First Toyota Owner
Discussion in 'New Member Introductions' started by Rockbuggie, Nov 19, 2018.
  1. Nov 19, 2018 at 4:36 PM
    Rockbuggie
    Rockbuggie [OP] New Member
    Jake
    07 Tundra white
    Pre runner fenders, custom wheels on 35 inch tires
    Traded my 99 cummins for this 07 Toyota Tundra. Has alot of check engine lights on . 4lo, engine light,traction control and a exclamation thats red. Runs fine without any problems. Also have alot of whinning coming from the front end not sure if its just the 35s or something else. IMG_20181119_172711_545.jpg
  2. Nov 19, 2018 at 4:48 PM
    FXFormat
    FXFormat New Member
    Welcome! Get a scanner and see what the CEL is on for, disconnect the battery for 10 minutes and then put it back and see if the traction control light go away or not. When i did my tune up, i unplugged the MAF sensor and forgot to put it back and started the truck and all the lights lit up like a christmas tree, cleared it and it went away.
    Which motor do you have? I'm not digging that front bumper to aftermarket misalignment. The whining could very well be the tires, if not, then wheel bearings.
    Rockbuggie[OP] likes this.
  3. Nov 19, 2018 at 4:51 PM
    Rockbuggie
    Jake
    07 Tundra white
    Alright cool deal, and yea i hate the way the bumper doesnt fit with the fenders. And it has the 5.7 in it!
    Pinay likes this.
  4. Nov 19, 2018 at 4:55 PM
    FXFormat
    FXFormat New Member
    Nice! Very capable truck, check for the water pump leakage, known issue with these trucks, how many miles are on her?
    Pinay and Rockbuggie[OP] like this.
  5. Nov 19, 2018 at 5:00 PM
    Rockbuggie
    Jake
    07 Tundra white
    Alright, and 140k
    Pinay likes this.
  6. Nov 20, 2018 at 1:23 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I've tripped a bunch of lights on my 2010, by not getting the Gas Cap tight enough, (too deaf to hear the click). If you fill the tank while the truck's running, that may do it too :confused:
  7. Nov 20, 2018 at 1:27 AM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO.
  8. Nov 23, 2018 at 5:17 AM
    dw8494
    dw8494 New Member
    Welcome, look forward to knowing what codes and the how you fixed them.
  9. Nov 23, 2018 at 5:18 AM
    Welcome from NY.
  10. Nov 23, 2018 at 5:47 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  11. Nov 23, 2018 at 5:49 AM
    Steve6
    Steve6 New Member
    Tucson
    Welcome from Arizona.
  12. Dec 4, 2018 at 1:36 AM
    Rockbuggie
    Jake
    07 Tundra white
    So i had the Codes checked and they all came back to Gas Cap . Which i found a small leak at the break point on the filler neck. Its going to the shop soon. Got a Wheel bearing Humming. Overall loving this truck. About to upgrade to different wheels and go up to 37s
    4x4_Angel likes this.
  13. Dec 4, 2018 at 4:28 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Nice truck!
  14. Dec 4, 2018 at 4:30 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
  15. Dec 4, 2018 at 6:25 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX! Great year!
  16. Dec 4, 2018 at 6:52 AM
    Tundrablue
    Dave
    Ohio
    Welcome from Ohio
  17. Dec 4, 2018 at 6:53 AM
    TXRailRoadBandit73 YOTAS,RAILROADIN',RĂ–KnRĂ–LLN',BEER,MAX/GEMMA
    Welcome from Texas
  18. Dec 4, 2018 at 7:06 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas ⛽️
    Rafael
    2017 TRD PRO
    WELCOME
  19. Dec 4, 2018 at 7:16 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    Welcome!
  20. Dec 4, 2018 at 7:48 AM
    Welcome
    Pinay likes this.
  21. Dec 4, 2018 at 9:01 AM
    Welcome from Ohio!
    Pinay likes this.
  22. Dec 4, 2018 at 9:03 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    welcome from Texas!
    Pinay likes this.
  23. Dec 4, 2018 at 6:23 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
    Pinay likes this.
