Strange - Passenger Side Window/Lock and Tailgate Lock Do Not Work
Discussion in '2.5 Gen Tundras (2014-2021)' started by 4Runner, Jan 9, 2019.
  1. Jan 9, 2019 at 9:10 AM
    4Runner
    4Runner [OP] New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Very strange. I had my Amp Research Steps installed on Friday. Drove home and then on Monday I noticed my passenger window will not roll up or down and the lock won’t work. Same for my tailgate. All other stuff seems to be working. I’m not sure how, but has to be related to the AMP Step install. I know the disconnected the battery as I lost all my radio stations. Any ideas?
  2. Jan 9, 2019 at 11:00 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Who installed it? Check relays? Check your connections to tailgate see if it got giggled loose
  3. Jan 9, 2019 at 11:07 AM
    timsp8
    NY
    Blown fuse?
  4. Jan 9, 2019 at 11:20 AM
    4Runner
    Columbia, SC
    4WP installed. It was a no tax and free install deal on the steps. Just pulled the negative, waited, and hooked up. Same result. Tailgate and passenger window and lock. How are these connected though? I might peek inside the lower kick panel since I know they tapped 2 wires in there. I'll check fuse panel on drivers side but sure seems like I would have more no working if it were fuse. Thanks for the replies.
  5. Jan 9, 2019 at 11:37 AM
    4Runner
    Columbia, SC
    Mission accomplished. In the lower kick panel passenger side, they knocked loose a connection. In my picture it is the lower blue connector. I reconnected and all is good.
  6. Jan 9, 2019 at 11:38 AM
    phabej
    phabej New Member
    Washington
    2018 Platnium
    Yay that's what I thought. Good job
