  1. Dec 22, 2018 at 8:56 AM
    T-Rex266 [OP] Owner, CTO and executive chairman of X Staff Member
  2. Dec 22, 2018 at 9:19 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    That suck!
  3. Dec 22, 2018 at 10:23 AM
    Twofer
    Twofer New Member
    Gary
    Pacific NorthWet
    2018 Silver 4x4 Tundra, 2000 red Tundra TRD
    Aw SHIT! Hope it wasn't hit and run. Your pic is kind of ironic with a Geico ad in the background.
    Sas, Kilos and WolfPac_Outdoors like this.
  4. Dec 22, 2018 at 10:23 AM
  5. Dec 22, 2018 at 11:00 AM
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    Nice looking truck. How are you liking the stage 6? How does it ride? Looking at the stage 4 currently.
  6. Dec 22, 2018 at 1:24 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
    Update: :( found oil on both side of engine (cam tower leaking) ..... guess I will be contacting Toyota after the new year to see if this is covered.
  7. Dec 22, 2018 at 1:55 PM
    trainracer
    trainracer New Member
    pop n lock for the tailgate and did the trd bezel for my rigid fog lights
  8. Dec 22, 2018 at 2:19 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I wasn’t pleased with first paint job on the grill surround, so I redid it and did the bumper caps too. All chrome gone except exhaust. :)
    This is much more acceptable.
  9. Dec 22, 2018 at 2:22 PM
    JohnsonANDjohnson
    JohnsonANDjohnson Jfabick277
    2015 sr5 Black crewmax 5.7 A.K.A Big Tex
    6inch block lift Iron cross rear and front bumper Nitto trail grapplers 35x12.50 Stock rims powder coated black Warn 10k winch Retro customz rock lights
    Got my ronin bullet antenna today but couldn’t figure out how to get this out of where my antenna slot is now. Any ideas? Already tried a flat head screwdriver
  10. Dec 22, 2018 at 2:32 PM
    easleycrawler
    Travis
    Easley, South Carolina
    19 TRD SPORT CM MGM 4WD
    Vise grips.
  11. Dec 22, 2018 at 2:44 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    X3 vice grips
    JoshuaA and NewImprovedRon like this.
  12. Dec 22, 2018 at 3:15 PM
    stewtopia
    stewtopia 4RunningTundra
    Stew (nickname)
    Masshole
    Indy got the Rough Country rear LED bumper for Christmas. Can't wait to put it on.
    ~Stew
  13. Dec 22, 2018 at 3:51 PM
    AlmightyCrash
    Crash
    San Leon, TX
    Bedliner.
    But not the heavy thick-textured stuff.
    Rattle can.
    NewImprovedRon likes this.
  14. Dec 22, 2018 at 4:19 PM
    AlmightyCrash
    Crash
    San Leon, TX
    I’ve used them all, so maybe I can help.
    Duplicolor (blue can) is the best if you can find it. Layer nice, even coat, and then press the nozzle halfway until it starts spitting heavy droplets...aim above what you’re painting and let the droplets fall on the previous coat while still tacky. It gives a beautiful droplet texture.
    Duplicolor (Black can, new formula) doesn’t texture quite as well, but goes on evenly. My biggest issue is that it ISNT BLACK. It’s fine if standing alone, but if it’s next to something black, it will look gray. It’s dark, just not as black as it could be or used to be. ALSO AVAILABLE IN CLEAR AND WHITE.
    Duplicolor Bed Armor (Kevlar) is jet black and textures well from the can, but is water based...do not use this if there is high humidity, fog, or chance of rain. It takes the longest to dry, but is the strongest. PAINTABLE
    Rustoleum will give the smoothest texture, and is great for trim pieces and areas that don’t come in contact with much. It is also the most likely to peel/scrape off.
    Herculiner sprays and adheres well, but not many places carry it...so if you are doing a big project it may be difficult to find enough of it.
    Krylon is newer and this was my first time to use it. It goes on in the most beautiful, even texture, and most closely resembles plastic bumpers, fender flares, etc. After spraying it, go back over and lightly dust it with the spray to perfect any heavy areas that look darker.
    THIS IS WHAT IS ON MY SURROUND AND BUMPER CAPS.
    porkitt, Boerseun, Watt maker and 3 others like this.
  15. Dec 22, 2018 at 5:48 PM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    Interior LED swap today.
    Went with the jdm astar. Easy swap. Much brighter.
    No fuses blown or other self-imposed headaches. Woot.
    Sas, tgo, JoshuaA and 1 other person like this.
  16. Dec 22, 2018 at 6:40 PM
    AlmightyCrash
    Crash
    San Leon, TX
    Got the bulge lights wired up.
    GAknight, FowlhookDE, Sas and 8 others like this.
  17. Dec 22, 2018 at 6:43 PM
    TokerJoker
    Travis
    Nowhere, Specific
    None.....yet
    man you should use some vise grips like they said!
  18. Dec 22, 2018 at 7:21 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Looks great! I have the same 17” Icon Rebounds and size tires, except mine are the Cooper Discoverer XLTs. I have Bilstein 6112s at the 1.9” setting and completely removed the front plastic from the bumper and no rubbing. I plan to cut the plastic liner and refit it back on to protect the fog light housing from mud and splash, but so far so good with the fog lights after a few months now.
  19. Dec 22, 2018 at 7:30 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
  20. Dec 22, 2018 at 7:36 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    ryanwgregg likes this.
  21. Dec 22, 2018 at 8:11 PM
    JohnsonANDjohnson
    :rofl::rofl::rofl:I'll try that
  22. Dec 22, 2018 at 8:36 PM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    Better than a stretched out metal coat hanger.
  23. Dec 22, 2018 at 9:08 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I wrapped my steering wheel trim pieces to match the rest of my interior dash. I think I’m going to paint the silver volume button black. 455AF1E7-90C2-4037-BD8D-9C6CDD9CA128.jpg
  24. Dec 23, 2018 at 7:08 AM
    Degausser
    Degausser New Member
    Kevin
    GA
    2024 LR SR5
    Started this yesterday, but it got dark on me, so I finished this morning. Installed Spyders with Morimoto HID kit. I'm in love.
  25. Dec 23, 2018 at 8:57 AM
    Degausser
    Kevin
    GA
    2024 LR SR5
    Took the boat out with the old man.
  26. Dec 23, 2018 at 9:30 AM
    rt_tundra_co
    rt_tundra_co I'll get tired of tweaking this truck...never
    '15 SR5 CM TRD
    Magnaflow cat-back exhaust Leer Topper, color matched to truck Thule Aeroblade roof rack on topper FABTECH 4” Suspension Lift Decked Storage, 2 drawer SPYDER LED headlights and taillights kits Hertz HDP5 5 Channel Class D Amplifier 2 x 10” subwoofer boxed behind rear seat Door speaker upgrades by Elite Auto Sound Colorado Springs Lock’er Down EXxtreme Console Safe LD2043EX Lock’er Down rear seat 3 x safes Lock’er Down gun magnet 80 LED in-grill light bar Baja Designs LED ditch lights TRD Pro grill Rotiform SIX-OR 20x9 wheels 35x12.5R20 Toyota Open Country R/T tires TheSource sPOD power control hub with in-cab installed accessory switches Firestone Ride Rite air suspension system with Air Command remote, on board compressor and rear bumper air port SDHQ rock sliders
    This is great because I have a worn out green vinyl wrap on my Tundra and I'm waiting for good weather and time to remove it. I have the same dark metallic grey under the wrap and I want to leave/re-wrap the chrome elements matte black. This is great inspiration for what the final product would look like. Looks great!
    AlmightyCrash[QUOTED] likes this.
  27. Dec 23, 2018 at 10:02 AM
    UTAHRTK
    UTAHRTK New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    You know when you think you got it - making it through a really tight area... I didn't make it. It made me sick.IMG_4454.jpg Getting estimate on 26th and then taking it to Mossy Toyota Collision Center.
    Watt maker likes this.
  28. Dec 23, 2018 at 10:08 AM
    FoghornTX
    Ft Worth, Texas
    Almost had to do a complete backout at a McDonald's drive-thru one time because of that narrow bullshit.
  29. Dec 23, 2018 at 10:46 AM
    Fired
    Fired Flame Extinguishment Specialist - Ret.
    The LowCountry
    '18 Limited Dbl Cab TRDOR
    Swapped 5.7 for V6
    Nice Combo! :thumbsup:
    Degausser[QUOTED] likes this.
  30. Dec 23, 2018 at 11:05 AM
    Voda48
    Voda48 New Member
    Wisconsin
    2016 Platinum
    Love the look.
    Are the lights that come with the Spyders not bright enough (hence the Morimoto HID) ?
