Steering torque- Nissan Maxima
Discussion in 'Off-Topic Discussion' started by Les7311, Dec 1, 2018.
  1. Dec 1, 2018 at 7:04 AM
    Les7311
    Les7311 [OP] Look up, what do you see
    2008 Blue Tundra TRD 4x4
    need your expertise forumites!!!!
    2011 maxima, 159k miles
    A year back I installed all new struts, out rods, shocks, LCA.
    Two weeks ago I replaced all four tires then get alignment
    Now: am having a severe torque steer to the right. Any touch to the accelerator the car can move a foot in lane while holding steering straight. Get off pedal and it treck straight.
    Where should I start looking for my DIY?
    I can comment more as the response are flowing
    Help!!
  2. Dec 1, 2018 at 7:05 AM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    This started after the alignment?
    If so, take it back to that shop and raise hell!
    Les7311[OP] and Black Wolf like this.
  3. Dec 1, 2018 at 7:08 AM
    ^^^^If so, take it back.....<<<<<<<THIS
    Squatting Pigeon likes this.
  4. Dec 1, 2018 at 7:18 AM
    Les7311
    This is the upper engine mount. See that hairline crack??? Could this be the culprit? Don’t mind doing this surgery...
  5. Dec 1, 2018 at 7:24 AM
    Les7311
    Zoom in and see crack on mount, one over the passenger wheel. Could this be the culprit?
  6. Dec 1, 2018 at 8:14 AM
    Squatting Pigeon
    Holden
    North Texas
    You mostly just get excess vibrations from bad motor mounts, that shouldn't be making the car pull to the right under acceleration.
    That mount should be replaced anyway though.
    Since the car is FWD, I'd imagine something is up with a CV axle.
    I'm no expert on FWD cars, but more power may be going to one than the other when you hit the gas.
    Les7311[QUOTED][OP] likes this.
  7. Dec 1, 2018 at 11:40 AM
    Les7311
  8. Dec 1, 2018 at 11:43 AM
    Les7311
    All that real estate light showing is a fully worn and damaged torque strut mount. That said, I will have to replace the other 3.
    The car drives a lot better, however I do feel a slight pull, not as aggressive as before.
    More surgery.
    Conclusion, Them darn mounts!!!
