Stupid Line-X question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Freezy, Dec 15, 2018.
  1. Dec 15, 2018 at 4:41 AM
    Freezy
    Freezy [OP] New Member
    Dumb i know, but is it bad to have this done in the winter? Wondering if it needs to be over a certain temperature for it to cure properly and time.
    Thanks
  2. Dec 15, 2018 at 5:10 AM
    MT Madman
    MT Madman Just an ordinary guy
    Hawk Point MO
    2020 Silver Platinum
    TRD dual exhaust TRD Rear Sway Bar SnugTop Hi-Liner
    I wouldn't think so since it's somewhat flexible and should expand/contract with the metal.
    NewImprovedRon likes this.
  3. Dec 15, 2018 at 5:15 AM
    Adam New Member
    It dries in seconds. Give it 24 hours before you use it to let it cure. you will be fine. If there is anything wrong with it, linex has a good warranty
    OR18TRD and NewImprovedRon like this.
  4. Dec 15, 2018 at 7:54 AM
    Freezy
    Ok, i'll just get it done. I appreciate the info
    OR18TRD likes this.
  5. Dec 15, 2018 at 7:57 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t think they would apply it if the weather was an issue.
    Law323 and Trooper2 like this.
  6. Dec 15, 2018 at 8:00 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    This^
    15whtrd[QUOTED] likes this.
  7. Dec 15, 2018 at 9:17 AM
    Freezy
    True, Thanks
  8. Dec 15, 2018 at 9:32 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Low temps might increase cure time. Shouldn’t be any other issues.
    15whtrd and Law323 like this.
  9. Dec 15, 2018 at 9:42 AM
    chphilo
    chphilo Tundra addict
    Western PA
    2010 Toyota Tundra TRD 5.7 4x4 CM
    I got mine done in winter. No issues.
    15whtrd and NewImprovedRon like this.
  10. Dec 15, 2018 at 9:50 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I would think they would apply in a temp controlled shop. And like others have mentioned, doubt they would take the job if it couldn’t be done.
  11. Dec 15, 2018 at 10:08 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    This. If you take it to a place and they are applying it outside - go find another shop.
    Every Line-X job I have had done has been in a temp-controlled booth/shop.
    15whtrd and Law323[QUOTED] like this.
  12. Dec 15, 2018 at 10:29 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    ^^^Absolutely.
    Regardless of bed liner having rubber in it, it still has a paint/adhesive base and nothing can dry/adhere if the temp is too cold. Rule of thumb (at least with painting industrial gennys ) is 55 degrees or higher. Anything lower won’t dry or adhere to the surface.
  13. Dec 15, 2018 at 11:22 AM
    AZTundra
    Paul
    Phoenix, AZ
    Agree with everyone above. You shouldn't have an issue aside from a possible longer cure time.
    15whtrd likes this.
  14. Dec 15, 2018 at 12:58 PM
    Freezy
    What is their warranty?
  15. Dec 16, 2018 at 12:58 AM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I haven’t done line-x brands, but I’ve sprayed other brands. If they are produced the same way, the two chemicals swirl in a tube and the result is a self-heating chemical reaction. It comes out in a liquid form that is hot enough to leave burns on the skin. I’ve sprayed beds in various temps and the cold has had no effect, but it doesn’t get as cold in Texas as other places.
