8/15 Tundras on lot at dealership have cam tower leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by helloo, Dec 17, 2018.
  1. Dec 17, 2018 at 1:34 PM
    helloo
    helloo [OP] New Member
    Aurora, CO
    2018 Black TRD CM Limited
    I recently went to look at the used Tundras at a local Toyota dealership and 8 out of 15 had leaking. All but two are on the passenger side. The other two had it on both sides. I can't believe they are selling these in this condition and I am sure 99% of potential buyers will not look for this leak. Most leaks were minor, but nonetheless. Most were leaking towards the rear/back area where it is hard to notice unless you stick your head in there.
    The worst leak observed is a 2017 with 25k miles leaking on both sides20181215_142000_resized.jpg 20181215_142038_resized.jpg 20181215_142108_resized.jpg 20181215_142127_resized.jpg 20181215_142318_resized.jpg 20181215_142339_resized.jpg 20181215_142357_resized.jpg 20181215_142547_resized.jpg 20181215_142620_resized.jpg 20181215_142743_resized.jpg 20181215_142814_resized.jpg .
    Some photos I took.
    jtwags, classiccat, tundraatx and 3 others like this.
  2. Dec 17, 2018 at 1:41 PM
    Gibo244
    Gibo244 New Member
    KG
    Maui
    Hope u told the dealer
    OR18TRD and NewImprovedRon like this.
  3. Dec 17, 2018 at 1:50 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    I must be missing something because a couple of those don't look like they have a leak at all.
  4. Dec 17, 2018 at 2:08 PM
    15whtrd
    15whtrd Mr. Blonde
    I can barely see it on some of them. And some of them don’t look like it at all. How did you spot that? I’ve looked at mine and it seems completely dry. If mines seeped a little I don’t know if I would want it torn down just for that.
  5. Dec 17, 2018 at 2:09 PM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    Same...I don't see it. They look bone dry.
    71_340 and BuckWallace like this.
  6. Dec 17, 2018 at 2:23 PM
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    how can something like this be prevented?
  7. Dec 17, 2018 at 2:24 PM
    helloo
    Aurora, CO
    I updated the photos with arrows to show where the area is covered with oil. The last photo is my 2018 that has just started to leak. 20181215_142000_resized.jpg 20181215_142108_resized.jpg 20181215_142318_resized.jpg 20181215_142357_resized.jpg 20181215_142547_resized.jpg 20181215_142743_resized.jpg 20181020_115734.jpg
    ColoradoTJ, jtwags, Sunnier and 5 others like this.
  8. Dec 17, 2018 at 2:35 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    Those tabs with the hole are supposed to be metal color not oil color... those look black unless it's just the lighting. My passenger side looks oil color but you can still see the metal under the oil.
    Vizsla and Sas like this.
  9. Dec 17, 2018 at 3:44 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I'm afraid to go out and check mine!:pray:
  10. Dec 17, 2018 at 4:26 PM
    15whtrd
    15whtrd Mr. Blonde
    Even a little bit of oil is irritating and should not be happening. Especially since they’ve known about it for a long time and have yet to make a permanent fix on newer engines. With that said, it’s very minimal, I don’t know if I would want my engine torn down for that. But I would want them to take a note so that it if it ever got worse after warranty I may have something to stand on.
    jtwags, Blueknights75 and Gibo244 like this.
  11. Dec 17, 2018 at 4:30 PM
    Baldmonkey22
    Baldmonkey22 New Member
    Quartz Hill, Ca
    Yep my 18 is in for the passenger side now because they only did 1 side the 1st time. 6k miles...
    OR18TRD likes this.
  12. Dec 17, 2018 at 4:33 PM
    idahowiseguy
    idahowiseguy New Member
    Kent
    Coeur d Alene, Idaho
    Love this thread as now I have a way to fill my time this Thursday when I take my truck in for it's one year service. I will take my headlamp and scope out the undersides of the used trucks on the lot. Food for thought, would it be of any benefit to tell the service advisor about any leaks I see? Only reason I can think of is it would be a good test of the dealership's integrity; if they act like they have no idea what the cam tower leak is or don't care about the leaking vehicles then I will be concerned should my truck eventually develop the leak.
    Sunnier likes this.
  13. Dec 17, 2018 at 4:44 PM
    Vizsla
    Vizsla 2 = 2.5
    It can’t. If it leaks or seeps under warranty get it fixed. Only gets worse and costs about 4K, and once it leaks bad enough it can fail inspection if you live where vehicle inspections are required. Really isn’t a big deal, certainly not tearing down the engine, just time consuming. Once your warranty is up they aren’t going to cover it.
    Sunnier, joonbug and 15whtrd like this.
  14. Dec 17, 2018 at 4:56 PM
    Navi
    Navi New Member
    2019 CrewMax Limited
    if you found that 50% are leaking, i’m wondering if the cam tower leak is on MOST Tundras or just some??
    are you more likely to have the leak or not have a leak?
  15. Dec 17, 2018 at 5:04 PM
    Beep88
    Beep88 New Member
    I was told Saturday when I had mine in for it’s free service that if it’s not dripping Toyota will not fix it! I had the head tech look at it and it took him a few seconds to say you have a leaking cam tower but it’s not dripping just seeping. When it drips we will fix it. Mine has 13,000 miles on it.
    OR18TRD and 15whtrd like this.
  16. Dec 17, 2018 at 5:05 PM
    Navi
    Navi New Member
    Harsh..
  17. Dec 17, 2018 at 5:16 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    Well. . . I am going to have to look at mine... Ugh
  18. Dec 17, 2018 at 5:36 PM
    helloo
    Aurora, CO
    I agree. I think I will have them take note of it and have it fixed before warranty is out. Unless it gets worse which it might since mine is already leaking before 6k miles.
    15whtrd[QUOTED] likes this.
  19. Dec 17, 2018 at 5:41 PM
    Car guy 991
    Car guy 991 New Member
    Bought my 2011 with 102k. The guy said the valve cover was leaking but turned out both sides had the cam tower leak. Now at 120k and the the leaks getting worse. Any advice on how to proceed from those with experience?
  20. Dec 17, 2018 at 5:42 PM
    Navi
    Navi New Member
    is this a reason to not be the truck??
  21. Dec 17, 2018 at 5:42 PM
    Navi
    Navi New Member
    *buy..
  22. Dec 17, 2018 at 5:53 PM
    Wolverine
    Wolverine New Member
    Jeff
    Michigan
    2019 SR5 CM Cement
    Damn it. Just checked mine and found a droplet of oil on the drivers side. To the dealership tomorrow I go. 18 Crew Max 11k miles.
    jtwags likes this.
  23. Dec 17, 2018 at 6:19 PM
    Vizsla
    Vizsla 2 = 2.5
    Not true, that’s your dealer saying that. There is no degree of leaking involved, for Toyota it leaks or it doesn’t. You can call Toyota customer care and force their hand, bet your dealer didn’t document it though, or wait till it drips. Might be better to do the latter relationship wise with your dealers head tech since you have plenty of warranty left.
    JoshuaA, ColoradoTJ, Sunnier and 2 others like this.
  24. Dec 17, 2018 at 6:34 PM
    Ductmon
    Ductmon Jet Wrench
    Aiken, SC
    2018 White C/M O/R 5.7
    8k on my 18cm ill have to check. I knew before the buy about the issue but hadnt seen or heard of it coming up before at least 70k. Is it just 5.7 or 4.6 as well?
  25. Dec 17, 2018 at 6:40 PM
    Wolverine
    Jeff
    Michigan
    2019 SR5 CM Cement
    I believe 5.7 only. Leak will be towards the rear of the engine. Supposedly in manufacturing the robot that applies the sealant doesn’t lay down a heavy enough bead.
  26. Dec 17, 2018 at 6:42 PM
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    This is like seeing Jesus in the clouds or the Virgin Mary in a piece of wood :)
    Black Wolf, Scpringle and Sunnier like this.
  27. Dec 17, 2018 at 6:45 PM
    Sas
    OKC, OK
    Must. Resist. Dirty. Joke.
    JoshuaA, Black Wolf, Sunnier and 2 others like this.
  28. Dec 17, 2018 at 6:53 PM
    acidspaz
    acidspaz New Member
    Those leaks won't even cause an issue. By 5k-10k miles you would get an oil change and never notice a thing... You are being paranoid. Before posting do your research. It would take probably 30k miles before you even saw anything on the dipstick and I doubt it even at that. Over time most vehicles develop small leaks that don't cause any issues... It would take a much more serious leak for me to worry or take any action. It's like a 16 yr old that just bought his first car...
  29. Dec 17, 2018 at 6:59 PM
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Just gave my truck a one over and leaks (yet), but I only have 625 miles. Such a disappointment to see this occurring on so many new trucks. It’s just a matter of time for it go happen to everyone based on what we are seeing here. May be time to consider getting an extended Toyota warranty.
    WrigglingWilly likes this.
  30. Dec 17, 2018 at 7:06 PM
    Krabage
    Krabage New Member
    2014 DC TRD
    Thats the same thing they told me when my 14's rear main seal started leaking at 30k. New vehicles shouldnt leak oil, period.
    NUDRAT, Spuds, NjPro and 1 other person like this.
