King Shock rebuild, pic heavy, get beer(s).
Discussion in 'Long Travel Suspension' started by ColoradoTJ, Dec 17, 2018.
  1. Dec 17, 2018 at 7:39 PM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    A long time ago I told the good people of Tundras.com that I would do a little thread on shock rebuilding. Better late than never right?
    The shocks being rebuilt are King 2.5 14" remote reservoir shocks. The 7/8" shaft needs to be replaced due to nicks and other stupid things I did around my shocks (weld splatter). I am also doing a re-valve and adding a flutter stack.
    If possible, wash the vehicle before starting this job, but most likely you will still be cleaning them up after removal.
    Be safe, use jack stands. I have to use a Hi-Lift jack to flex out my junk. This is also a great time to see if my limit straps need adjusting.
    Straps still stop the shock from topping out with just the tire off the ground, but it could use a little adjustment. Not sure if the strap would stop the shock under a big shock load. I aim for 1/4" left of travel before shock tops out.
    While flexed out, might as well take all the preload out.
    Once shock is out, wash time. Nobody likes working on oily shocks.
    Bench work:
    Pull coil plate off, remove springs and coil slider. Inspect the springs for excessive wear, mainly inside. Normal wear is fine like paint missing...etc.
    Time to break into the shock. Place in vice and bleed off N2 pressure. I did this part on the bench for the sake of taking pictures.
    Loosen the lock down for the wiper cap. Then use spanner wrench to loosen wiper cap. Around half way, push down to drop the seal cap down to expose the shock cylinder c-clip. Unscrew all the way by hand and slide up the seal cap. Now you can remove the c-clip. This is what holds the shock together. Some don't believe in limit straps, but I do.
    Now you are ready to separate the shock body from the internals. This is best done in the vise.
    Pull straight up evenly and the internals will pop out. Lay the assembly on a clean rag.
    At this point I sliced my finger wide open, forgetting that these are machined surfaces...so I didn't get a picture of the assembly coming out. I will post links to other websites to satisfy the visual need for guys.
    I will give you some helpful pointers though.
    1) some surfaces are razors...yeah.
    2) With the shock body still in the vise, put a little air into the reservoir (25 lbs), and get the reservoir piston all the way to the end. This also helps see if the reservoir needs a re-seal as well. If you see bubbles coming up in the oil, you have a leak. Then re-seal the reservoir.
    On Fox shocks, you have an added step right here to set the reservoir piston depth. Not a big deal and easy to do.
    Now I wanted to show you why my shock was leaking:
    The welding slag was my fault, and the nick in the shaft...no idea.
    Next was to check my valving to what was ordered. .015" on compression and .012" on rebound. This is an image of the valve shims and piston. Notice the gap between the last two shims....this is called a flutter stack. Please read on....
    Notice the two sides are different. One is compression and the other is rebound. Don't get this messed up.
    Instead of trying to explain a flutter stack, shock valving/tuning, I would rather give the information so everyone can read and understand.
    https://www.crawlpedia.com/shock_tuning.htm
    This is not just a normal rebuild since my shaft needed to be replaced. This can be a real PITA, but I will give you some tips to get it done like a pro. Removing the rod end can be frustrating.
    First, go inside and start boiling some water.
    Second, remove the c-clips and bearing.
    Take your shaft with the rod end and place it in the boiling water for 10-15 minuets. Women love when you do this.
    I like doing this over using a torch. A torch will remove the finish of the rod end, uneven heating, etc. To each their own though. If a torch is what you want to use, knock yourself out. All you are trying to accomplish is breaking free the lock tight.
    After your required time in the boil, take the shaft and clamp it in the vise (and hopefully you purchased the aluminum shaft clamp). Remove rod end, install on new shaft with some lock tight. Reinstall bearing and c-clips.
    Time for seals, o-rings, and putting this all back together.
    Place shock body in bench vise, and fill up body until about 1" away from the shock cylinder c-clip grove. Place a rag or something over the body so dirt, bug, diaper, or whatever doesn't get inside. On an emulsion shock (no remote reservoir), there is a specific measurement of shock oil to use. On a 2.5 14" shock, it would be 900cc of oil. Another reason the RR shocks kick ass.
    Install all seals & o-rings and discard old ones. You will have extra seals unless doing a triple bypass shock. Not a big deal, save them for the trail. Never know who you might run into with a seal issue.
    Re-install all parts in the exact reverse order on the shaft. This is the easy part. If doing a re-valve, write all sizing on shims for future use.
    Very easily, start working the piston back into the valve body. Oil will overflow and this is normal. This is getting all the air out. Work in the seal cap. You may have to pull out and put the shaft into the oil more (spill some out), push seal cap in, and pull shaft out of oil. This will draw the seal cap into the body. Little trick if you put to much oil in the body. Push the seal cap below the c-clip grove in the body. Install c-clip. Screw on dust cap and tighten set screw.
    I usually take out the schrader valve core at this point.
    Next, push the shaft all the way down into the body. Replace schrader valve core and hook up N2 fill kit.
    I usually step up the pressure and put 50-75-100 psi of N2 into the shock and watch the shaft come up and listen/watch for leaks. After that is done, I charge the shock to manufacturer recommended psi, disconnect N2 line. (2” shock 125-150 psi, 2.5” shock 150-200 psi)
    You now have a rebuilt and tested shock.
    Install spring(s), coil slider if applicable, coil plate and adjust coil adjustment cap until snug. Then you can set preload. I have my fronts at ~1" preload and rears at 2-2.5". Tighten down cap and you are ready for install.
    And this is how you blow a few hours of your day rebuilding a coil over shock.
    http://www.kingshocks.com/products/parts/replacement-parts/
    https://www.crawlpedia.com/shock_rebuild.htm
    https://downsouthmotorsports.com
    https://www.filthymotorsports.com
    https://www.schmidtyracing.com/product-p/n-reg-uni400-8r-w-.htm
    So how much does this cost you ask?
    The charge kit, when all said and done was around 300.00. I have used this so much and has paid for itself. Others may not ever pay this off if only using it every 2-3 years. We do a few shocks between the fellas (and ORI's)
    Shock rebuild kits 22.00
    1 Gallon of shock oil 32.00 (will do two of my large shocks).
    Shaft was 60.00, but this is not a normal replacement part. My fault.
    So after 4 years of ice cream runs and easy trails, this repair cost me 98.00. If it wasn't for the shaft, this simple rebuild would have cost me 38.00. Shipping alone on most shocks will cost more than that for a private party that doesn't get bulk shipping rates.
    Hope this helps some of you out when making decisions on rebuilding shocks. As always, if you have questions or comments, feel free to add them or PM me.
    ATV25, dak13, Black Wolf and 34 others like this.
  2. Dec 17, 2018 at 7:46 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Great write up!
    ColoradoTJ[OP] likes this.
  3. Dec 17, 2018 at 7:58 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    2016 Tundra TRD Pro - Quicksand
    None, yet....
    Good read!
    Since you already referenced Crawlpedia, I figured I’d add this link from filthy motor sports. Breaks down how to rebuild a bypass and since some of the big boys here run them, might be worth keeping the info together.
    Also, what N2 kit are you running? I need to order one for my bypass install.
  4. Dec 17, 2018 at 8:15 PM
    Already linked in the post. :thumbsup:
    Vizsla likes this.
  5. Dec 17, 2018 at 8:30 PM
    the_midwesterner
    Luis
    None, yet....
    Ah balls... missed that. Did you link your N2 kit also? I can’t find that.
  6. Dec 17, 2018 at 8:31 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Thanks for the write-up!
  7. Dec 17, 2018 at 8:51 PM
    Vizsla
    Vizsla pretend2send
    Thanks!:thumbsup: I learned..., let someone else rebuild my shocks.:D Like the adjuster on the limit strap.
  8. Dec 17, 2018 at 8:55 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  9. Dec 17, 2018 at 9:04 PM
    I will update the original post.
  10. Dec 17, 2018 at 9:06 PM
  11. Dec 17, 2018 at 9:48 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    Very nice write up Chris!! :thumbsup::thumbsup:
    Side note:
    When the shock is not charged, the end caps of the remote reservoir will “suck” into the reservoir tube. When this happens, dirt and debris can enter the reservoir area if the reservoir was dirty.
    Clean that reservoir area very well before recharging and spray with a cleaner.
    I had a King that was shipped without N20 that lead me on a wild goose chase for weeks.
    The debris in the reservoir chamber was the culprit.
    Here is a pic of the chamber sucked in (not charged).
  12. Dec 17, 2018 at 9:51 PM
    Boosted4runner
    WA
    Here is a pic of the chamber charged
    OR18TRD likes this.
  13. Dec 17, 2018 at 9:53 PM
    Boosted4runner
    WA
    Better pics with dummy arrows
    Not charged
    Charged
    equin, 040Tundra and ColoradoTJ[OP] like this.
  14. Dec 17, 2018 at 9:57 PM
    That is a fact. Probably ruined the seals rather quickly.
    I didn’t post this, but a comparison between old oil vs new oil.
    This is why I always wash my shocks well after removing. Only time I have my shocks discharged is shipping or in the rebuilding stage.
  15. Dec 17, 2018 at 9:58 PM
    Boosted4runner
    WA
    Thankfully all my seals were good! Did appx 400 miles with no N20 and after cleaning and recharging all was well. :eek2:
  16. Dec 17, 2018 at 10:25 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    Kings & Icons
    I dont discharge the shocks until I get the wiper caps off. The pressure will keep the seal head from spinning when trying to unscrew the cap.
    And lots of times the seal head wont come up all the way allowing the wiper cap to fully seat until the shocks are pressurized, so make sure you go back and check that there is no gap between the wiper and the shock body
    ColoradoTJ[OP] and Watt maker like this.
  17. Dec 18, 2018 at 9:17 AM
    I pull up on the shaft to ensure the seal head is seated against the c-clip before putting pressure to the shock, but there is always that one time! Good tips.
    Keep them coming people.
  18. Dec 18, 2018 at 12:10 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    TJ!!! Awesome thread brother, great writeup...
    one quick note. On heating the rod end if you do use a gas torch you must use MAP gas torch... thats very important... and i do it that way and as long as you keep the nozle 4-6" away and do quick passes you should have no issues with loosing the finish on the rod end. Also the shaft clamps are so easy to use. I have a set i got for 25$ from Down south motorsports. And they are a must for those wanting to do self-shock work.
  19. Dec 18, 2018 at 3:22 PM
    Good call on the MAP gas selection. I have actually seen people get aluminum so hot it deforms. Lol. This is usually why I suggest the boiling water.
    Doing rebuilds without shaft clamps is just wrong. I have actually rebuilt a 2.0 King on top of an old clothes washer as a bench. My buddy had just returned from a short deployment to Africa and decided to get this done over beers. Lol. Timing is everything I guess.
    Glad you liked the thread and thank you for your input and advice.
  20. Dec 18, 2018 at 3:49 PM
    Funny, I just noticed a gun in one of the pics....
    See if you can find it....
  21. Dec 18, 2018 at 7:07 PM
    Boosted4runner
    WA
    :D
    Took me a while, I admit!
  22. Dec 18, 2018 at 7:10 PM
    Are you pointing at my member? Lol
    Try again.
  23. Dec 18, 2018 at 7:11 PM
    Boosted4runner
    WA
    LOL!!!! :rofl:
    Then I might give up. At first I figured reflection off something. Could’nt figure out what this is
  24. Dec 18, 2018 at 7:13 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Skills!
    Awesome write up!
  25. Dec 18, 2018 at 7:15 PM
    That’s a razor knife.
    Big hint. First picture.
  26. Dec 18, 2018 at 7:18 PM
    Boosted4runner
    WA
    LOL! I got it! :thumbsup:
    Glock of some sort :thumbsup:
    G22, G17, or G21 I’d guess
  27. Dec 18, 2018 at 7:21 PM
    19.
    G17 wasn’t far though.
  28. Dec 18, 2018 at 7:22 PM
    Boosted4runner
    WA
    :thumbsup:
    I just picked up a new threaded barrel for my G17 last night. Have a used G17 Lonewolf threaded barrel if ya need one! :D
  29. Dec 18, 2018 at 7:26 PM
    Oh......
    Boosted4runner likes this.
  30. Dec 18, 2018 at 7:32 PM
    Shoot me a PM with details.
    See what I did there?
