Need help
Discussion in 'Lighting' started by Tileman800, Dec 20, 2018.
  1. Dec 20, 2018 at 8:59 AM
    Tileman800
    Tileman800 [OP] New Member
    2018 Tundra. I have amber and white led lighting for undercarriage. But both share common ground. I would like to connect the white to interior with key activation, and the amber to running lights with turn signal activation. Because switching is done on negative side, i cant see how to make both work independantly. Any ideas? Which wires can I connect to?
  2. Dec 20, 2018 at 9:19 AM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Wish I could help :notsure: but I am sure someone with experience or knowledge with this will chime in.
  3. Dec 20, 2018 at 12:56 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    That didn't work on my 2017 I had to grab it from behind the dash which its not hard to do..
  4. Dec 20, 2018 at 1:44 PM
    Tileman800
    I can get into the courtesy circuit in several places. That not the probem. My issue is that both led colors share the same ground. This led strip should have separate ground wires for each color. Any help for that? Thanks
  5. Dec 20, 2018 at 2:00 PM
    xj2202009
    x
    Lutz, Fl
    If you know of a + that gets powered when ever you like. Then My only suggestion would be to use a relay on the second ground..
