Alpine X Series - Will they fit in a Tundra?
Discussion in 'Audio & Video' started by Nuclearone, Dec 10, 2018.
  1. Dec 10, 2018 at 9:53 AM
    Nuclearone
    Nuclearone [OP] New Member
    I've watched several speaker reviews about the Alpine X-S69C and X-S65C, and they sound like just what I'm looking for. Crutchfield says they won't fit in my 2019 Tundra, but I found at least one other site that says that they will. Does anyone have any experience with this line of speakers and putting them in a Tundra? Any information would be helpful. Thanks.
  2. Dec 10, 2018 at 10:32 AM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    Does it say they are compatible with the 2018? If so, then you should be good to go. Often times websites are just slow to update their compatibility. Unless I’m mistaken, nothing has changed between the 18 and 19 model years. If you end up buying them, make sure to post up a review for us!
    Rica25 likes this.
  3. Dec 10, 2018 at 10:45 AM
    Rica25
    Ricardo
    Tulare
    Wow they are nice but pricey......also nice ones are by Audison Voce
  4. Dec 10, 2018 at 10:47 AM
    Nuclearone
    Actually, Crutchfield doesn't have the 2019 listed yet. I used the 2018 which, as you said, should be the same. Crutchfield says they won't fit because of depth (3.072" required vs. 2.533" compatible) and major apex diameter (8.766" required vs. 8.699" compatible). Seems to me that this is something you could fix with an insert, but I don't know how much room is between the door panel and where the speaker would be.
    Rica25 likes this.
  5. Dec 10, 2018 at 10:57 AM
    KnuckleHD
    Oh gotcha, in that case I’m not much help, sorry... I would assume that a spacer/adapter would work but I haven’t started my audio upgrades yet so I’m not sure on the space back there either.
    Maybe give them a call and see if someone there knows what up?
    Rica25 likes this.
  6. Dec 10, 2018 at 11:37 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    What the hell are you going to use to power those. If the door speakers are anything like their subs they need a shit load of power to sound good.
    I had a 10" type x that I couldn't ever get to sound right. Threw loads of power at it and a couple different boxes that were made per spec. Ended up selling it......but damn it looked great with the carbon fiber cone
    Rica25 likes this.
  7. Dec 10, 2018 at 2:16 PM
    Nuclearone
    One problem at a time, my friend, lol. If, and it's a big "if", I can actually use the 6x9s in the front, the 6.5s in the back, I'm thinking I might not actually need a sub (for my music anyhow). I'd think that 2 x Alpine PDX-F6 4-channel amps would push 4 woofers and 4 tweeters. This is in no way set in stone, but it's kind of the road I can picture myself driving down. Excessive? Yes. Will that stop me? I doubt it. If I do the install myself, I'm looking at around $2,500-2,600. I've spent more on more useless crap before. But OMG, I bet it'd sound good.
    Rica25 and Mountun Goat like this.
  8. Dec 10, 2018 at 5:13 PM
    Danimal86
    Daniel
    Sacramento, CA
    Just do 6.5" in all 4 doors, swap one 4 channel for a 5 channel and add a 10" sub. Problem solved.
  9. Dec 11, 2018 at 1:50 AM
    Nuclearone
    Nah, I don't think I will. I think I'll continue to try and figure out if I can do what I said in my original post, which I believe will be pretty sweet. I do appreciate your advice, though. I went through your build thread, and it seems like you have a really nice setup yourself. How did the sound-deadening work out?
    Rica25 likes this.
