Rear sway bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ol' Salty Dawg, Dec 26, 2018.
  1. Dec 26, 2018 at 9:49 AM
    Ol' Salty Dawg
    Ol' Salty Dawg [OP] New Member
    2017 Tundra 2WD XSP-X
    I just bought my 2017 XSP-X 2 weeks ago. It does not have the rear sway bar. Is this something I should get or can I do without? If I do need it should I just get the TRD sway bar?? My truck is a DD, not towing and mostly highway driving. Thanks
  2. Dec 26, 2018 at 9:54 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    It helps with handling. It lessens the roll of the truck when turning and when taking on/off ramps.
  3. Dec 26, 2018 at 10:39 AM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Good for road use
    Rica25, 15whtrd and Stormtrooper81 like this.
  4. Dec 26, 2018 at 10:45 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    On turns and lane changes, increased anti-left/right body roll is commonly preferred over looser independent articulation unless one rock crawls and those are 4x4’ers. It’s a noticeable improvement in ride quality for most people and well worth it for DD pavement Tundras. You actually notice your shoulders rocking less.
    There is a rear TRD one where there was none. And there is a thicker/heavier TRD front one, if you want to replace the stock lighter front sway bar too.
    15whtrd likes this.
  5. Dec 26, 2018 at 10:58 AM
    Ubnpast
    Ubnpast New Member
    I got the trd and noticed some enhanced stability.
    Stormtrooper81 likes this.
  6. Dec 26, 2018 at 11:29 AM
    SweetWaterSurprise
    SweetWaterSurprise New Member
    NJ
    Platinum
    I installed the thicker front TRD sway bar and TRD rear sway bar on my Platinum. Haven't driven much since I put them in so I can't tell you how much of a difference they have made.
  7. Dec 26, 2018 at 4:32 PM
    Ol' Salty Dawg
    Thanks for the reply's, now where would be the best place to get it? I have priced around a bit and some Toyota dealer keeps popping up for over $200.
  8. Dec 26, 2018 at 4:58 PM
    Blueknights75
    Ron
    Clayton, NC
    @Roman can help you get one. With a 2WD Tundra it should be a must. Not sure why everybody with 4WD gets them installed as it limits the off road capabilities but if mine was 2WD, this would be one of the first things I would install.
  9. Dec 26, 2018 at 7:07 PM
    JeremyGSU
    JeremyGSU New Member
    Jeremy
    2016 Tundra
    These are my observations:
    I've had my '16 SR5 Crewmax 4x4 since 9700 miles. It now has near 48k on it and I installed the TRD rear sway bar at 46k.
    I mostly do street/highway driving.
    I always felt the truck rolled pretty badly when going around corners. I added the rear bar and the truck feels much tighter in the corners now. Not only that but it seems to have tightened up the straight line tracking as well. It was always pulling badly to the highway before with the tires even with alignments. Now it tracks much straighter.
    The only negative I've found is it makes the rear ride a tad stiffer. Depending on the road service it can feel a little choppy because you are linking the sides more together. I am hyper sensitive to how a vehicle rides so I avoiding getting the bar for a long time because I didn't want to sacrifice any ride quality but I got sick of the sway. Overall, I say it's worth it.
    Ol' Salty Dawg[OP] likes this.
  10. Dec 26, 2018 at 7:09 PM
    I installed one and am very happy I did.
    Rica25 likes this.
  11. Dec 26, 2018 at 8:11 PM
    Mannishboy
    Mannishboy New Member
    Indianapolis, IN
    2015 DC 4x4 Limited, Blue Ribbon Metallic.
    TRD exhaust, TRD cai, TRD rear sway bar, TRD shift knob, Sequoia front sway bar, bed extender, bed step, Weathertech floor mats and window vents, spray in bed liner, Morimoto fogs, Access tonneau bed cover.
    I have the trd rear sway and the sequoia front sway. Coupled with Michelin Defenders LTX and I love the ride. Big difference. This is my pavement DD. My bilstein 5100’s are in the garage. I would think I’ll be even happier when I get those installed as well. I don’t have the trd suspension.
    Rica25 likes this.
