Rope tie downs
Discussion in '1st Gen Tundras (2000-2006)' started by Klingon4x2, Dec 24, 2018.
  1. Dec 24, 2018 at 11:34 AM
    Klingon4x2
    Klingon4x2 [OP] New Member
    2006 Tundra 4x2 Double Cab
    None
    My first truck was a 1989 Nissan SE-V6 4x4. It was a pretty good truck. I really like the pop-up rope tie down the SE-V6 came with. Does anyone know if there is anything like that for a 06 Tundra?
  2. Dec 24, 2018 at 11:38 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  3. Dec 24, 2018 at 11:38 AM
  4. Dec 24, 2018 at 11:56 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    There are only four tie downs in each corner so I added a couple to the middle of my 8' bed. These unscrew from the base in case you ever needed to remove them. I mounted them off to the side so I can still carry a 4'x 8' sheet. IMG_2623.jpg
  5. Dec 25, 2018 at 8:14 AM
    bmf4069 Captain wtf
    That unistrut one is cool. Then you can use 3/8 springnuts with eye bolts to put it where you want.
    jeffw6236 and BestGen like this.
  6. Dec 26, 2018 at 8:45 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    jeffw6236 likes this.
  7. Dec 26, 2018 at 9:09 AM
    I don't see why not. You may just have to adjust the sizes and mounting locations.
