Coil over issue.
Discussion in 'Suspension' started by Mnorris1206, Jan 12, 2019.
  1. Jan 12, 2019 at 10:55 AM
    Mnorris1206
    Mnorris1206 [OP] Super white is fast as f***
    08 tundra
    Got my struts put together but they are not sitting all the way on the perch. My buddy said they will pop into place when they are on the truck .Anyone else ever seen thus happen ?
  2. Jan 12, 2019 at 10:58 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Yup had this problem on my 04. It had Monroe Quickstruts on it when I bought it, bought 5100's and the coils would not fit pretty much exactly where you're at. Unfortunately no they do not go into place, ended up buying new springs.
    Mnorris1206[OP] likes this.
  3. Jan 12, 2019 at 10:59 AM
    Mnorris1206
    08 tundra
    Well crap.
  4. Jan 12, 2019 at 11:24 AM
    Mnorris1206
    08 tundra
    One quick question did you try mounting them on the truck then bouncing it up amd down ? Thays what he said will make then sit down properly I dont get why I'm having thos issue they are stock springs .
  5. Jan 12, 2019 at 11:26 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    I didn't, I was working with my mechanic and he advised against it.
    If they're stock, I'd double check you received the correct shocks.
  6. Jan 12, 2019 at 11:27 AM
    Mnorris1206
    08 tundra
    I am going to call rough country on mon. Thanks for the help .
  7. Jan 12, 2019 at 11:28 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t think the stock springs are white. Maybe you painted them? If so, maybe the paint is holding it up on the inner coil
  8. Jan 12, 2019 at 11:34 AM
    Mnorris1206
    08 tundra
    Thats what my buddy thought at first so he grinded them down on the inner side but got the same result. Idk if they are the right struts I will just put them on amd go jump my truck lmao jk but maybe hit some speed bumps and see what happens. Crap idk what to do lol
    15whtrd[QUOTED] likes this.
  9. Jan 12, 2019 at 11:41 AM
    15whtrd
    15whtrd Mr. Blonde
    What brand are the shocks?
  10. Jan 12, 2019 at 11:49 AM
    Mnorris1206
    08 tundra
    Thats what I will do . Its my luck that this is going on lol .I'm sure I will get it figured out they are not that far off at all that is what is crazy you would think the spring would force its self down it must be crazy strong for it not to .
  11. Jan 12, 2019 at 11:54 AM
    Mnorris1206
    08 tundra
    Well I think because unless it is sitting in their right its forcing it to one side
  12. Jan 12, 2019 at 11:54 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    One other way to look at it too is if you get them on and need new shocks later you're probably never getting those springs off again.
    I ended up just getting some cheap Monroe's to run until the new springs came in. Once I got the new ones in, I sold the old assemblies to make up some of the cost.
  13. Jan 12, 2019 at 11:58 AM
    Mnorris1206
    08 tundra
    15473230825611816409966.jpg look how close .
    Rica25 likes this.
  14. Jan 12, 2019 at 12:11 PM
    Mnorris1206
    08 tundra
    Only problem here is these are lifted struts 6" from rough country so I would have to run what I have until I figure it out. That is ok but just wanted this done and over lol
  15. Jan 12, 2019 at 12:14 PM
    Mnorris1206
    08 tundra
    The whole strut .
    Mountun Goat and Rica25 like this.
  16. Jan 12, 2019 at 12:36 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I can’t see why it wouldn’t sit down once the truck weight is on it. But it does seem odd for sure. It your ever off road and in a full droop position it will most likely gap out again. Unless the sway bar or another bind point is before that
  17. Jan 12, 2019 at 12:38 PM
    Mnorris1206
    08 tundra
    No off road for me .Lol unless on a quad .But yes I think it will go for sure we just smacked the bottom on the ground from like 1 ft up and it went down about a 1/4" so I think it will be ok. If not we will just jump some railroad tracks hahaha
    Mountun Goat[QUOTED] likes this.
  18. Jan 12, 2019 at 12:39 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I’d try it before spending more money. But that’s me just being a cheap ass haha
  19. Jan 12, 2019 at 12:40 PM
    Mnorris1206
    08 tundra
    Yep me too the guy that put these together has been a mechanic for 15 yrs he said he has had this with other struts as well .
  20. Jan 12, 2019 at 12:40 PM
    Mnorris1206
    08 tundra
    We will see I guess .O and I'm a cheep ass too .
