New Here, Steering rack and ball joint problems
Discussion in 'New Member Introductions' started by eastmonsoon, Dec 19, 2018.
  1. Dec 19, 2018 at 9:38 AM
    eastmonsoon
    eastmonsoon [OP] New Member
    Daniel
    Western Wisconsin
    2002 Toyota Tundra Access Cab SR5
    Hey All,
    I'm 4 years into owing my stock 02 AC and loving it, except for the suspension issues.
    In the last 7 weeks I replaced my upper and lower ball joints with Mevotech's, had it aligned and put my Firestone Winterforce's on it getting it ready for winter here is western Wisconsin. Last week it started steering bad, hard to keep straight at 55, much less 75. Took it into the shop today and found out that not only are the "new" ball joints bad (.250" vertical travel) but the steering rack I put into it last year is shot and the rear springs are "slipping" on off camber corners.
    I'm planning on picking up another reman steering rack, from NAPA I think, and doing that replacement again. I am not quite sure what to do about he ball joints. The new ones from Toyota are $128 eac. Will they be good enough? I want to keep it stock ride, etc.
    Any suggestions would be great.
  2. Dec 19, 2018 at 9:40 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO
    Pinay likes this.
  3. Dec 19, 2018 at 11:07 AM
    I would go OEM BJ's, unless you feel like doing BJ's all the time.
  4. Dec 19, 2018 at 11:14 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
    Pinay likes this.
  5. Dec 19, 2018 at 12:26 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  6. Dec 19, 2018 at 12:27 PM
    Welcome from Texas
  7. Dec 19, 2018 at 12:47 PM
    rnssncman
    rnssncman Purveyor of the Good News
    2019 Tundra Limited White
    Welcome from Kentucky.
  8. Dec 19, 2018 at 1:10 PM
    Welcome
  9. Dec 19, 2018 at 1:12 PM
    Welcome from CO.
  10. Dec 19, 2018 at 1:47 PM
    eastmonsoon
    Daniel
    Western Wisconsin
    Thanks All! And no, I don't enjoy doing ball joints all the time so , yes, I am going to purchase OEM BJ's and build a tent ( I don't have a garage) and install them.
    Does anyone think the failure of the ball joints caused the rack to fail or vice versa or neither? Just trying to figure out why the rack failed.
    Sunnier and ColoradoTJ like this.
  11. Dec 19, 2018 at 1:49 PM
    mtntop
    mtntop New Member
    2004 4x4 Access Cab SR5
    welcome from Colorado, I have always used OEM ball joints on my 04, 220k now with no problems and I live in the mtns and it sees lots of rough roads. I can't help with the rack, is it leaking fluid? Did you check your inner and outer tie rods for looseness? If they have not been replaced on a an 02 they are probably worn out??
    ColoradoTJ likes this.
  12. Dec 19, 2018 at 1:52 PM
    eastmonsoon
    Daniel
    Western Wisconsin
    Internally it developed play, the seals are still fine but I now have 1/2" play on it. measured by guys at a shop I trust
  13. Dec 19, 2018 at 3:51 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  14. Dec 19, 2018 at 3:54 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    Definitely only use OEM BJs on a first gen, as far as the rack I would double check the bushings that hold the rack to the frame. And welcome to the page, great group of people here!
  15. Dec 19, 2018 at 7:12 PM
    Welcome from Ohio!
  16. Dec 19, 2018 at 7:35 PM
    Sunnier
    Sunny
    San Diego, CA
    Hey, here's a recent post from a very knowledgeable guy who regularly does stuff in his truck you never will. Here's what he experienced, and what he did:
    https://www.tundras.com/threads/the-truck-by-osidepunker.26649/page-5#post-904493
    My thought in sharing it, is to prompt you to think about related upgrades you might do at the same time, for not much $ in parts, that could save you $$$ in the long run.
