mathew
    west bend WI
    I had jim beam when i installed the catalitist system. Like i said I'm kicking around the idea. I wish there were more options for the tundra.
    Keegan C and Black Wolf[QUOTED] like this.
  13. Jan 14, 2019 at 6:33 AM
    It's too bad ARB engineers haven't come up with a snorkel for the 2007s and up..at least Volant did. It's really the only one for the 07 to 13.
  14. Jan 14, 2019 at 6:43 AM
    polymerhead
    polymerhead New Member
  15. Jan 14, 2019 at 9:06 AM
    mountainpete
    I had an ARB Safari Snorkel on my Tacoma for around 10 years so I feel like I can rant intelligently on the subject.
    I added the snorkel mostly as an insurance policy. The truck went through its share of streams where the bow wake went over the hood. The snorkel reduced the likelihood of engine lockup (reduced, not eliminated as the snorkel was just one part of the system). Beyond water, I found it was valuable on high-speed dusty fire roads and keeping the air intake high where the particulates are smaller and thus the filter cleaner. Not a game changer as I banged out the filter daily anyways, but a helper.
    Theoretically, a snorkel should produce a ram-air, cyclonic effect and thus increase engine performance/efficiency. I did not see any of that and 99% of people don't. It's likely due to the fact that vehicles with snorkels also have hundreds of extra pounds of armour, equipment and higher rolling resistance off-road tires. It's not enough to cancel any of that out.
    Cutting the fender holes wasn't easy mentally, but not a hard mechanical job. If you mess it up though, it's a big mess up. Plus, the more holes you add, the more likely it will rust. The Volant looks like a nightmare install though - I wouldn't touch that thing.
    Car washes become tough with a snorkel. You really shouldn't use an automated wash because you're basically spraying water and soap straight into the system.
    My advice: treat a snorkel like optional insurance. Only buy one if you are going to put you truck in situations where you're likely to need it.
    Black Wolf and joonbug like this.
  16. Jan 14, 2019 at 11:04 AM
    Makes sense!:thumbsup:
