Toytec/eibach...or stay where I’m at
Discussion in 'Suspension' started by JohnsonANDjohnson, Dec 11, 2018.
  1. Dec 11, 2018 at 8:17 PM
    JohnsonANDjohnson
    JohnsonANDjohnson [OP] Jfabick277
    2015 sr5 Black crewmax 5.7 A.K.A Big Tex
    6inch block lift Iron cross rear and front bumper Nitto trail grapplers 35x12.50 Stock rims powder coated black Warn 10k winch Retro customz rock lights
    Hello all again, I currently have a 6inch spacer lift on my 2015 tundra and have been debating going down to the toytec/eibach 3/1 or stay where I’m at. I run 35x12.50 trail graps and do not intend to change tire size. Was just wondering if people run 35’s on their 3” lifts and how it is. Also if anyone has the eibach kit your info would be greatly appreciated. I’m mostly just driving around with mild wheeling but want to be prepared when I do go wheeling.
  2. Dec 11, 2018 at 8:20 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  3. Dec 11, 2018 at 8:25 PM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    It works well so far. Get UCA so you won't need to do a body mount chop to clear 35's
    because_wumbo-truck likes this.
  4. Dec 11, 2018 at 8:25 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    With the right offset wheels and a little cutting you should be good
  5. Dec 11, 2018 at 8:26 PM
    DITTO
  6. Dec 11, 2018 at 8:27 PM
  7. Dec 11, 2018 at 8:28 PM
    Jengel451
    The Bitterroot, MT
    True. Offset will determine cutting or not in addition to UCA or not
  8. Dec 11, 2018 at 8:30 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    I currently have the Toytec/Eibach kit and I love it. I’m sitting on 295/70/18s
  9. Dec 11, 2018 at 8:40 PM
    Vizsla
    Vizsla 2 = 2.5
    You have a lift that cut the crossmember, it will take some work to undo. Hardly worth doing to run the Eibach kit, as there won’t be much advantage over what you have. If you are upgrading to something performance oriented, Fox, King, ADS etc. then maybe? Not going to be cheap regardless. Are you 2wd?
  10. Dec 12, 2018 at 4:42 AM
    JohnsonANDjohnson
    No sir I’m 4wd
  11. Dec 12, 2018 at 5:06 AM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Any other mods to make those tires work with that lift? Is the offset on your wheels similar to stock TRD Offroad wheels? lookin at that same lift and want bigger tires but don't want cut if I don't have to.
  12. Dec 12, 2018 at 5:44 AM
    Jengel451
    The Bitterroot, MT
    you'll need +25 if you don't want to cut, that's the sweet spot. Many many threads cover what you're trying to do. Do the research and you'll be fine. After an hour if looking I was able to figure out what would work and what won't. Worked out great.
  13. Dec 12, 2018 at 7:25 AM
    Guhner123
    Gunner
    2017 Tundra SR5 MGM
    I did very light trimming of the front fender well. But +25 seems to be a good spot!
  14. Dec 12, 2018 at 7:40 AM
    YZTundy
    YZTundy New Member
    Denver, Co
    2011 Crewmax Rock Warrior
    I am running the Toytec Boss Suspension, SPC UCA's, Progressive AAL with 35x12.50R17 Ridge Grapplers and I only have a slight rub at full lock in reverse.
  15. Dec 12, 2018 at 8:10 AM
    Hugo Huerta
    Hugo Huerta New Member Vendor
    Hugo
    2011 4Runner
    Toytec BOSS Performance 2.5, SPC ucas, Icon Alloys wheels, Hefty Fab front bumper, Come Up Winch, ARB skid plates, 285/70/17 Duratracs, Custom built rock sliders
    Feel free to give a call any time! We will be more than happy to answer your questions and find the right suspension for your needs upload_2018-12-12_9-10-24.jpg
    T-Rex266 likes this.
  16. Dec 13, 2018 at 3:54 PM
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    Don't forget that the offset plays a role in the equation. I want to start it's been 5.75 for clearance.
  17. Dec 13, 2018 at 6:33 PM
    JohnsonANDjohnson
    I also have a 10k winch on the front now as well
    dandailey[QUOTED] likes this.
  18. Dec 22, 2018 at 3:53 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Are those stock wheels painted or Plasti dip? They actually look great!
  19. Dec 22, 2018 at 4:48 AM
    JohnsonANDjohnson
    Thanks my man! They are powder coated black, they do look really good for stock rims.
  20. Dec 22, 2018 at 4:50 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    You'll likely need to do some serious trimming. Maybe a BMC.
  21. Dec 25, 2018 at 4:36 PM
    JohnsonANDjohnson
    Well what does the cutting of the crossmember do to where I can’t go down to a lower lift? How can I undo the damage? I want to go down to a lower lift but I’m wondering what it will take.
  22. Dec 25, 2018 at 4:54 PM
    Vizsla
    Vizsla 2 = 2.5
    Nothing, first see if yours is cut. If it is the old version it won’t be, there were issues so it was redesigned with cutting the crossmember, there are some things cut and trimmed on the old version as well, not sure if that will matter. Just need a competent fab shop to fix it if cut. Anything can be fixed with money, and you would definitely appreciate the performance gained by a proper mid travel setup.:)
  23. Dec 25, 2018 at 4:56 PM
    JohnsonANDjohnson
    Thank you so much for the Info!! I’ll be looking into it more and hopefully will receive good news!
  24. Dec 25, 2018 at 5:03 PM
    JohnsonANDjohnson
    I’m trying to remedy an issue where I was doing mild off-roading and mudding where my shock tower broke and my shock collapsed. So I’d like to have confidence in my truck to wheel so this doesn’t happen again. I’m running 35x 12.5 20s and TRD pro suspension
  25. Dec 25, 2018 at 9:41 PM
    Jhayxian
    Jhayxian New Member
    35 12.5x20 with 2.5 revtek 1.25" rear block..slightly rubbing on plastik maybe few hair when steering lock turning with 5mps.
    I just ordered toytec/eibach 3" and i have extra 1" rear block just incase..this should fix the minor rubbing
    JohnsonANDjohnson[OP] likes this.
