eBay "OEM Style" Running Boards - Can anyone vouch for these?
Discussion in '2.5 Gen Tundras (2014-2021)' started by JNome, Jan 3, 2019.
  1. Jan 3, 2019 at 8:38 PM
    JNome
    JNome [OP] New Member
    Jake
    Michigan
    2018 Tundra Crewmax SR5 Cement
    Hello all. So I'm currently looking for a set of factory running boards for an 18 Crewmax. I found these on eBay and while not genuine Toyota they look like the right part. Was wondering if anyone can vouch for a set of eBay OEM style running boards like these in terms of quality? Thanks!
    https://www.ebay.com/itm/For-07-18-Toyota-Tundra-Crew-Max-Cab-Black-Nerf-Bar-Side-Step-Running-Boards-Set/182689066362?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=a3f244521e5e4f6fbfb762a10deafb65&pid=100675&rk=2&rkt=15&mehot=lo&sd=202535887781&itm=182689066362&_trksid=p2481888.c100675.m4236&_trkparms=pageci:793aff25-0fd9-11e9-9800-74dbd1806939|parentrq:172081051680aa487005f631ffec5085|iid:1
  2. Jan 3, 2019 at 10:38 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I’d check your local craigslist first. I see OEM take offs like those all the time for cheap.
    Personally, I went a different route with RCI Off-road side steps but they are admittedly a little more than the OEM style.
    Good luck with your search!
    B737 likes this.
  3. Jan 4, 2019 at 9:38 PM
    Danny
    Danny New Member
    I would highly suggest you avoid unfamiliar brand knockoffs. I installed the iboards bought off eBay, sent it into the dealership for some work, got it back a week later, decided to return the boards for oem boards and found rust in the bolts and mounts. Then there’s the hassle to return them and get the seller to pay for the return label which cost as much as the boards itself. Stick with oem or highly reputable quality ones
  4. Jan 7, 2019 at 2:09 PM
    plumber802
    plumber802 New Member
    Andy
    Florida/Vermont
    2018 White Platinum CM
    You usually get what you pay for...
  5. Jan 7, 2019 at 6:17 PM
    JNome
    Jake
    Michigan
    I agree. I’ll be keeping my eye out for a set of OEM takeoffs someone is looking to sell but for the time being these will do. Up here in Michigan they salt the crud out of the roads and I really just want something the help keep the grime off and help prevent rock chips for the time being.
  6. Jan 8, 2019 at 2:26 AM
    plumber802
    Andy
    Florida/Vermont
    10-4 on the salt. Stainless steel holds up well.
