Healight assembly set
Discussion in '2nd Gen Tundra Parts Marketplace (2007-2013)' started by Emire221, Sep 10, 2018.
Thread Status:
Not open for further replies.
  1. Sep 10, 2018 at 4:01 PM
    Emire221
    Emire221 [OP] New Member
    NJ
    Set of headlight assembly come with bulbs installed. Asking $75
    Stormtrooper81 likes this.
  2. Sep 14, 2018 at 8:33 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I might be interested in these. My left one is all full of condensation. What did you replace them with, are there good newer options available. Thanks. New to the updating is why I ask.
    Emire221[OP] likes this.
  3. Oct 30, 2018 at 1:07 PM
    LAWNKILLER
    LAWNKILLER New Member
    Andy
    KC
    2010 Crew Rock Warrior
    Are these still available? What yr do these Fit? In cab adjustment?
  4. Oct 30, 2018 at 1:09 PM
    Emire221
    NJ
    Hi these came off a 2007 limited CM. Does not have the in cab adjustment. Theu should fit all second gen tundras.
  5. Nov 29, 2018 at 12:06 AM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    What did you plug in their place if you don’t mind?
  6. Jan 3, 2019 at 11:36 AM
    lsumatt1514
    lsumatt1514 New Member
    2008 Tundra Crewmax Limited
  7. Jan 3, 2019 at 11:39 AM
    Emire221
    NJ
    Yes they are
  8. Jan 3, 2019 at 11:58 AM
    lsumatt1514
    Are they a genuine, OEM Toyota part? Anything broken on them? I am strongly considering an LED projector retrofit for my truck, and I'm going to need a spare set to use while mine are getting retrofitted...which could be close to 6 weeks. Thanks!
  9. Jan 3, 2019 at 12:01 PM
    Emire221
    NJ
    Yes they are original headlights
  10. Jan 3, 2019 at 12:05 PM
    lsumatt1514
  11. Jan 5, 2019 at 2:52 PM
    Emire221
    NJ
Thread Status:
