Truck pulling hard to the right at times
Discussion in '1st Gen Tundras (2000-2006)' started by jperez2396, Jan 8, 2019.
  1. Jan 8, 2019 at 7:32 PM
    jperez2396
    jperez2396 [OP] New Member
    Junior
    2002 Toyota Tundra limited 4x4
    hey everybody I’m new on here and just was wondering if anyone can help I have a 02 tundra limited and I’m having suspension problems I’ll be driving and sometimes all of a sudden the truck pulls HARD right and before it does the steering wheel will vibrate/jerk to the right only happens from time to time now I’m hearing some clunking noises seems from like the front left suspension I’m totally bamboozled at this point
  2. Jan 8, 2019 at 7:33 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  3. Jan 8, 2019 at 7:34 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Did you try searching for the topic?
  4. Jan 8, 2019 at 7:36 PM
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    Does it happen when you hit the brakes or just completely random? Does everything look normal in the front end?
    OR18TRD likes this.
  5. Jan 8, 2019 at 7:41 PM
    Welcome from NY.
    Pinay likes this.
  6. Jan 8, 2019 at 8:07 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Could be several things: ball joints, tie rod ends, brake components. Provide pics and more information and someone will be able to assist.
    Black Wolf and Pinay like this.
  7. Jan 8, 2019 at 8:12 PM
    Welcome. Wonder if it’s caused over small bumps in the road. Like a possible tie rod issue.
  8. Jan 8, 2019 at 8:13 PM
    @jperez2396 I kinda had same problem with my T100 turned out on of my CV axles busted loose on the outter end and the slots on the end of the CV axle we're catching the slots on the hub and was making the truck jerk to that side, are any of your CV axles boots busted?
  9. Jan 8, 2019 at 8:18 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    Welcome.
    Extra points for using the term bamboozled:cool::p
  10. Jan 8, 2019 at 8:21 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
    jperez2396[OP] likes this.
  11. Jan 8, 2019 at 8:22 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME.
  12. Jan 8, 2019 at 8:46 PM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  13. Jan 8, 2019 at 8:52 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    Welcome from East Tennessee
  14. Jan 8, 2019 at 9:40 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Check the ball joints.
    joonbug and jperez2396[OP] like this.
  15. Jan 8, 2019 at 9:50 PM
    jperez2396
    Junior
    Yes I forgot to mention my left cv axle boot is all busted
  16. Jan 8, 2019 at 9:54 PM
    jperez2396
    Junior
    No it doesn’t when I hit the brakes the only thing I see is my left cv axle boot is busted
    831Tun likes this.
  17. Jan 8, 2019 at 9:56 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Good place to start especially since Adam, @ARamirez73 said that could be it. Nice call Adam.
  18. Jan 8, 2019 at 10:00 PM
    jperez2396
    Junior
    But would the left one explain for it pulling to the right
  19. Jan 8, 2019 at 10:16 PM
    I'm trying to remember, but I believe the the right one was busted and the truck was jerking to the left, like a sudden violent jerk, I remember this happening from a work travel from Houston to Shreveport Louisiana and in that course it happened over a dozen times, I didn't know what was causing it, til I got close to Louisiana, I hit this bump and ther e wwasthis bad grinding noise, and what I think what happened was the CV axle got caught and was making truck go into wrong side of road, and I was trying to turn the opposite way and something popped, turned out it was ring that hold ball bearings
    OR18TRD likes this.
  20. Jan 8, 2019 at 10:17 PM
    Yeah it was a scary thing cause I was on my way to work late in the night
    831Tun[QUOTED] likes this.
  21. Jan 9, 2019 at 12:34 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  22. Jan 9, 2019 at 1:33 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona. Looks like your problem has been ID'd. Good Luck.
  23. Jan 9, 2019 at 1:54 AM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Welcome from Obx
  24. Jan 9, 2019 at 2:35 AM
    Welcome from Ohio!
  25. Jan 9, 2019 at 8:56 AM
    tenntundra
    Walter
    Tennessee
    Replacing the CV axles ate easy. I have replaced the on my 2000 tundra in about an hour
  26. Jan 9, 2019 at 10:57 AM
    jperez2396
    Junior
    Yeah it’s a real violent jerk to the right it’s scary as fuck and it happens randomly I’m starting to hear squeaky noise on the left side but when I do the steering wheel gets all shaky... thanks to all been a real big help!!
  27. Jan 9, 2019 at 11:33 AM
    I can almost bet that's the issue, replace CV axle
  28. Jan 9, 2019 at 11:43 AM
    @jperez2396 was it happening at highway travel only? Not on normal driving in city, that's how mine was doing, on the highway rarely on normal driving around town
  29. Jan 9, 2019 at 3:28 PM
    jperez2396
    Junior
    It does both but mostly on highways I’ve noticed
  30. Jan 9, 2019 at 5:30 PM
    Deslock23
    Deslock23 New Member
    2003 Tundra SR5 AC 4wd
    5100’s at 5th notch, Add-a-leaf, diff drop.
    Welcome! (I'm new too).
    Silly question, but have you lifted the front and seen if the wheel could physically shake? My $$ would be on a bearing or a CV as mentioned above.
