Finally a no mess oil change!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Berettafan, Dec 1, 2018.
  1. Dec 1, 2018 at 12:45 PM
    Berettafan
    Berettafan [OP] New Member
    2017 CM
    DIY'rs will know these motors flow oil like a tidal wave. In my case the drain pan things I use have a solid top with a drain hole. easy to move around without spilling once full. Negative is the oil splashes all over the front right wheel and then the ground. NOTHING in the front right area of my truck will ever rust.
    So I got tired of that crap and today figured out a better way. I used one of those plastic storage bins we keep clothes and Christmas decorations in. wife won't be too happy but my front right brake is not soaked in motor oil for the first time.
    The bin is huge and barely fit under the truck. actually kinda wedged in there but it fit.
    15whtrd likes this.
  2. Dec 1, 2018 at 12:52 PM
    15whtrd
    15whtrd Mr. Blonde
    I use a milk jug with the bottom cut out at an angle. Like a large funnel to contain the initial flow.
  3. Dec 1, 2018 at 12:52 PM
    KnuckleHD
    KnuckleHD New Member
    2018 Tundra CM Limited- Cement
    I use a Walmart special mop bucket. It’s slightly oval so it catches the oil better. It also has a spout to make transfering the old oil easier. When it’s done draining, I just pour it into my oil container. Has worked pretty well so far. But I agree, it does come out fast and at an awkward angle.
  4. Dec 1, 2018 at 12:55 PM
    stealth09
    stealth09 New Member
    Canada
    Black Wolf and Ericsopa like this.
  5. Dec 1, 2018 at 1:56 PM
    Stig
    Stig New Member
    Didn't know anyone that does their own changes still use standard drain plug bolts. First oil change on all my vehicles gets changed out to a valve.
    Black Wolf, Ericsopa and texasrho83 like this.
  6. Dec 1, 2018 at 2:21 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
  7. Dec 1, 2018 at 3:36 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
  8. Dec 1, 2018 at 3:36 PM
    KnuckleHD
    I’ve been looking into the Fumoto valve. I know a lot of people run them without issue but there’s just something unsettling about the fact that it could be pushed open on accident. I know they make some type of lock for it but still. Removing/ installing a drain bolt and new washer only takes a minute and it’s piece of mind.
    Ronin, rodm1 and Blueknights75 like this.
  9. Dec 1, 2018 at 3:52 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Most often they come with a plastic retaining clip that acts as a secondary "safety." I'm not running this part on the four Fumotos I have on various vehicles and have no worries. Fumoto valves have about 25 years of development on them. Without a doubt the worry related to these awesome devices would be operator error.
    BTBAKER and Black Wolf like this.
  10. Dec 1, 2018 at 6:10 PM
    Stig
    Stig New Member
    There's really no way for them to open without someone doing it by hand. I have them on all my vehicles even my motorcycles. If you're concerned about it opening by accident, you should also be concerned about your Schrader valves on your tires opening.
    Tundras even have the skid plate covering it.
    Black Wolf and KnuckleHD[QUOTED] like this.
  11. Dec 1, 2018 at 6:23 PM
    Cfincke
    Cfincke Mall Crawler but capable
    San Antonio
    2014 Tundra 1794 CM 5.7 4x4 sunset bronze
    5.29s, Auburn LSD, 37x12.50R18, Icon coilovers and shocks, SPC UCA's, Tech 12 Volts sound system, Enve Grill
    Have had the fumoto valve on for 40k miles without issue.
  12. Dec 1, 2018 at 7:37 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Ive had the same reservations for over a year. I’ve done enough research and read enough good things that I feel comfortable going with one.
  13. Dec 1, 2018 at 9:45 PM
    KnuckleHD
    Yea that’s awesome. I have the drain kit for the filter and it’s great. Is there an adapter for the Fumoto valve to use the drain tube? Anyone have a link for that?
    If I get the valve I definitely want to use the drain tube as well.
  14. Dec 2, 2018 at 6:16 AM
    Stig
    Stig New Member
    Just go to your local hardware store with the valve and find the correct size tubing.
  15. Dec 2, 2018 at 6:18 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    Right here Chief >>>> https://www.fumotooildrainvalve.com/
    You're describing the N Series. N is for nipple. (he said nipple).
    Rica25 and bmcdds like this.
  16. Dec 2, 2018 at 7:06 AM
    Professional Hand Model
    Fred
    Hand Protectors
    Savings Check is in the mail.
  17. Dec 2, 2018 at 7:09 AM
    Fred
    Hand Protectors
    Seems like a nice option for you non-1st gen’rs. How long does it take to let ALL the oil out of that small orifice on the Fumoto? I go crazy waiting with just a standard plug.
  18. Dec 2, 2018 at 7:20 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Then you would likely snap with the Fumoto installed.
  19. Dec 2, 2018 at 8:06 AM
    bmcdds
    bmcdds New Member
    CA
    2019 Barcelona Platinum
  20. Dec 2, 2018 at 8:15 AM
    Same here
  21. Dec 2, 2018 at 9:20 AM
    Cfincke
    San Antonio
  22. Dec 2, 2018 at 9:27 AM
    PA452
    PA452 New Member
    2021 Tundra SR5 CM TRD O/R
    I don't know anyone outside these forums who does use one. In fact any time I've brought them up to people in person, no one has ever heard of them.
    Not saying there's anything wrong with them, just saying I don't think they're all that common.
  23. Dec 2, 2018 at 9:28 AM
    PA452
    PA452 New Member
    My skid plate does not cover the drain plug. If it did I'd give it more consideration.
    jerzeedivr, TTund16 and 15whtrd like this.
  24. Dec 2, 2018 at 9:35 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I completely disagree with this statement. Do some research. Google is your friend. You will find they are much more common than you think.
  25. Dec 2, 2018 at 9:37 AM
    PA452
    PA452 New Member
    And I'm telling you I have yet to find anyone who changes their own oil in person who uses one. I don't need to research anything, don't care. I'm just telling you plenty of people who change their own oil don't use them.
  26. Dec 2, 2018 at 10:11 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Ok, got it. Your small circle of people that don’t use one tell the story.
    If you’re on the fence and base a decision on that then by all means stick with the plug. I don’t use one but I’m not naive enough to think that discussing with people I run into and change their own oil is a good marker of a product.
  27. Dec 2, 2018 at 10:17 AM
    PA452
    PA452 New Member
    Go back and read my post. Google is your friend if you need some help with English.
    ETA: I'll help you. Just because people don't use something, doesn't mean it's a bad product. Doesn't even mean they think it's a bad product. It means I was disputing that everyone who changes their own oil uses a Fumato. Plenty don't.
    B737 likes this.
  28. Dec 2, 2018 at 10:26 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Chill gents. One of you knows people outside forums that uses a Fumoto, the other doesn't.
    Let's move on!
  29. Dec 2, 2018 at 10:30 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    It’s good bro, I’m not chasing that path.:thumbsup:
    MotoTundra[QUOTED] likes this.
  30. Dec 2, 2018 at 10:37 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Last time I changed my oil I put my truck up on ramps and let it sit for over an hour. It was a much cleaner change than pulling the plug when the oil was hot. When oil is warm in these trucks it’s a mess. I’ve always heard to change oil when it warm/hot but I’m not sure it makes a difference so long as you let it drain completely.
    MotoTundra likes this.
