CB Radios
Discussion in '2.5 Gen Tundras (2014-2021)' started by 540tundragirl, Dec 3, 2018.
  1. Dec 3, 2018 at 8:44 AM
    540tundragirl
    540tundragirl [OP] New Member
    Kimberly
    Botetourt, Virginia
    2014 Tundra Crewmax Limited
    Does anyone have a CB Radio in their rigs?
    I want to see your setups.
    I want to put mine back in mine but not sure how and where to mount it.
    jeremyd, TundraXPLover and Black Wolf like this.
  2. Dec 4, 2018 at 6:22 AM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    This is what I have:
    https://www.amazon.com/Midland-75-822-Channel-CB-Way-Radio/dp/B00000K2YR
    It’s a handheld. I hook it up to a Lil Wilson mag mount:
    https://www.amazon.com/WILSON-305-38-300-Watt-Little-Antenna/dp/B001AAT94W
    I didn’t want to semi-permanently mount and install a CB and antenna, so I figured a more portable setup would do. I’ve only used CBs when off-roading in a group and on long road trips. I’m not sure where I’d mount one in a Tundra if I were inclined to go that route, though.
    dcsleeper408 likes this.
  3. Dec 5, 2018 at 4:02 PM
    curt37
    curt37 New Member
    FRESNO, CA
    2018 Tundra Limited Crew Cab white
    SNUGTOP BED COVER
    I use a magnet mounted antenna with an old radio shack cb and external speaker, I put the cb in the center console.
    Works great and no one can see the radio, even when I tow my travel trailer. :oldglory:
    equin likes this.
  4. Dec 5, 2018 at 4:16 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Being the dirty old truck driver that i am, i do have a CB. Not yet currently in my pickup. It among all other things, has been "slightly modified". I havent decided on mounting location but its between, inside center console or on the outside skirting of the center on passenger side. This is the only pic i have of it.
    G_unit3000 and equin like this.
  5. Dec 5, 2018 at 4:24 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    No, no one runs CB's anymore, we all run HAM Radios better distance and usability over CB unless you are into talking to truckers... and meeting up at truck stops :anonymous:
  6. Dec 5, 2018 at 4:54 PM
    Randy1794
    Randy1794 New Member
    Randy
    Wentzville, MO
    2014 Tundra 1794
    Here is my set-up, unfortunately just as the poster ☝️ said, it’s kind of useless now days. I used it on my last road trip, and it only came to life a couple times. I don’t even think truck drivers use them now
  7. Dec 5, 2018 at 5:33 PM
    I've got a Uniden Bearcat SSB 980 mounted in my 07 center console with Firestik antenna mounted out front for best reception and minimal VSWR. SSB, Single Side Band, CB gives you more options. Not sure if you can mount a CB in the "2nd" Gen center consoles. Taking my Ham radio test in February so the Uniden will be complemented with a Ham radio too...
    jeremyd and equin like this.
  8. Dec 5, 2018 at 5:46 PM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    I run a big peaked and tuned Cobra 29 Classic in my big truck. Not made the move to put a CB in my Tundra yet. CBs are very handy and a REAL trucker will have a CB. A lot of your bigger companies prohibit CBs in the big truck. CBs are very useful to communicate to other truckers about road hazards, etc.
  9. Dec 5, 2018 at 9:35 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I've got a Galaxy DX 33HML mounted to the sunglass holder thingy in my 16 DC.
    IMG_4496.jpgIMG_4421.jpg IMG_5111.jpg 30073674_10155142980376353_8858766892104696738_o.jpg 30073102_10155142980501353_7055119956727716567_o.jpg IMG_5308.jpg
  10. Dec 6, 2018 at 3:20 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I had a CB back in the late '70's. Surprised to hear that people still use them.
    texasrho83 and Fishman57 like this.
  11. Dec 6, 2018 at 6:41 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I had them in all my old 70s model pickups and couldn’t wait to put it in this newer ride. I love having a CB - best traffic report when you hit a back up on the highway. Also good for smokies
  12. Dec 6, 2018 at 8:13 AM
    plumber802
    Andy
    Vermont
    10-4 good buddy!
  13. Mar 5, 2019 at 7:50 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    What ham radio @papasmurf do you recommend to use? Don’t want to mount a radio just want to communicate with other drivers when we are all in a group and don’t have phone service.
  14. Mar 5, 2019 at 9:37 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Ok so CB’s are a waste let’s start there... but a ham handheald is a good start or base station but that’s more perm and expensive... I run a kenwood ta-281a for base station it’s only single channel because generally we stay on a primary channel and don’t need to monitor a second channel, also it’s 65watt base over normal 50watt like most dual and single channel ham radios... so w a good antenna and mount I have crazy good distance w it! I also have a beaufang handheald which works great for most situations it’s a 8watt i believe and I paid 40$ for a kit that has radio, battery, extra battery, two antennas, A charger and car charger ... so I’d say start there.. as an option I can provide a Amazon link if you would like? Start w handheld and move to a base station later when you are ready and the handheld becomes a backup and good for spotting etc
    Darkness likes this.
  15. Mar 5, 2019 at 9:41 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
  16. Mar 5, 2019 at 9:59 PM
    brownmike
    brownmike New Member
    '17 CM 4x4
  17. Mar 6, 2019 at 2:59 AM
    NH2BV
    NH2BV Daily drivers!
    Las Cruces, NM
    2024 Tundra TRD Off Road
    Rock Stock OEM beast
    I have an FT-8800 in the truck with a remote head setup. I use my Boefeng 9+ to crossband (into the 8800 on the 440Mhz band and out on 2 meters) into it to extend range while out wandering from the truck. Most repeaters that are out there are on 2meter bands so it works great for both the crossband. CB radios may be plentiful, but you are only as good at getting out as the set up.
    Don't forget, when operating on the amateur radio frequencies, you must be licensed. It is much easier than you think. Just go to QRZ.com and look for the practice tests. Take the technician test a few times to get some exposure to the test and the ham requirements and you will easily pass an exam session with the local ham club. You will have to google that for your area.
    NH2BV
    Sunnier, Black Wolf and KELZ84 like this.
  18. Mar 6, 2019 at 8:44 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Or don’t take the test... and operate in public open channels and tell ham nerds to try and find you through triangulation while doing 80mph through a desert... good luck nerds!!!
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Btw I’m a navy comms operator so clearly I have knowledge and experience w mobile comms for almost 20 years of service .... I’m just soooo tired of hearing ham guys press on off-road guys about getting ham license’s when we use vhf minimum range radios sold commercially ...
  19. Mar 6, 2019 at 8:49 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    @papasmurf thats all i want To use it for off road and distances we loose service i have no need to operate on open roads. Does the test cost money or what’s it about?
  20. Mar 6, 2019 at 8:52 AM
    Racingjohndeere55
    Racingjohndeere55 New Member
    What frequency can you use with just a tech licence? Long time cb'er time to move up. About the only thing I know about is the Stryker 10m. I'm assuming that's a ham license?
  21. Mar 6, 2019 at 9:02 AM
    Cement
    Cement ...
    2019 Cement Trundra TRD
    Except that you're "breaking the law". And there are people out there with literally nothing else to do but hunt you down. Yes they can, and do. Seen it myself. Its a sport for them. A hobby. They keep track of "kills"...
    Now before you go all nutz with the keyboard, stop :p I get it. I'm licensed but also I'm not a snob about it. I think generally you'll find most causal ham's feel the same. Don't abuse it, don't walk on others, don't be a dick, etc. And you'll be fine. But do understand you're operating illegally.
    BTW: Baofeng just came out with an 8w version of the UV-5R. And also BTW, these UV-5Rs can physically do GMRS/FRS/MURS out of the box. Just make sure you limit the transmit power to the "legal" levels ifnwhen you decide to use 'em "illegally" on those freqs...
    https://smile.amazon.com/gp/product/B07F6NRMMC/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
    Black Wolf and GodlessPro like this.
  22. Mar 6, 2019 at 9:06 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    This is all Chinese talk lol
    Medinasmoke and Darkness like this.
  23. Mar 6, 2019 at 9:08 AM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    Rather buy a damn walkie talky hahahah
  24. Mar 6, 2019 at 9:11 AM
    Cement
    Cement ...
    Darkness and Black Wolf like this.
  25. Mar 6, 2019 at 9:14 AM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    :worthless:
    :crapstorm:
    JSTUNDRA76 and KELZ84 like this.
  26. Mar 6, 2019 at 9:20 AM
    DividedSky
    Jeff
    Oh really? If so, I'm totally in!! Is it a true 8W though?
    I have a UV82-HP which is "rated" at 8w but in reality isn't.
    Amazon Review of UV82HP:
    Unit does not perform to expectations/specifications. Has additional odd behavior. Advertised as a high power version of the UV-82, the manual claims that the power output is 8 watts VHF, and 7 watts UHF. Tested two units. The first had a power output of 5 watts VHF, and 4 watts UHF on both medium and high power settings. Contacted seller who advised that testing must be done with a dummy load. Purchased and retested dummy load with same results. Purchased second unit in case of fluke. Second unit tested at about 4 watts VHF, and about 3.5 watts UHF. Tested both units with full battery. Additional issues: Internal power supply does not appear to be regulated causing power output to be proportional to battery state of charge. When reading the battery voltage on unit, some noise gets introduced into any audio output which may be occuring at that time. Exhibits odd behavior on Low power as well: power output is specified 1 watt until the backlight times out, which seems to correlate with a drop in output to 0.75 watts. For comparison a Pofung UV82 also recently purchased via Amazon outputs about 5 watts VHF, and 4.25 watts UHF on high power setting.
  27. Mar 6, 2019 at 9:22 AM
    Cement
    Cement ...
  28. Mar 6, 2019 at 9:25 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    Trust me I totally get the breaking the law part ... I’m not too worried about the FCC and people who have a hardon for busting guys for illegal ham use when I regularly carry concealed in places that are frowned upon by law... my point is yes I’m aware of Ham guys who have a thing for finding guys like me.... we don’t step on people have good comms discipline and stay away from things like GMRS etc.. so I risk it... and I may actually have a license just won’t mention my call sign because reasons
    Cement[QUOTED] likes this.
  29. Mar 6, 2019 at 9:29 AM
    Cement
    Cement ...
    We're totally on the same page @papasmurf. Just commenting for the 'general audience'. You understand ;)
    @DividedSky One comment on expected vs actual. These radios are counterfeited more than paper money (the Chinese ripping off their own? Whodu'thunk it?). It could be you've got one of those counterfeits, or it could be its real and overrated. Who knows. But if you're looking to pick up one of these new 8w UV-5Rs, get the Mirkit version. They're a legit US distributor that guarantees authentic stuff. Best as I can tell, anyway.
    papasmurf likes this.
  30. Mar 6, 2019 at 9:30 AM
    DividedSky
    Jeff
    Oh... and btw, KM6WCK QSL QSL
    West Texas Tundra likes this.
