  1. Dec 1, 2018 at 7:30 PM
    FoghornTX
    FoghornTX Proud American and Infidel since 1968
    Ft Worth, Texas
    2022 Camry XSE (Black w/blackout package)
    LED headlights and Morimoto LED fogs installed on my 2018 SR5 CM.
    The headlights are pretty easy, just follow the video that we've all seen to take the grill out and then the painted pieces out that are below the headlights. If you've got TSS like I do on my 2018, you'll need to unplug that connection before you try to remove the grill. There's a little Toyota stamped removable square to the right of the hood latch. See the two pictures below.
    Fog replacement can be somewhat of a pain in the ass due to the cramped area and the removal of the front portion of the wheel well liner. My 2018 had two 10mm screws inside to remove along the edge, one of those plastic push rivets on the far inside of the wheel well, and then two 10mm screws and two 12mm screws underneath.
    When you're taking the small front piece wheel well liner out, you'll have to deal with the bracket that holds it in on the outside edge. You only see the outside parts of the bracket. The majority of the bracket is on the inside of the wheel well liner. Once you take out the two 10mm screws and the four bottom screws, slip something between the bracket and the truck just enough so that you can slide the bracket out with the wheel well liner out. If you don't, you'll snap that bastard off on the inside and it'll fall to the bottom of the bumper. I think that I saw that happen in a video. I actually got lucky and had the headlights out while I did the Morimotos. Noticed that the bracket was one piece that held the wheel well liner.
    The last part is pinning the Morimotos correctly. See picture below for correct pinout.
    That's about it. I had to align my headlights afterwards using the 25 foot instructions from Headlight Revolution.
    I'll add that you can use a drill to remove all the 10mm screws. But if you use a drill to put them back, put the drill on the lowest torque setting that your drill has. I'm talking the number one setting. Anything else and you could strip out the plastic nut/grommet. I would suggest using a ratchet to put them all back, including the two underneath the bumper for the fog replacement.
    https://youtu.be/uz0yRCyTP2w
    Thanks to @Roman for the LED headlights and @Headlight Revolution for the Morimotos.
  2. Dec 1, 2018 at 7:31 PM
    Donski17
    Donski17 New Member
    Donald
    Jacksonville, FL
    2017 Blazing Blue Tundra 4X4
    Thanks, it’s an awesome mod and pretty affordable all things considered. Definitely worth doing!
  3. Dec 1, 2018 at 7:49 PM
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    Same here, except I'm going back and forth on 19 pro and retro still. I do the same, use my BD squadrons as a high beam that I can turn off when people get pretty close without blinding them. The BD S8 I use as a longer range high beam when I'm alone on road. That 1 I turn off before I even go around a corner just in case. The fogs I can be more lax with, if I dont turn off before passing someone the other way it's not the end of the world. The s8 is much less forgiving so I'm extra careful. I've gotten really good at turning on and off the s8 with a push button switch to left of wheel blank, and the fogs on the stalk. I can turn both on and off within seconds with my eyes closed just based on repetition. Love my setup so.far, just wish I had a little better regular low beam headlight light. It's a million times better with HR led replacement than stock halogen in 16 pro housing, but still I yearn for better.
    Watt maker likes this.
  4. Dec 1, 2018 at 8:20 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    holy hell....That's quite a haul. How much did all that set you back?
  5. Dec 1, 2018 at 8:58 PM
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    Pudge[QUOTED] likes this.
  6. Dec 1, 2018 at 8:59 PM
    lionix
    Did you have to drill the roof?
  7. Dec 1, 2018 at 9:02 PM
    lionix
    19 pro is my vote.
  8. Dec 1, 2018 at 9:33 PM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Congrats!
  9. Dec 2, 2018 at 4:47 AM
    bppclermont
    bppclermont New Member
    Clermont
    2018 Cement Tundra TRD 4x4
    Gator bed cover, 275/70/R18 Cooper Discover AT3 XLT tires, TRD wheel center caps
    Donski17 you're one step ahead of me...the CAI and BAMuffler are next for me...did you install the resonator with the exhaust?
  10. Dec 2, 2018 at 5:26 AM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
    Yesterday-We have a big doe bedding down in our rhubarb patch, so I hauled some hay and setup a big ol bed for her with a mineral block, then ran the truck thru the touchless wash and rolled up the tonneau to dry up the bed. aAnd today we got rain..
  11. Dec 2, 2018 at 5:44 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Got my parts from CoolSpings but am disappointed that the 2019 TRD Pro Grill did not come with the Hood bulge and only the grill by itself. I was under the impression that the 2019 TRDPro grill would be the same package as the 2017TRD Pro and come with the bulge. To my disappointment it does not and now I have to spend extra Money and wait longer to get my grill set up. Wish this was disclosed in the original thread. Also, ordered my harness from Headlight revolution about a week ago and that still hasn’t come in yet. I guess this is the drawback from ordering things on Black Friday and in general not using Amazon to buy online.
    Sometimes ones has to look at the ROI when it comes time for discounts and the vendors ability to meet the demand of those offered item on time and with quality service.
  12. Dec 2, 2018 at 6:24 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Unless you bought a special package deal, the bulge and grill have always been separate parts.
    NewImprovedRon likes this.
  13. Dec 2, 2018 at 8:59 AM
    XLTaco
    XLTaco New Member
    '21 SR5 DC 4x4 Cement
    How'd it go transferring the TSS stuff transfer over to the new insert? I just got my Limited and this is one of the first things I want to do.
  14. Dec 2, 2018 at 9:02 AM
    fishing guy
    fishing guy New Member
    Billy
    2017 White Platinum 4x4 Tundra
    N/A
    Looks great! have you thought about removing the black pillar tape? (white underneath)
    OR18TRD[QUOTED] likes this.
  15. Dec 2, 2018 at 9:09 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Looks good. How hard was it t ok put the mirror caps on?
  16. Dec 2, 2018 at 9:17 AM
    HamHands
    HamHands Honey-Glazed Member
    2018 Tundra DC MGM SR5 5.7 TRD 4x4
    Before:
    After:
    :cool:
  17. Dec 2, 2018 at 9:37 AM
    Donski17
    Donski17 New Member
    Donald
    Jacksonville, FL
    I've not put the resonator yet. I want to drive it for a week or two and see if I notice any drone first.
    bppclermont[QUOTED] likes this.
  18. Dec 2, 2018 at 9:46 AM
    mrburns05
    mrburns05 New Member
    Jacob
    Menifee CA.
    2018 4.6L White DC SR5
    Maxtrac 3.5” Spindles Bilstein 6112 Icon AAL Icon 2.5” PB shocks Coachbuilder +1 Shackles AFE dry filter TRD AIA Magnaflow muffler TB Coolant Bypass
    I’m considering purchasing this. Could you comment on how bright/ effective the light is?
  19. Dec 2, 2018 at 1:53 PM
    Cthulhu
    All depends on whether or not you decide to retain the factory black grill. The grill does diffuse the light a little, but I still consider it bright enough to where you still wouldn’t drive down the road with it on; strictly offroad. Without the grill, forget about it, super bright for offroading only. I hope that helps.
    mrburns05[QUOTED] likes this.
  20. Dec 2, 2018 at 1:54 PM
    mrburns05
    Jacob
    Menifee CA.
    That helps a lot! Thank you
  21. Dec 2, 2018 at 3:16 PM
    Nickj619
    Nickj619 New Member
    San Jose, ca
    2014 tundra trd crew max
    Debadged and installed platinum running boards today, going to be deleted more chrome as I go on C465FAF8-8474-4B96-AC9B-7ABF93AA7E71.jpg
  22. Dec 2, 2018 at 3:51 PM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
    put in the 6112s today. second setting. Not too bad a process. Better picture in AM. Drives smoothed than spray butter.
  23. Dec 2, 2018 at 6:05 PM
    cjmay13
    cjmay13 New Member
    Corey
    Indiana
    2017 Toyota Tundra TRD Pro Cement Gray
    None Yet.
    Anybody know if BFG quit making their KO2s in a 295/70R18? I can't find that size or 285 anywhere. Thanks for the help.
  24. Dec 2, 2018 at 7:03 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I installed my ToyTec/5100 combos, wheels and tires, and X-pel wrapped the bottom.
    Started working on my TRD exhaust but ran out of paint. BF41E12F-1167-44D2-9D74-E569568FC43C.jpg4AE2D1B1-F834-4E11-95DC-08553143A7DB.jpg3B4A3DD5-606B-43CD-9CF0-0155D1527789.jpgF8079070-AA48-4C67-A013-3C8ADCD800D7.jpgC8406D5A-7341-4A9F-AA6F-57C220A5EAAF.jpg3DA2E9F7-ABBA-413B-9083-3BB5415DD182.jpgAB2BAA80-4500-4A37-BBC5-159371CF9757.jpg2B9B48D4-A5DA-4B4E-BB37-5955EC12C76C.jpg
    16TRD, OR18TRD, r1-superstar and 11 others like this.
  25. Dec 2, 2018 at 7:16 PM
    Guhner123
    Guhner123 New Member
    Gunner
    2017 Tundra SR5 MGM
    Toytec/Eibach 3/1 lift kit 295/70/18 TOYO AT 18 Inch Method NVs
    Finished up my bed storage box. I love having the extra storage. And I still maintain a lot of bed space.
    TokerJoker, OR18TRD, Ostrich and 5 others like this.
  26. Dec 2, 2018 at 7:25 PM
    lionix
    You have any problems drilling the roof? I am really afraid to do it, but I want the roof rails.
  27. Dec 2, 2018 at 7:33 PM
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    We had sunshine and 60's here today. Sooo, I installed my Extang Solid Fold 2.0 tonneau, put my color matched handles and mirrors on. Also, I know, it's dirty.
    Handles Before:
    Handles After:
    Mirrors:
  28. Dec 2, 2018 at 7:35 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    high tech, easily removed.
  29. Dec 2, 2018 at 8:13 PM
    fishing guy
    Billy
    N/A
    Absolutely beautiful!
    Omohundro[QUOTED] likes this.
  30. Dec 3, 2018 at 5:06 AM
    2015Crewmax
    2015Crewmax New Member
    Cory
    Centennial, CO
    15 Crewmax
    BOSS 4x4 3" Lift kit, TRD Swaybars, TRD dual exhaust,
    33x12.50R20 with 2" spacers on factort wheels. only had to remove the front bumper flap. I will need to trim the metal skid plate. Low road noise and great ride!!
