2014 Rear diff
Discussion in '2.5 Gen Tundras (2014-2021)' started by TylerVG, Dec 11, 2018.
  1. Dec 11, 2018 at 5:25 PM
    TylerVG
    TylerVG [OP] New Member
    Tyler
    2014 Tundra CM 1794
    3/1 level
    Hi Everyone,
    I am about to change the oil in my rear diff. Does anyone know how many quarts it takes?
    Any recommendations on oil? Synthetic vs regular?
    Thanks again, I can’t find it anywhere online for a 2014.
  2. Dec 11, 2018 at 5:42 PM
    Azblue
    The Dirty T ( ^_^)_且
    15whtrd and Jsena like this.
  3. Dec 11, 2018 at 5:49 PM
    TylerVG
    Tyler
    2014 Tundra CM 1794
    3/1 level
    Thanks man, I appreciate the help.
    When I bought the Tundra it has a leaking rear diff seal. I took it to a shop to replace it and told the guy I have no idea if the previous owner ran it low. I asked him to check the breather in case it was plugged and the pressure caused the seal to leak. He changed the seal and said it took 2 quarts to top off and the breather was good. Today I was bored so I pulled the fill plug and air pressure came out. I couldn’t feel oil sticking a finger in and ended up dumping 2.5 quarts in. So I pulled the breather valve and it was locked solid and had brown funk in it. I got that cleaned up and working properly. I’m going to run the truck 100 miles and then drain, pop the cover and clean it up and refill. I called the mechanic and asked if he actually filled it and he denied fixing the rear seal and said he just did the front axle shaft change. My bill shows the seal and labour and it doesn’t leak anymore. So I checked the front and it was 1/2 a litre down.
    I am really worried that i will have to replace my rear end bearings, gear and housing. Should I flush it a few times? It not howling or making any noises.
  4. Dec 11, 2018 at 5:50 PM
    Curious what's your mileage?
  5. Dec 11, 2018 at 5:51 PM
    TylerVG
    Tyler
    2014 Tundra CM 1794
    3/1 level
    130,563 kilometres. But it has been changed regularly at the dealer prior to my buying it
  6. Dec 11, 2018 at 5:51 PM
    Y0TA PR0 likes this.
  7. Dec 11, 2018 at 5:53 PM
    TylerVG
    Tyler
    2014 Tundra CM 1794
    3/1 level
    I would change it for sure. It’s not expensive and easy to do yourself. Mine is done very 30,000kms so roughly every 20,000 miles. You could easily get away with longer if you are not towing constantly.
    15whtrd likes this.
  8. Dec 11, 2018 at 5:57 PM
    ninjajay
    ninjajay Posting from the toilet
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toytec/Radflo Lift, Ambit RS02 18x9+0, Bridgestone Revo 3 295/70/18
    60k is a good time to do it
  9. Dec 11, 2018 at 5:58 PM
    No towing what's so ever, city n highway driving
  10. Dec 11, 2018 at 5:59 PM
    15whtrd
    15whtrd Mr. Blonde
    I suggest you never go to that guy ever again! I would be pissed! Guys like him give good mechanics a bad name.
    OR18TRD and 831Tun like this.
  11. Dec 11, 2018 at 5:59 PM
    Use what @Azblue stated above? ^ post #2
    15whtrd likes this.
  12. Dec 11, 2018 at 6:02 PM
    TylerVG
    Tyler
    2014 Tundra CM 1794
    3/1 level
    I definitely will not use that shop again. Small town so he will lose business on this one.
    If my rear end is not howling or acting any different do you think things are ok after I change fluid?
    Today I was so mad that I was going to drain it and fill with diesel and run it around my yard and drain a few times to clear out the crud. Common sense kicked in and I decided I will flush with proper gear oil lol
    15whtrd likes this.
  13. Dec 11, 2018 at 6:03 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    Should change it at 60,000km (37,000miles)
    Even if your towing or not! Front & back diff and transfer case
  14. Dec 11, 2018 at 6:03 PM
    Look into when I get to Ft. Worth
    831Tun and 15whtrd like this.
  15. Dec 11, 2018 at 6:05 PM
    15whtrd
    15whtrd Mr. Blonde
    Adam will be changing that shit in the parking lot of the hotel!
  16. Dec 11, 2018 at 6:07 PM
    :anonymous:
    :spy:
    Can't believe you remember that :rofl:
    OR18TRD and 15whtrd[QUOTED] like this.
  17. Dec 11, 2018 at 6:09 PM
  18. Dec 11, 2018 at 6:10 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I'm at 42,400 miles and will do it shortly. I'm using Red Line 75W90 full synthetic.
  19. Dec 11, 2018 at 6:11 PM
    Azblue
    I'd say it's about time. I just turned 40k but I do tow a travel trailer about 8 times a year and honestly what came out didn't look too bad, but I'm glad I changed it.
    You'll need the 4 quarts and 2 crush washers (cheaper on Amazon, I hit the dealer, $3.15 each). Tighten drain and fill to 36 ft lbs. Also a good idea to loosen the fill first just in case.
  20. Dec 11, 2018 at 6:12 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Yup. Use the same figure.
    I've got a 4WD and will have 2 one gallon jugs of new oil on hand to do all three.
  21. Dec 11, 2018 at 6:12 PM
    Was planning on taking to a lube shop, when I get into DFW
    Y0TA PR0 and 15whtrd like this.
  22. Dec 11, 2018 at 6:15 PM
    Azblue
    I don't trust them, sneaky, shady bastards. Buy a 12 pack and spend the 1/2 hour in the garage. Tell the wife it'll take all day to do.
  23. Dec 11, 2018 at 6:16 PM
  24. Dec 11, 2018 at 6:17 PM
    Y0TA PR0
    Rafael
    2017 TRD PRO
    Get on it your way past due guey! :D
  25. Dec 11, 2018 at 6:18 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    I think it's every 30k for diffs.
  26. Dec 11, 2018 at 6:18 PM
    Y0TA PR0[QUOTED] likes this.
  27. Dec 11, 2018 at 6:19 PM
    Ok I know how to change oil on my Tundra, but never have I changed the Diffs (Front/Rear) someone wanna give instructions or vid links...
  28. Dec 11, 2018 at 6:22 PM
    15whtrd
    15whtrd Mr. Blonde
    :rofl:I was impressed! That’s dedication.
  29. Dec 11, 2018 at 6:22 PM
    :rofl: gotta take care of my baby
    15whtrd[QUOTED] likes this.
  30. Dec 11, 2018 at 6:24 PM
    Azblue
    1. Loosen fill plug.
    2. Remove drain plug and let old oil drain.
    3. Replace drain plug using new washer, tighten to 36 ft lbs.
    4. Squirt new oil (about 3.8 quarts) into fill until it starts running out, let sit 2 minutes to finish running out.
    5. Replace fill plug with new washer, tighten to 36 ft lbs.
    6. Hang out in the garage for rest of day drinking beer and avoiding wife.
