Bought a Gen 1
Discussion in 'New Member Introductions' started by Bulldogs2741, Dec 18, 2018.
  1. Dec 18, 2018 at 6:51 PM
    Bulldogs2741
    Bulldogs2741 [OP] New Member
    Hi everyone! New member from Redlands, CA and working as a teacher. I just bought a 2000 tundra limited which has about 154k and engine and everything is working great. I do have to replace the shocks and struts... (any recommendations?). Also what do you all recommend to do now that I just bought it, should I change out the transmission fluid (still pink... I just checked it yesterday). Oil was changed 300 miles. Any other things I should do given it has ~150k on it.
    I want to be able to keep this forever as a DD and general moving stuff. I don’t plan on using it for any towing at all! Looking to forward hearing for you all.
  2. Dec 18, 2018 at 6:55 PM
    Welcome from Texas
    Bulldogs2741[OP] likes this.
  3. Dec 18, 2018 at 7:00 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC! Just drive it and enjoy!! Several good shock options out there. All depends on the ride you are looking for. Show us some pics of your Tundra!!
    Bulldogs2741[OP] and Pinay like this.
  4. Dec 18, 2018 at 7:02 PM
    Welcome from Ohio!
  5. Dec 18, 2018 at 7:03 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  6. Dec 18, 2018 at 7:04 PM
    zcarpenter92
    zcarpenter92 Yotas and Yellow Jackets
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Welcome from eastern CO!
  7. Dec 18, 2018 at 7:04 PM
    Bulldogs2741
    What would you recommend? are the strut assembly options out there any good? A little dark out here right now but I’ll get some up soon!
    BestGen likes this.
  8. Dec 18, 2018 at 7:07 PM
  9. Dec 18, 2018 at 7:20 PM
    Bulldogs2741
    Just going to keep it stock for now.
  10. Dec 18, 2018 at 7:33 PM
    Blueknights75
    Ron
    Clayton, NC
    If keeping it stock the greatest Toyota parts expert is here to take your money on any OEM parts.... @Roman
    Roman and Pinay like this.
  11. Dec 18, 2018 at 7:34 PM
    Bulldogs2741
    Sweet thanks!! I’ll check it out
  12. Dec 18, 2018 at 8:08 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from Colorado
  13. Dec 18, 2018 at 9:10 PM
    Welcome from NY.
    Pinay and Bulldogs2741[OP] like this.
  14. Dec 18, 2018 at 9:14 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Welcome from Ventura California
  15. Dec 18, 2018 at 9:15 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Welcome aboard! :cheers:
  16. Dec 18, 2018 at 9:23 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Welcome from the IE
    Darkness, Pinay and Bulldogs2741[OP] like this.
  17. Dec 18, 2018 at 10:16 PM
    Padj
    Padj Life is what happens when you're making plans
    Denver, Colorado
    2019 Limited CM TRD MGM
    Welcome from Denver, Colorado. Get your tundra out for the boys.
    Pinay likes this.
  18. Dec 19, 2018 at 2:01 AM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Pinay likes this.
  19. Dec 19, 2018 at 2:14 AM
    cjd82362
    cjd82362 New Member
    Downeast NC
    2019 TRD Limited Cavalry Blue
    None
    Welcome from Downeast NC.
    Pinay likes this.
  20. Dec 19, 2018 at 3:30 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
  21. Dec 19, 2018 at 7:10 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    1st gens are my personal favorite, I'd love to help you dial in the truck!
    We have tons of different options to fit every style driver/ budget.
    Shoot me a pm or a call anytime!
    BestGen likes this.
  22. Dec 19, 2018 at 7:15 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Welcome from a former Riverside resident who always liked Redlands.
    Change all fluids, spark plugs and air filter to start with a clean slate.
    Figure out if the timing belt, serpentine belt and water pump job has been done. If not, get that done. This is the only serious maintenance job these trucks need, it is recommended at 90k miles but I went 190k before doing mine.
    BestGen likes this.
  23. Dec 20, 2018 at 8:22 AM
    Bulldogs2741
    Ok thanks! I’ll bring it into my mechanic and check those things out!
    Just a quick question as well... what do you guys do as far as changing out the transmission fluid? I’ve heard conflicting things from people.
  24. Dec 20, 2018 at 8:46 AM
    03tundra
    03tundra New Member
    2003 white tundra
    Wheels & tires
    NC
    TXMiamiFan likes this.
  25. Dec 20, 2018 at 10:42 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The dump and refill method should be fine. The stories I have heard in general where things go wrong were related to flushing by machine or the old bucket trick.
    I change mine by dump and refill every 30-40k and am around 230k with no problems.
    BestGen likes this.
  26. Dec 20, 2018 at 10:55 AM
    Most people recommend doing just a drain and refill. Make sure you buy the proper fluid. Keep in mind this only gets out around half the fluid at best. A flush is good if you know the history, and know that it's it's been done regularly. I think even the Toyota dealerships near me have stopped doing the flush though. Don't forget to do your rear differential fluid. If it's 4WD you'll want to do the transfer case and front diff fluid as well. This is often overlooked. The transfer case and rear differential are extremely easy to do yourself. If I can do it, you can do it and save a bunch on labor.
    As for shocks and struts. Don't make the mistake I made by getting the Monroe quick struts. They are cheap for a reason. It really depends on how much you want to spend and what your intentions are with the truck. I actually have a thread going right now where I asked for feedback.
    https://www.tundras.com/threads/need-help-leveling-my-first-gen.36489/
  27. Dec 20, 2018 at 11:24 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  28. Dec 20, 2018 at 11:50 AM
    Bulldogs2741
    Thanks!! That helps a bunch!
