110v outlets in bed and console (write-up)
Discussion in '2.5 Gen Tundras (2014-2021)' started by AlmightyCrash, Jan 7, 2019.
  1. Jan 7, 2019 at 3:00 PM
    AlmightyCrash
    AlmightyCrash [OP] Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Hi everyone. I had a few people ask for a write up on this, so I’m happy to help....although there’s really not much to write up.
    The inverter I used was around $30 and claims to have a 500w-550w output from each of the two built in outlets. It also has two 2.1 usb outlets, but I didn’t utilize them for this project. I may extend them to flush mount ports at a later date.
    (Stock photo because I forgot to take photo before mounting it)
    I mounted it under the drivers seat with the outlets facing the center console. I ran a 8g ground through the floorboard and grounded it to the frame, then an 8g wire to the positive side of the battery.
    I chose this outlet for the back of the console mainly due to aesthetics and the fact that it adds USB ports. It also comes pre-wired with an extension cord to plug into the inverter.
    I went with a different shape for the one in the bed, but it comes prewired also...though I did need a single 6ft extension cord to reach the inverter.
    I taped off the outlets and bedlined it so it would blend in more.
    Even though my bedcover doesn’t leak, I am still designing a cover for the unit.
    I suggest removing the light and tailgate shock when cutting, just in case...so you don’t damage them.
    That’s really all there is to it, but I’m always happy to answer any questions.
  2. Jan 7, 2019 at 3:22 PM
    timsp8
    NY
    What brand are the outlets? Are they prewired to any inverter?
  3. Jan 7, 2019 at 3:39 PM
    AlmightyCrash
    Crash
    San Leon, TX
    I’ll find links for you, but they are both wired with standard three prong plugs. Round one has a 6ft cord. Rectangular one has a 9ft cord.
    OR18TRD and Jim LE 1301 like this.
  4. Jan 7, 2019 at 3:43 PM
    AlmightyCrash
    Crash
    San Leon, TX
  5. Jan 7, 2019 at 3:57 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
  6. Jan 7, 2019 at 4:01 PM
    Berdine
    Berdine Voodoo Sport
    Frank
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    That's awesome! Great job!
  7. Jan 7, 2019 at 4:09 PM
    timsp8
    NY
    Thanks. Nice job. Looks like it came there from Toyota. I’ve been meaning to do this for years. I think some tundras and sequoias came with an inverter and power outlet, but it’s overpriced. I was looking at a cobra professional 1500w or 2000w.
  8. Jan 7, 2019 at 4:12 PM
    AlmightyCrash
    Crash
    San Leon, TX
    No. It isn’t. Thats why I’m designing a cover for it, as stated...even though it’s out of the elements when my bedcover is closed.
    I searched for days to find an outdoor one that would fit in the bed that was more than a single outlet. I couldn’t find anything.
    Also, all outdoor units are open on the backside, which would leave everything exposed. This is a sealed unit.
  9. Jan 8, 2019 at 8:44 AM
    hpeeler
    hpeeler New Member
    Does the inverter have a switch on it?
  10. Jan 8, 2019 at 8:46 AM
    PinoyRN
    PinoyRN Manila Gorilla
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    Will this work with the truck off? Also, at what point do I need to think about a secondary battery...I already have AMP research steps and a rough country light bar hooked up to my battery.
  11. Jan 8, 2019 at 9:34 AM
    AlmightyCrash
    Crash
    San Leon, TX
    This one doesn’t, but there are those that do.
  12. Jan 8, 2019 at 9:38 AM
    AlmightyCrash
    Crash
    San Leon, TX
    Yes, this is hooked to constant power.
    Your steps only use power when extended, and light bar only when it’s on, so you should still be fine with one battery.
    I chose to install an in-dash voltmeter so I can see if the battery starts to drain and start the truck to charge it back up.
    Another option is to get a battery that is both a deep cycle and a starting battery. That type will help with running many accessories at once with the engine off.
    twistedcricket and TundraMash like this.
  13. Jan 8, 2019 at 9:54 AM
    PinoyRN
    Sammy
    Phoenix, AZ
    ‘06 Tundra
    Awesome, thanks for the info. I’m a newb when it comes to this stuff :boom:
  14. Jan 10, 2019 at 12:23 PM
    lamikela1
    lamikela1 New Member
    Michael
    2019 Silver Sky Platinum Tundra 4X4
    Revolver X4 cover, Bedrug, Pocket Flares. Previously owned... '86 Hilux, '94 4-Runner '95 Taco, '05 Taco
    Just keep in mind that for a 12V 2000W inverter at full load you will be drawing over 160 Amps. Better get the correct wire size or your truck will go up in flames. Also long runs may require even larger wire. Also this should be switched, key or panel switch, to protect the battery. Best case is that the inverter has a control lead that allows you to turn it on/off. Otherwise the switch would need to be rated the same as the wire.
  15. Jan 10, 2019 at 2:13 PM
    timsp8
    NY
    I didn’t think about the draw on the alternator. Guess I’ll go with 1000w or 1500w. I just wanted the bigger one to have the power if I needed it. Also just got the genesis dual battery kit in so it’ll be on it’s own battery. Cobra’s also have a power switch so they aren’t always on or on when the truck starts.
  16. Jan 15, 2019 at 11:58 PM
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    Did you add heated seats for the rear? What’s the switch on the sides of the cig lighter outlet?
  17. Jan 16, 2019 at 4:33 AM
    AlmightyCrash
    Crash
    San Leon, TX
  18. Apr 30, 2019 at 4:12 PM
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    So did you "disassemble" the inverter and just moved the outlets to the mounting locations?
  19. Apr 30, 2019 at 4:40 PM
    Berdine
    Frank
    Binghamton, NY
    No, he used extension cords and added new outlets
  20. May 8, 2019 at 9:26 PM
    Califspine
    Califspine Califspine
    Ron
    Bell Canyon, UT
    2020 1794 with TRD Pkg
    Almighty Crash, I ordered and just received the exact inverter you installed. My question is how did you mount/secure the inverter under the seat? Also, where did you breach the firewall for the positive lead to the battery?
  21. May 8, 2019 at 10:29 PM
    916tundra
    916tundra New Member
    Ken
    2017 Tundra Crewmax
  22. May 9, 2019 at 9:57 AM
    AlmightyCrash
    Crash
    San Leon, TX
    You can Velcro it to the carpet, and it won’t go anywhere.
    The 12v wire enters through the rubber grommet that all of the other factory wires come through.
  23. May 9, 2019 at 11:47 AM
    flinky14
    flinky14 If I'm the wife, who says no to new mods?
    Genna
    Alberta
    2019 Tundra CM Platinum 4x4
    -TRD Dual Exhaust - 3m - UV front window tint/rear limo tint -TRD Oil Cap -Toyota Bed Mat - TRD Pro Grille - ARE canopy (sliding Windoors, pop down sliding front window, headliner, rack rails) -OEM Toyota Remote Starter -Baja Designs Sport Fog Lights -TRD door sill protectors -Ronin Factory short antenna
  24. Jun 9, 2019 at 5:34 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    I simply plug an inverter similar to yours into the trailer hitch receiver wiring connector when I need 120v power to that area. With diagrams all over the internet showing the proper pins to use (12v positive & negative) for the various plugs (4-pin, 5-pin, 7-pin, etc), wiring the plug was super easy
    Since most of my power tools are cordless, I got it mainly for the two 120v air pumps (120v pumps are stronger & quicker than 12v) for my inflatable boat. However, I have used the inverter to power a few small shop tools (band saw, belt sander, etc) while on location. I've also used it for the air compressor when airbrushing (fishing lures, etc) at remote camp sites. When the inverter is not being used, it's tossed into the bed toolbox with my other tools.
  25. Mar 8, 2020 at 7:12 AM
    russellmoran
    russellmoran New Member
    Russell
    2018 1794 Tundra 4x4
    USB Ports, Linex, Aftermarket Su
    I want to get a 500W converter and add 2 of these grommet units (1 where you have it and 1 in the front seat somewhere). My question is, so I have to wire direct to the battery? Can I tap into wire from a cigarette lighter or similar? Mainly using it to charge my laptop on travel, etc... Thanks @AlmightyCrash
  26. Mar 13, 2020 at 10:39 AM
    russellmoran
    Russell
    I want to get a 500W converter and add 2 of these grommet units (1 where he has it and 1 in the front seat somewhere). My question is, do I have to wire direct to the battery? Can I tap into wire from a cigarette lighter or similar? Mainly using it to charge my laptop on travel, etc..just don’t want the catch fire using a smaller wire to get power. Thanks @lamikela1
  27. Mar 20, 2020 at 6:58 AM
    lamikela1
    Michael
    For 500 watts you would be pulling about 42 amps at full load. You would need a power source that has a number 6-8 wire size to be safe.
  28. Mar 20, 2020 at 7:04 AM
    russellmoran
    Russell
    Thanks so much. I created a new thread to ask questions. I’ve learned my inverter has two 40 amp fuses and my sub that is currently running power has 100amp. I’m needing 180 amp so I’m using a 1/0 gauge wire with a 300Amp in-line fuse then a power distributor to distribute power to both devices. There’s much more to it (relays, switches, etc) but that’s the jest of it. Thanks
  29. Mar 20, 2020 at 7:57 AM
    Bigolbaddy
    Bigolbaddy New Member
    Ben
    Fort Worth
    2020 MGM 1794
    What paint did you use/find that bedlined the outlet. I need to do that for something else. Thanks
  30. Mar 22, 2020 at 2:14 PM
    lamikela1
    Michael
    Ok. Sounds like you are on the right track.
