Am I gonna ruin it?
Discussion in 'Suspension' started by OHP, Dec 7, 2018.
  1. Dec 7, 2018 at 6:43 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    2018 Tundra TRD Sport
    Current Mods: JL Audio Stereo System, Truxedo Bed Cover, Console Organizer, Tint, Matt Gekko bed lights, tailgate auto lock, black badges Upcoming Mods: Level, Leather, Remote Start
    I love driving my TRD Sport. It handles, rides, corners, accelerates, and overall drives awesome, especially for a big truck. BUT, I want to install a 2.5"/1" leveling kit and slightly larger AT tires (285/65/18, probably Nitto TG's). Am I going to ruin the handling and ride of my sport by doing this? If there are any current sport owners that have first hand experience with this, I'd love to hear your opinion.
    Thanks
    Mountun Goat and jewsNbrews like this.
  2. Dec 7, 2018 at 6:59 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    raising the center gravity of a vehicle will lower its' cornering capability (as well as having a tire with a taller sidewall). however, overall handling and comfort will be determined by the type of lift that you use. using spacers will give you the worst ride and handling while new coil kits will give you the best ride and handling.
    lifts from worst to best (and generally cheapest to most expensive).
    • spacers
    • shock replacement (such as 5100's)
    • shock and coil replacement (such as 6112's)
    • full coil kit (such as kings, icons, toytec, etc.)
    I have the 5100's at the middle setting and, for my use, they are fine. the ride is a little stiffer than stock, but I don't have any complaints. if I set them at the top setting, the ride might be too stiff and I would be tempted to go with the 6112's or a coil kit (I have used toytec in the past).
    jewsNbrews, Law323 and gm125800 like this.
  3. Dec 7, 2018 at 7:42 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I've considered the 5100's versus a spacer lift. How much front lift did this give you with them on the middle setting?
  4. Dec 7, 2018 at 7:47 AM
    Netmonkey
    Georgetown, TX
    1.57"
    I recommend the 5100's over spacers. the parts cost is a little more, but the install cost should be about the same.
    if you use the top setting on the 5100's, you would get 2.24" of lift.
    RickC, Black Wolf, Boerseun and 3 others like this.
  5. Dec 7, 2018 at 7:50 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    It looks like in your avatar picture, your truck has the factory 20's. Are you getting new wheels too?
    jewsNbrews likes this.
  6. Dec 7, 2018 at 7:51 AM
    15whtrd
    15whtrd Mr. Blonde
    Sorry if this offends anybody with a spacer lift, but I would rather leave it stock than use spacers. Which is why I waited and bought something more worthwhile. Now I’m waiting for my stock tires to wear out before I upgrade. I know you are excited and want that look that you get from a lifted truck. But it’s so much nicer when the lift also performs.
  7. Dec 7, 2018 at 7:55 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    +1. Don't cheap out on this. Spend the extra coin - it is worth it.
  8. Dec 7, 2018 at 7:58 AM
    15whtrd
    15whtrd Mr. Blonde
    My feeling is the entire truck works so well and reliably, anything I replace has to be as good or better than OEM. It gives you a nice warm fuzzy feeling LOL
  9. Dec 7, 2018 at 8:04 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    Buy once cry once.
    I went with King's have have never regretted it... except when the wife saw the cc statement.
    RickC, Rica25, Black Wolf and 7 others like this.
  10. Dec 7, 2018 at 8:07 AM
    15whtrd
    15whtrd Mr. Blonde
    That’s what I really wanted but I just couldn’t swing that bill. Ended up with a used set of pro shocks and springs. They’re not the best out there but it’s a damn good start. We’ll see what happens when these wear out. For my use they work really good and better than the standard off-road shocks.
  11. Dec 7, 2018 at 8:11 AM
    Newm
    Newm New Member
    KC
    I agree with the guys above....do it right once. OP you sound like a guy who appreciates how his vehicle handles and would notice even slight changes for better or worse. I honestly don't think you would be happy long term with a spacer lift. You have a nice rig now...rock that thing stock and just save up for an improvement in both looks and driveability. my .02
  12. Dec 7, 2018 at 8:28 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    Yes. I bought a set of 18" TRD off road wheels that I am going to have powder coated satin black, I think. Also considering an aftermarket 20" but I'm really worried about off set. Don't want them to stick out excessively. Flush or very slightly protruding is okay but I'm not a fan of tires way past the fender wells. No offense to anyone, just my personal preference.
    Thanks for all of the opinions. Been doing some reading and it sounds like the 6112's are the way to go if I want to maintain ride quality and raise the front to level.
    Rica25, DalTee and jewsNbrews like this.
  13. Dec 7, 2018 at 8:38 AM
    mattyd170
    mattyd170 New Member
    Albuquerque, NM
    2020 Tundra Limited Crewmax with Leer shell. Calvary Blue
    TRD Front Suspension, Bilstein Rear, TRD rear sway bar kit, 35" tires, working on stereo.
    I was in this same dilemma a while back. For the money, ride and small investment, Bilstein 5100's are the way to go. Just get a full set, put them in the middle setting for the front, regular shock replacement in rear and you will be golden all the way around. Better ride and control, will feel better than stock and you will be out less than $500 for the shocks. I did the install on mine in my driveway, but I am super mechanical. The ride was WAY better, you can see my posts on it under my profile. I added a single coachbuilder shim on each front 5100 and I have about 1" rake difference between front and back. 381/2" front and 39 1/4 in the rear.
  14. Dec 7, 2018 at 10:41 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    You can level if you want, but the 285/65/18 will fit stock. That's what I run on the TRD off road package. IMG_20180502_152857874.jpg
    Black Wolf and 15whtrd like this.
  15. Dec 7, 2018 at 10:46 AM
    15whtrd
    15whtrd Mr. Blonde
    And it looks good doing it!
  16. Dec 7, 2018 at 10:52 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Stick to 20+- 30+ offset to keep in wheel well or slightly out, no smaller than +20 offset. Size of tires will play a part as well. I have +20 and the are perfect for me, about an inch or two outside the wheel well with 285/65/18.
    15whtrd likes this.
  17. Dec 7, 2018 at 10:53 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    That looks good! Pretty much the exact look I'm going for. You have no lift at all in the front?
    15whtrd and jewsNbrews[QUOTED] like this.
  18. Dec 7, 2018 at 10:59 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    2017 SR5 CM w TRD off road package. No suspension changes. New wheels and tires is all. Removed front mud flap is all that was needed. The one behind the front tire didn't need moved but I did take it off. Fuel trophey 18" +20 offset with 285/65 toyo open country a/t II extreme. IMG_20180503_110203139.jpg IMG_20180503_110237986.jpg IMG_20180502_132830330_HDR.jpg
    15whtrd likes this.
  19. Dec 7, 2018 at 11:57 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    I decided to stick with Toyota wheels to pretty much prevent them from sticking out too far. I thought I'd use spacers if I needed to bring them out a little. However, your pics have almost convinced me to go aftermarket. Thanks a lot for the pics and the info!
  20. Dec 7, 2018 at 11:59 AM
    OHP
    OHP [OP] New Member
    Gallatin, TN
    By the way jewsNbrews, how did you black out your badges? Plasti-dip, the covers available at stealership, other method?
    Thanks
  21. Dec 7, 2018 at 12:03 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    I purchased them all on line. I was going to try and paint the old ones but decided to give away on our freebies thread.
    15whtrd likes this.
  22. Dec 7, 2018 at 12:43 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Still love mine!!!!!!!!!!!!
    Rica25, jewsNbrews and 15whtrd like this.
  23. Dec 7, 2018 at 12:44 PM
    15whtrd
    15whtrd Mr. Blonde
    Steering rack holding up good?
  24. Dec 7, 2018 at 12:46 PM
    Berettafan
    Berettafan New Member
    2017 CM
    yes. you will significantly degrade the ride, handling, acceleration, etc. by doing those things. the weight of E range tires alone will be noticeable.
    15whtrd and jewsNbrews like this.
  25. Dec 7, 2018 at 12:59 PM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    Thats why you wait for your bonus to come in, give her a portion for the house and spend on!
  26. Dec 7, 2018 at 1:02 PM
    15whtrd
    15whtrd Mr. Blonde
    When I bought my suspension I made sure to wash, wax and do all maintenance on her car. Then I bought a lawnmower and other care equipment and fired the gardeners LOL! As well as quite a few other things so that she could see I was being a good boy.
  27. Dec 8, 2018 at 4:15 PM
    DalTee
    DalTee New Member
    Dal
    My buddy has a Ram with his wheels sitting out from the wheel well. That joker looks mean... I drove it and was surprised at how nice it drove. He had his work done at trucktoyz. I am still impressed
    Rica25 likes this.
  28. Dec 8, 2018 at 4:24 PM
    Ntmid8r
    Ntmid8r New Member
    TBA
    Just did mine without a lift. TRD PRO Wheels with 275/70/18 KO2s
    Rica25 and jewsNbrews like this.
  29. Dec 8, 2018 at 4:27 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Mine is on a 3.5” Old Man Emu kit with SPC upper control arms and a sway bar delete. The truck rides on 35x12.5s and feels way more planted and sporty than it did stock. Hands down won’t be driving a stock truck ever again haha. I realize this is a bit taller and larger tires than your asking about but just goes to say if you go about it properly you won’t be disappointed. .02
  30. Dec 8, 2018 at 5:25 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    Stay away from spacers lifts/leveling kits and if all you want is 285x65x18 wheels you can fit those with out lifting the truck. I ran KO2's in that size without a lift for a few years before I upgraded to a mid travel setup.
    5100's, OME, or ToyTec would be a better option for a lift and a 34+-in(295x70x18)/standard 35in tire. If you want to go the next step up you could do a mid travel kit.
    Mountun Goat likes this.
