  1. Dec 30, 2018 at 8:53 AM
    #2971
    Casper421
    In the woods
    06 DC
    New serpentine belt?
  2. Dec 30, 2018 at 8:55 AM
    #2972
    Professional Hand Model
    Fred
    Hand Protectors
    Thats when mine started. Only squealed during high humidity when engine was first started. Has gotten better over 40k miles but still pops up sometimes. The belt dressing spray helps, but is temporary.
  3. Dec 30, 2018 at 8:58 AM
    #2973
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Depending on the mileage it might be worth replacing the tensioner and idler pulleys.
  4. Dec 30, 2018 at 9:16 AM
    #2974
    Fred
    Hand Protectors
    Good call. This will happen on the next go around in about 30k miles.
  5. Dec 30, 2018 at 9:54 AM
    #2975
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    It's true. Same with my 03 taco
  6. Dec 30, 2018 at 9:57 AM
    #2976
    because_wumbo-truck
    Jon
    Houston, Texas
    No it's the same one as when I bought the truck. It looks fine and is a Toyota belt. I started noticing the squealing when it got cold. I think it's a pulley bearing or something in the right side of the belt system. I sprayed some lubricant on the few pulleys I could reach in there and it helped for like an hour then the squeal came back and I've tried several times since to lubricate to no avail. I'm at my wit's end with it because it's so loud and gets louder as I give it more gas.
  7. Dec 30, 2018 at 9:58 AM
    #2977
    because_wumbo-truck
    Jon
    Houston, Texas
    So o got some belt spray. How do you generally apply it? I can't really reach the belt in most spots
  8. Dec 30, 2018 at 9:59 AM
    #2978
    because_wumbo-truck
    Jon
    Houston, Texas
    You're probably right. I have 205k
  9. Dec 30, 2018 at 10:44 AM
    #2979
    Fred
    Hand Protectors
    Aim and shoot. Its a spray can with a straw. Do it with engine off because the rad fan will blow your stream off course if engine is on.
  10. Dec 30, 2018 at 11:39 AM
    #2980
    because_wumbo-truck
    Jon
    Houston, Texas
    Do you spray both side of belt? Do you soak it?
  11. Dec 30, 2018 at 11:45 AM
    #2981
    Fred
    Hand Protectors
    Aim for the inside slotted parts. Won’t hurt if it goes on the other side. Doesn’t need soaking. This, again, is a temporary solution. Only lasts for a few days max.
  12. Dec 30, 2018 at 11:46 AM
    #2982
    ethan1911
    ethan1911 I’m one of those regular weird people
    Black 2006 tundra double cab
    Dana 44 sas, 63” Chevy springs, shackle flip, 4.10 gears
    088057F2-23EC-4D4F-AA3F-6724FE30C965.jpg Pulled off my camper shell and snorkel and started a little body work. Hopefully I’ll be ready for a nice paint job soon.
  13. Dec 30, 2018 at 12:06 PM
    #2983
    Very busy day. Washed truck yesterday. Waxed today. I have the chalky paint notorious in early Gen1s, especially white ones. Toyota really shit the bed on painting some of these. I'm lucky that the PO took good care of this one or the paint would look horrible.
    Also installed new fog bulbs. Went with Sylvania Silverstar. The old bulbs actually look pretty good so I may not see an improvement.
    Also removed the front grill and painted it. It turned out good, not great. There were a few places where the grill told paint to piss off. It wouldn't adhere completely. I'll post more pics in a bit.
    Oh, and I partially broke the safety latch for the hood. Having a hard time locating that part#
  14. Dec 30, 2018 at 12:13 PM
    #2984
    Valler
    Valler New Member
    Ramon
    Daily driven 2000 toyota tundra
    16in M/T wheels with a 305 70 r16 tire 3in space lift front add a leaf in rear Led headlights upgrade OEM fog light delete replaced with 7in light bars in OEM locations Led interior lights and tag lights and cargo lights also Kenwood double din head unit self powered subwoofer under driver's seat
    So my tundra died today I was driving down the hwy and going around 55 to 60 and it just died, helps guys to diagnose the problem, turns over but wont start, sounds like its farts at times when trying to turn it on
  15. Dec 30, 2018 at 12:21 PM
    #2985
    ethan1911
    My truck did this once I pulled my battery cables off for about 30 min then hooked them back up and it ran fine. Don’t really know what caused it and it Hasn’t done it since.
  16. Dec 30, 2018 at 12:53 PM
    #2986
    Fred
    Hand Protectors
    Was looking at the vivvid stuff the other day which lead me to 3M which costs more and from the reviews is a little (emphasis) easier to put on. Either one requires some skill. I started some research after you had brought up wrapping some interior items. The carbon wrap stuff looks cool. Especially, any colors with a matte finish like your roof. Only drawback I saw was the 5-7 year useful life on the wrap.
    potoghi[QUOTED] likes this.
  17. Dec 30, 2018 at 12:57 PM
    #2987
    Outbound
    Aaron
    Northern Alberta
    Took the ol' girl out for a spin in the snow today. Gave the 4wd a workout as I haven't used it much in a few months. Gotta say again...4x4 + studded Nokian Hakkapellitas = glacier climbing.
    I did however officially add "get the fucking steering wheel straightened" to my to-do list. I got an alignment done when I had the 5100's installed. The truck track excellent, numbers are good blah blah blah. But my steering wheel is a few degrees off level. When I level the wheel out, the truck pulls to the left. I took it back to the shop a few days after the alignment and they "straightened" it. Didn't do shit imho. Been too busy to really have a go at it since then.
    I finally got pissed off with it enough today. It bugs the hell out me. I spent some time online but it doesn't look like a simple job to just pop the steering wheel off, and straighten it out. Going to have to take it to a different shop and be a pain in the ass OCD owner I guess. Probably mark where I want it, specify not to correct for road crown and tell them to expect me to be a pain. LOL
  18. Dec 30, 2018 at 1:09 PM
    #2988
    Fred
    Hand Protectors
    Put the first coat of red highlighting on the side trim. 2 more coats to go. Subtle is the goal.
  19. Dec 30, 2018 at 1:20 PM
    #2989
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    But for the price, the years it will last is worth it. The one i got came from here https://www.amazon.com/gp/product/B00L9JAUOC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 Wrapping the car also helps protect the paint from fading and keeps it fresh under the wrap.
  20. Dec 30, 2018 at 1:28 PM
    #2990
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    sweet ride man.
    ethan1911[QUOTED] likes this.
  21. Dec 30, 2018 at 1:43 PM
    #2991
    Here are a few more pics with the grill installed. I must say, I'm quite pleased. Now I just need to decide what to do with the rest of the bumper and trim. I can't decide if I want to leave the chrome or try to plasti dip it. I used Meguiars Ultimate Black on the trim today. It's a decent temporary fix.
  22. Dec 30, 2018 at 1:58 PM
    #2992
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    I'm not a fan of chrome but your chrome bumper looks really clean and suits the truck nicely. Also, the grill looks great. But if you paint the bumper I'd say paint all the other chrome parts too so it all matches together nicely
  23. Dec 30, 2018 at 2:03 PM
    #2993
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    I have the same issue. May have happened while driving in CA and being pissed off at the toll roads and running into a curb while trying to U turn... :rolleyes: (btw, we need the whistling emoticon added to our list).
  24. Dec 30, 2018 at 2:26 PM
    #2994
    Could it be the alternator?
    Valler[QUOTED] likes this.
  25. Dec 30, 2018 at 2:32 PM
    #2995
    Valler
    Valler New Member
    Ramon
    I will have to take it off and get it tested to check, because before the interior dome lights would flicker to the rhythm of the blinker, also would be dimmed and if I gave it gas in park they would brighten up, so could be alternator, I'll just have to work on it over the new year day off
    Always had 18v for battery when the truck was on already never dropped
  26. Dec 30, 2018 at 3:53 PM
    #2996
    Fred
    Hand Protectors
    Swapped the Clear 3157LL side marker bulbs over to Amber Color to complete the look. The clear bulbs blended to much into the headlamp lights and did not provide much distinction when at a straight on angle. The new bulb number is 4157LL per the auto store computer. Very happy with it all. Pic below is Clear bulb on passenger side and Amber on the drivers side. Looks more distinct in person.
    Bought a new Milwaukee LED work light for Christmas. Its the cube style with a clamp and magnetic catches. The lens swivels.
    ethan1911, bmf4069, Darkness and 3 others like this.
  27. Dec 30, 2018 at 4:06 PM
    #2997
    Fred
    Hand Protectors
    How many miles you have on your truck? I heard our alternators are good for around 200k miles. Hope you get it worked out.
  28. Dec 30, 2018 at 4:20 PM
    #2998
    Looks great. Are these them?
  29. Dec 30, 2018 at 4:31 PM
    #2999
    Valler
    Valler New Member
    Ramon
    Just hit 171k
    Went to go pick up some work tools for tomorrow went to try go crank it, and it got weaker to crank like if the battery is going dead on it
  30. Dec 30, 2018 at 4:32 PM
    #3000
    Mike Tread lightly.
    south carolina
    2003 tundra sr5 4x4 stepside....
    yep bank account is running low from it..
    157xxx when mine went out... diodes where leaking on mine ..
