New to me purchase advice!
Discussion in '2nd Gen Tundras (2007-2013)' started by Tundra2times, Jan 12, 2019.
  1. Jan 12, 2019 at 8:02 AM
    Tundra2times
    Tundra2times [OP] New Member
    Guys looking for advice on a new to me purchase.
    2011 crew max limited
    92k
    $21,500
    New brakes all around
    New tires
    Trans and dif service done
    Regular maintenance records
    (Buying it from a mechanic shop owner)EAA48D4A-F6F4-46A4-A5A8-3F79BF6C9B1F.jpg024D0E24-6811-4B86-877D-DAE677DD8302.jpg
  2. Jan 12, 2019 at 8:20 AM
    Stormtrooper81
    Stormtrooper81 Slow and steady
    Lost coast
    2011 DC
    Welcome to the forum. Good deal imo, but I'm from CA and everything is expensive here. Check cam tower for leaks.
    Capt J-Rod and Y0TA PR0 like this.
  3. Jan 12, 2019 at 8:22 AM
    Tundra2times
    Thanks for the response. Trust me I hear ya... Chicago is not that much cheaper.
    Guy seems to have taken really good care of it. I’ll take a peak at the towers
    Thanks again stormtrooper
    Stormtrooper81 likes this.
  4. Jan 12, 2019 at 8:23 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Sounds very fair. get the carfax too, mechanics can hide things.
  5. Jan 12, 2019 at 8:24 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Get under it and look for fresh fluid leaks and anything more than surface rust.
  6. Jan 12, 2019 at 8:24 AM
    Stormtrooper81
    Lost coast
    2011 DC
    I think you'll be happy. I bought mine with more miles, more beat up, smaller motor, for 18k. And I'm very happy I did
  7. Jan 12, 2019 at 8:24 AM
    Sounds like a good deal to me.
  8. Jan 12, 2019 at 8:25 AM
    Also welcome from Ohio!
    Tundra2times[OP] likes this.
  9. Jan 12, 2019 at 8:36 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    In Chicago, check for rust underneath. And, welcome.
  10. Jan 12, 2019 at 8:46 AM
    Welcome from NY.
  11. Jan 12, 2019 at 9:24 AM
    rebmo
    rebmo 2020 Crewmax Limited 4wd Silver/Black
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Welcome from WI
    Some suggestions for basic maintenance and mods.
    Coat bottom with fluid film for winter salt protection
    Keep washed in winter underside and touchless car wash
    Keep wheels free of salt paint bubbles easy
    Wire drill brush hitch metal spray with black rust paint if when needed
    Spray in Bedliner if none
    All weather floor mats
    TRD shift knob nice over stock
    LED bulbs for headlight fog improvement
    Grease driveshaft fittings every oil change
    Check for recalls
    Nice truck TLC and should last a long time
  12. Jan 12, 2019 at 11:58 AM
    Tundra2times
    Thanks all
    Truck has remote start, spray in bed liner and a few other bells and whistles.
    This is my second Tundra. Had an 05 quad cab limited bought with 112k and sold it at 265k. Hoping for similar results.
    It also has a K and N cold air kit...has a pretty good throaty sound. It appears that the original owner put some type of push button start accessory on it but current owner knows nothing about it.
  13. Jan 22, 2019 at 12:54 PM
    chazzykaid
    chazzykaid New Member
    2011 White Platinum Tundra
    6" lift 35s on 20s
    I just bought a 2012 5.7 with 103k. didnt even bat an eye. these trucks when taken care of are 300k+ trucks
  14. Jan 22, 2019 at 12:58 PM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    As long as it has been taken care of, that looks like a good deal.
  15. Jan 22, 2019 at 1:40 PM
    Tundra2times
    I am not concerned about mileage more the price. I ended up getting it and absolutely love it.
    Thanks
    georgiey22, chazzykaid and Trooper2 like this.
  16. Jan 22, 2019 at 1:44 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  17. Jan 22, 2019 at 1:45 PM
    Trooper2
    JR
    Aeesome!
