Daily driven..lift or no lift??
Discussion in 'Suspension' started by Jhayxian, Dec 20, 2018.
  1. Dec 20, 2018 at 7:03 PM
    Jhayxian
    Jhayxian [OP] New Member
    For daily transportation to work..should i lift it to 6" or 3" or under spacer?
  2. Dec 20, 2018 at 7:04 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    Do you park in a garage?
    Black Wolf likes this.
  3. Dec 20, 2018 at 7:04 PM
    Jhayxian
    At home or at work
  4. Dec 20, 2018 at 7:11 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    If you want to keep parking it in the garage then you'll need to do some planning. Take lots of measurements and figure out how much room you have to work with, then go from there. I've done exactly that w/mine and it's my DD as well.
    Law323 likes this.
  5. Dec 20, 2018 at 7:11 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I’d say 3/1
    Less components, no cutting, easy to maintain, gives enough clearance for any chance trail runs or most off-road (not extreme) excursions, not much mpg loss, looks badass
    Good all around
    Badknees, jewsNbrews, 805ebr and 3 others like this.
  6. Dec 20, 2018 at 7:14 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Like @Sas said, if you want to keep parking in your garage, I’d take measurements and/or hire a contractor to raise the clearance if need be.
  7. Dec 20, 2018 at 7:14 PM
    ninjajay
    Spoolston, TX
    Either? Anywhere you wouldn't be able to fit with a lift?
  8. Dec 20, 2018 at 7:48 PM
    Jhayxian
    No i park mostly front of a garage..and open area at work..im more concerns on truck that will last longer only occasionally (minor) 4 wheeling...my recent lifted tacoma sound like crap after a while..like falling apart
  9. Dec 21, 2018 at 6:35 AM
    Sas
    OKC, OK
    The more you lift it the more components and systems come into play. You may have to upgrade more than just suspension if you're doing a 6" lift. If you want to keep it simple, clean and relatively inexpensive do a 3/1 or 3/2.
  10. Dec 21, 2018 at 6:36 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    No lift.
    I lowered the rear on mine, it sits level now.
    1UPPER, Istvank11, Pudge and 3 others like this.
  11. Dec 21, 2018 at 6:42 AM
    Jhayxian
    Truck is 2.5 revtek ans 1 1/4 rear block..35" tire no rubbing..i might just replace front with 3" all spring toytec fo front? 00101_kzPqNqn9l37_600x450.jpg
    parker44 likes this.
  12. Dec 21, 2018 at 6:51 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I would just swap it out with the Toytec 3" lift.
  13. Dec 21, 2018 at 6:55 AM
    Jhayxian
    Looks like truck kinda nose dive isnt jt? Maybe install 1" block too..how much 1/4 will change the looks? :)
  14. Dec 21, 2018 at 7:12 AM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    3/1.5 toytec eibach kit on 35’s
    4BE5DE5C-875F-495F-94D0-AB9D1C9AB59A_zps_916fc6b976b4667d2fdf4303a2a7f47e1a2493f2.jpg
    Kerktam likes this.
  15. Dec 21, 2018 at 7:14 AM
    Jhayxian
    Did you have to add differential drop kit too? Or just replaced it with toytec struts spring assembly?
    TuFerLife[QUOTED] likes this.
  16. Dec 21, 2018 at 7:21 AM
    TuFerLife
    Taylor
    Chattanooga, TN
    Whatever the eibach kit came with. I’m drawing a blank this morning. Was that a diff drop kit, or carrier bearing?
    I think that was the diff drop kit.
  17. Dec 24, 2018 at 6:04 AM
    brimy311
    brimy311 New Member
    Kalamazoo
    2018 Tundra Platinum
    Im running 3” BDS with Fox Coilovers on my DD. Might as well have something cool to drive!
    Jcmf52, Law323, Casper421 and 8 others like this.
  18. Dec 24, 2018 at 3:51 PM
    Jhayxian
    Hmmm but spnding 2500 for 3" lift kinda stiff..we might as well give her 6 or 7 bds? For less?
  19. Dec 24, 2018 at 3:55 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    LIFT IT!!!
  20. Dec 24, 2018 at 4:02 PM
    brimy311
    brimy311 New Member
    Kalamazoo
    It really depends on your wants and needs. When you go over 3”, it becomes a drop bracket it.
    Coilovers are the problem. They are not cheap no matter what the application. It’s a lot of shock and technology that is far from cheap.
    kidrman likes this.
  21. Dec 24, 2018 at 4:13 PM
    Vizsla
    Vizsla 2 = 2.5
    You would be fine adding the 3” Toytec lift.
    The Revtek kit is very good, and would have included the diff drop, carrier bearing drop, etc.. That said lots of people including myself that run 3” coilover lifts and use their trucks hard do not use a diff drop. IMO the cons outweigh the pros.:notsure:
    Jhayxian[QUOTED][OP] likes this.
  22. Dec 24, 2018 at 4:57 PM
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    This. Not the lowering part but I agree no lift if I would do it all over again would left stock and added some 2.5 coilovers and shocks when it would be time to replace.
  23. Dec 24, 2018 at 5:21 PM
    Rockanock
    Rockanock 21 Chevy 2500
    No lift. After running a lift on my DD for four years I got tired of the climbing in and out. Tired of not being able to use a regular jack or reaching into my bed. Tired of the expensive cost of oversized tires. Tired of even worse MPG. Tired of premature wear on a lot of components.
    My opinion on lifts is they look awesome and are very good if your constantly off road. They are not very practical.
  24. Dec 24, 2018 at 5:30 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Don’t go 6. Stay at 3.
    Jhayxian[OP] and Degausser like this.
  25. Dec 24, 2018 at 6:05 PM
    ZPMAN
    ZPMAN 2nd place is the 1st looser
    Minnesota
    2016 Black Platinum Supercharged
    4" lift, 35s, Magnuson Supercharger
  26. Dec 24, 2018 at 6:08 PM
    Big lift??? Lose the garage.....[​IMG]
  27. Dec 24, 2018 at 8:15 PM
    Jhayxian
    Revtek kit came with spacer for differentials
    Front ( should) 2.5" with 1 1/4 rear block..
    But looks like truck is nose diving.i ordered 1" block and might replace front with toytec/eibach 3" assembly
    Chucho and Vizsla like this.
  28. Dec 24, 2018 at 8:36 PM
    Vizsla
    Vizsla 2 = 2.5
    Looks good! Not sure I would drop the back down to 1” if upgrading to the 3” Toytec/Eibach kit, there is a good chance your current front coils are a little tired from the preload spacers and age. Would definitely start with the front upgrades first, will be a noticeable improvement, rear will be mostly aesthetic.
  29. Dec 24, 2018 at 8:45 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    That 3" lift is much higher quality, better offroad and on road, will last longer, cause less wear on the truck, ride better, look better and no cutting your crossmember out. Way better than a 6 BDS IMO
    Personally I probably wont lift another vehicle, I've done a few tacomas and I'm over it. I just don't ever offroad so theres no point for me to lift and stick big tires under it. It'll look bad ass but kill my mileage and prematurely wear out other components.
    I may consider lowering it at some point though.
    Istvank11 likes this.
  30. Dec 24, 2018 at 9:32 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Go 3/1, 6” only looks right if you’re doing 37’s.
    Jhayxian[OP] likes this.
