Any Platinums with 6100's/5162 Setup with Stock 20" Wheels?
Discussion in '2.5 Gen Tundras (2014-2021)' started by boomer8, Dec 13, 2018.
  1. Dec 13, 2018 at 7:12 AM
    boomer8
    boomer8 [OP] New Member
    Evan
    Cincinnati
    2018 Platinum
    I have a 2018 Platinum and I have ordered and received Bilstein 6112's for the fronts and 5160's for the rear. I plan to run these at the 1.9" leveling setting and a 1" shackle in the rear. Is anyone running a similar setup with the factory 20" wheels?
    If so, what tires did you go with and can you please add a picture?
    I ordered 1.25" Spidertrax spacers to but am not sure if I am going to use these or not. I have done a ton of searching without luck of finding anything similar to this setup.
    Any help is appreciated!
  2. Dec 13, 2018 at 7:50 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    I think the factory platinum wheels are 20x8 with a +60mm offset. If so, then you could fit a 285 width for sure....or maybe a 295. go with either a 285/60/20 or a 295/60/20. if you use wheel spacers, then get whatever size tire you want :)
  3. Dec 13, 2018 at 1:44 PM
    boomer8
    Evan
    Cincinnati
    2018 Platinum
    Thanks for the tips. Id love to see some pictures as most of what I have seen with this setup are running 18"s and im afraid of having "too much wheel"
  4. Dec 14, 2018 at 12:46 PM
    kcmatt
    kcmatt New Member
    2018 WHITE PLATINUM TUNDRA
    TRD DUAL EXHAUST
    Went with Fox 2.0 coilovers front and rear. Toyo 275/65/20 tires on stock platinum wheels. Had to trim skid plate slightly.
    boomer8[OP] and mattyd170 like this.
  5. Dec 19, 2018 at 9:04 AM
    boomer8
    Evan
    Cincinnati
    2018 Platinum
    Appreciate the help on this. I ultimately decided to go with SR5 TRD wheels powder coated with the TRD Center Caps. Now to select the tire!
  6. Dec 19, 2018 at 12:45 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I have a 3/2 with 285/65/20’s. Offset is +18 with wheels. Only had to trim front well where small flap is or where it was.
  7. Dec 19, 2018 at 3:32 PM
    cpc0812
    cpc0812 New Member
    Cory
    2018 Cement 4 X 4 CM
    How much lift did you get with the Fox 2.0? Did you adjust them before putting them on or just out of box and installed?
  8. Dec 23, 2018 at 4:56 AM
    Ubnpast
    Ubnpast New Member
    Platinum here stock wheels, stock tire size. 2.5 in front with the 6100s and actually got 2" in rear with toytec shackle at top setting with 5160s. The ride is really nice, I was worried about harshness at the top setting; not at all an issue.
  9. Dec 24, 2018 at 11:35 AM
    tanabersx
    tanabersx New Member
    Miguel
    Puerto Rico
    2017 Tundra DC SR5 XP
    Planning on going this route 6112's set at 1.9" front and 5160's w/ 1.5" toytec shackle. like the way it looks.
