35 to 37's...
Discussion in 'Wheels & Tires' started by Bulldogs85, Jul 7, 2016.
  1. Jul 7, 2016 at 8:07 AM
    Bulldogs85
    Bulldogs85 [OP] New Member
    Gabe
    2014 tundra Platinum crew max
    6inch stage 1 pro comp, Magnaflow Dual Exhaust, AFE CAI
    Anyone out there running 37's? If so fill me in on your thoughts please. I greatly appreciate it and anyone out there has pictures too. From mileage to any pros and cons about them. I'm thinking about going with Mickey Thompson Baja MTZ 37x12.50x20, on my 2014 crewman tundra, w/6inch s/lift.
    SoCal619 likes this.
  2. Jul 7, 2016 at 8:32 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Pros: They look good. They provide an inch more of clerance over 35s. You learn to stop caring about MPG.
    Cons: They're not 40s. Your speedometer will be ~4mph behind.
    Also be prepared to do some trimming if you plan to actually offroad with your truck.
    SoCal619 and bandit like this.
  3. Jul 7, 2016 at 9:03 AM
    Pros: looks badass!
    Cons: more strain on the trans/engine to push. Are you s/c'd? Re-geared? If not, I would consider that.
    Cost for replacement will be much more when time is due for new tires.
    Ref the speedometer- that can be corrected via the HT speedometer calibrator.
    Rica25 likes this.
  4. Jul 7, 2016 at 9:41 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
  5. Jul 7, 2016 at 9:53 AM
    Spvrtan
    Kris
    San Diego, CA
    Yea, it'll put strain on the truck's moving components overall but if he's not really wheeling it or doing long road trips every weekend he should be fine I think.
    I have 37s with a supercharger at the moment. I'm going to 40s soon with my 7" lift and then will regear after I get those on.
    Rica25 likes this.
  6. Jul 7, 2016 at 9:59 AM
    But on a stock drivetrain and tune, it's going to be rather stressful on it. (Presuming he's stock in that dept)
    Rica25 likes this.
  7. Jul 7, 2016 at 10:00 AM
    Spvrtan
    Kris
    San Diego, CA
    For reference, the blue circle is what I ran on my FJ for 3 years with absolutely zero mechanical problems and the loss of power wasn't significant unless you're comparing it to a brand new FJ. The FJ was loaded with metal bumpers, sliders, skids, roof rack, and so forth. It still drove great even after all the heavy-pedal driving and rock crawling.
    The red circle is where my Tundra is at now. Once I go to 40s, I'll be at the pink circle. Once I regear, I'll be at the green circle. I should be fine running at that end goal, especially with the supercharger. :D
    Lindenwood and Ardnut like this.
  8. Jul 7, 2016 at 10:02 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Better gas mileage if i jump up to 36s....hmm
  9. Jul 7, 2016 at 10:09 AM
    Spvrtan
    Kris
    San Diego, CA
    Do it! What more of a reason do you need? Haha.
    Rica25 likes this.
  10. Jul 7, 2016 at 11:36 AM
    Bulldogs85
    Gabe
    True on that about the MPG...
    As long as it's not my frame?
    Rica25 likes this.
  11. Jul 7, 2016 at 1:42 PM
    Bulldogs85
    Gabe
    Have thought about that before on re-gearing, I currently have my speedometer calibrated set with my 35's. Any good reviews on the Nitro re-gearing kit?
  12. Jul 7, 2016 at 3:26 PM
    Bulldogs85
    Gabe
    My drive way is at an incline
    Rica25 likes this.
  13. Jul 7, 2016 at 3:30 PM
    Bulldogs85
    Gabe
    Thanks for that info. I will be def. looking into re-gearing before I go bigger tires
  14. Jul 7, 2016 at 3:31 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    DOOOOOO IT
    Bulldogs85[OP] likes this.
  15. Jul 7, 2016 at 3:35 PM
    Bulldogs85
    Gabe
    Yes, I want to eliminate straining on my trucks components as much as possible. Don't really go on long hauls except vacation times some hunt trips to our deer lease, work here for me is only 10 or less min away, but still don't want that to stress my truck in the long run.
  16. Jul 7, 2016 at 3:52 PM
    Have you looked into aftermarket programming for tunes?
  17. Jul 31, 2016 at 7:36 AM
    Bulldogs85
    Gabe
    No sir to be honest
