295 55 20
Discussion in 'Wheels & Tires' started by grgrypaul, Sep 6, 2018.
  1. Sep 6, 2018 at 10:27 AM
    grgrypaul
    grgrypaul [OP] New Member
    Paul
    2018 Tundra crew limited
    Anyone running 295 55 20 on stock rims with level kit?
  2. Sep 6, 2018 at 11:32 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    295/55/20 ridge grapplers on 20x9 +50mm offset wheels with a 1.5" lift in the front:
    Squig and parker44 like this.
  3. Sep 6, 2018 at 11:48 AM
    MGM!
  4. Dec 4, 2018 at 3:51 PM
    DHart
    DHart New Member
    Newbury Park, CA
    2014 Platinum Tundra
    Bilstein 6112 top setting w/ 1 CB .25 shim driver-side Camburg Uniball Upper Control Arms Bilstein 5160 rear w/ 1" block (soon 1.5 Camburg shackles) TRD Pro Wheels 35x12.5x18 Toyo Open Country AT2 1.25" wheel spacers AMP steps Roll-N-Lock tonneau cover TRD Pro Grill
    What lift did you go with?
  5. Dec 4, 2018 at 4:22 PM
    TundraXPLover
    TundraXPLover New Member
    Clif
    NC
    2018 CM 4x4 XP
    No rubbing???
  6. Dec 4, 2018 at 4:31 PM
    Netmonkey
    Georgetown, TX
    no rubbing. just removed that little front spat. i probably could have fit 295 60 20's with some trimming.
  7. Dec 4, 2018 at 4:34 PM
    TundraXPLover
    Clif
    NC
    2018 CM 4x4 XP
    That is awesome. I did a 3/1 kit and still have the 275/55/20s on it. I think I am going to do the 285/60/20 when I wear these out.
    I am surprised that the 295s didn't cause you more trouble. That's great!
    Netmonkey[QUOTED] likes this.
