  1. Dec 26, 2018 at 6:31 PM
    #2881
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I wonder if it started in 04 when they added the DCs?
    Filthyphil[QUOTED] likes this.
  2. Dec 26, 2018 at 8:31 PM
    #2882
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    That very well could be, interesting none the less.
  3. Dec 26, 2018 at 8:42 PM
    #2883
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    My 03 will start with just a bump.
    Jerry311SD and Casper421 like this.
  4. Dec 26, 2018 at 9:20 PM
    #2884
    My 02 doesnt. It gets mad when you try then doesnt want to start.
    Sunnier likes this.
  5. Dec 27, 2018 at 6:35 AM
    #2885
    I'm glad someone else mentioned this. If I short stroke my 02 and then immediately try it again, she gets angry. I let it sit for a few seconds before trying. It's interesting that others can bump it.
    Filthyphil likes this.
  6. Dec 27, 2018 at 8:03 AM
    #2886
    Professional Hand Model
    Fred
    Hand Protectors
    Still haven’t reconfirmed the confirmation of the bump start, but will say that I can confirm what the 02’ guys have said based on past experience.
    In our case, its better to ‘over start’ the starter than to bump it and have it angry at you.
    I count quick 1-2- start! in my head when turing the key.
  7. Dec 27, 2018 at 11:01 AM
    #2887
    hammeron
    hammeron New Member
    2002 Tundra v8 Blue 2wd
    Regarding the "bump start"......my 2004 AC does the bump start, my 2002 AC does not....it's a cool feature, but i'll survive without it in the '02.
  8. Dec 27, 2018 at 12:54 PM
    #2888
    Fred
    Hand Protectors
    Confirmed. The 02’ doesn't bump start. In fact, it hates a quick bump which sends the starter spinning for a couple seconds without any simultaneous engine ignition turn.
    Conclusion: Stick with turn and hold (1-2-start) method on the 02’.
    Bulbs and lamps housings came today!
    Filthyphil, Sunnier and FirstGenVol like this.
  9. Dec 27, 2018 at 1:52 PM
    #2889
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Post a pic!
  10. Dec 27, 2018 at 3:57 PM
    #2890
    2nd attempt at replacing the power steering fluid using the turkey baster method. I don't know where you guys are finding a baster but I still can't manage to find one skinny enough to really reach down in there.
    This is all I was able to get out. That fluid looks dirty. I guess I'm going to jack it up this weekend and do that method instead.1227181811.jpg
    Rheywood456 likes this.
  11. Dec 27, 2018 at 3:58 PM
    #2891
    Fred
    Hand Protectors
    Take a pic of your reservoir.
  12. Dec 27, 2018 at 3:59 PM
    #2892
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Yeah it’s a skinny hole. Maybe use the straw method? :D
    Jk. Let me know which way you go. That’s on my next few month list of things to do.
  13. Dec 27, 2018 at 4:18 PM
    #2893
    Did you happen to replace the glove box bulb? It's not easy to get out. I got it out and realized I don't have the right bulb. Not even sure they make an LED that small.
  14. Dec 27, 2018 at 4:20 PM
    #2894
    Festerw
    Festerw New Member
    04 Tundra DC
    because_wumbo-truck likes this.
  15. Dec 27, 2018 at 4:21 PM
    #2895
    Fred
    Hand Protectors
    Gotta order it. T10 bulb. 10 packs run about $12. Same bulb for footwell above parking brake. You can use the remainder for your instrument/climate panels.
  16. Dec 27, 2018 at 4:22 PM
    #2896
  17. Dec 27, 2018 at 4:24 PM
    #2897
    Fred
    Hand Protectors
  18. Dec 27, 2018 at 4:25 PM
    #2898
    Are they worth it? I can live with limited glove box light unless it's a huge improvement.
  19. Dec 27, 2018 at 4:27 PM
    #2899
    Fred
    Hand Protectors
    I think they are for a small $ amount. Plus you can use the rest on the footwell and control panel as they are required there.
  20. Dec 27, 2018 at 4:34 PM
    #2900
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    This is the tool for you! I picked one up for Xmas. When I changed my leafs out I had to remove the upper Shock mount for some extra droop. Takes forever with a open end wrench.
    This allows one hand to hold the shaft, and one to tighten / loosen the top nut.
  21. Dec 27, 2018 at 4:35 PM
    #2901
  22. Dec 27, 2018 at 4:38 PM
    #2902
    Fred
    Hand Protectors
  23. Dec 27, 2018 at 4:42 PM
    #2903
    Casper421
    In the woods
    06 DC
    Got home from work and more goodies arrived:
  24. Dec 27, 2018 at 4:43 PM
    #2904
    Sunnier
    Sunny
    San Diego, CA
    Alright. My idea would be, either hit up a specialty chef supply store (or Amazon) for a small tipped baster... OR... they make syringes with long flexible tubes on the delivery side for administering fluid meds to human babies or animals (sublingual)... I'd guess vet supply would have best sizing for your planned use (longest tube, largest syringe volume.
  25. Dec 27, 2018 at 4:43 PM
    #2905
    Fred
    Hand Protectors
    Beefy springs.
  26. Dec 27, 2018 at 4:48 PM
    #2906
    Sunnier
    Sunny
    San Diego, CA
    Like this one even mentions 'motoring applications' so I'm not the first one to think of this. A good sign.
    https://www.ebay.com/p/Large-Plasti...3%26rvr_ts%3Df246770b1670a9c4a1f0316dffde07b1
  27. Dec 27, 2018 at 4:51 PM
    #2907
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Oh yeah baby!
    Too bad you’re not closer, I’d lend a hand with the install since I just did mine
  28. Dec 27, 2018 at 4:56 PM
    #2908
    Fred
    Hand Protectors
    Here is what my ‘baster’ looks like. Had to go look to remember. Auto stores have them. Mine was a .50c garage sale find.
  29. Dec 27, 2018 at 4:57 PM
    #2909
    Casper421
    In the woods
    06 DC
    I used some vinyl tubing to siphon the fluid into a catch can.
  30. Dec 27, 2018 at 5:00 PM
    #2910
    Casper421
    In the woods
    06 DC
    Any tips would be greatly appreciated. I’ve never replaced leaf springs, only coils. Seems pretty straight forward though.
