VLED BF sale!
Discussion in 'Deals & Group Buys' started by BlueBottle, Nov 20, 2018.
Thread Status:
Not open for further replies.
  1. Nov 20, 2018 at 10:00 AM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    get your lights! I have no affiliation with VLeD. Just a happy customer.
  2. Nov 20, 2018 at 10:12 AM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Thanks mike <3
    BlueBottle[OP] and Rica25 like this.
  3. Nov 20, 2018 at 11:58 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Ruh row......
    Anyone run switchbacks in their running lights? I've got retros with Halo and strips, might be cool to add a switch back.
  4. Nov 20, 2018 at 12:00 PM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    I forgot I wanted these till now, thanks!
  5. Nov 20, 2018 at 12:45 PM
    Danimal86
    Daniel
    Sacramento, CA
    I also think the Triton's aren't a bad deal. Seems like they are really expensive, but they are priced as a pair vs the others are per bulb.
    BlueBottle[OP] likes this.
  6. Nov 20, 2018 at 1:30 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have the $25 signals(each) on my other car and they are actually very bright. For signals I wouldn’t bother w the tritons.
  7. Nov 20, 2018 at 1:35 PM
    Danimal86
    Daniel
    Sacramento, CA
    I was thinking about the Triton's for the brake lights.
    I have them in my commuter car and they are great.
  8. Nov 20, 2018 at 1:38 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  9. Nov 20, 2018 at 1:43 PM
    Danimal86
    Daniel
    Sacramento, CA
  10. Nov 20, 2018 at 1:44 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I meant if you were to use tritons as signals. You are correct no resistor needed for brake lamps.
  11. Nov 20, 2018 at 2:08 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
  12. Nov 20, 2018 at 2:34 PM
    Danimal86
    Daniel
    Sacramento, CA
    Thanks! Those definitely look plenty bright!
  13. Nov 20, 2018 at 5:26 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Bak Revolver, BedRug, Undercover Swingcase, PopLock, Bilstein 5160(rear), Firestone RideRite, TRD rear sway bar, Coachbuilder +2 rear shackles, Andersen 5” aluminum adjustable hitch, TRD dual exhaust, VLEDS interior leds including the footwell kit, TundraTex FRAC mod, VLEDS LPR backup tag mount led, Husky X-Act mats, Color matched cup holder bezel (silver), Ceramic 20% tint all around, 50% Ceramic windshield, Color Matched door handles & mirror caps, The “Stubby” antenna, AMP Research steps, VLEDS 6”step lights, ToyTec/5100 Bilstein coil overs, 700lbs red ToyTec springs (2.75” lift), 20x9 +18 Method 306 custom painted and custom fit center caps, Gorilla spline lugs, Bridgestone Revo 3s 285/60R20, TRD skid plate, RaptorLiner “Red” tow hooks, 19 Pro black LED headlights, VLEDS Triton V6 turns, Rigid SAE D series fog lamps, 19 TRD hood scoop, 2019 TRD Pro grille, Coachbuilder bumper shims, X-Pel protect under mud guards, Opti Coat Ceramic, Opti Coat Sealed. And some snakes and sparklers, because they are my favorite!
    I may have to do my tail lights, super happy with my Triton V6s.
  14. Nov 20, 2018 at 7:09 PM
    mr_clark
    mr_clark New Member
    2018 Black Tundra Limited
    Looking to replace my interior lights as the first step but I can't decide between natural, pure or cool white. The pics I find online really don't show enough of a difference to help out here.
    Any recommendations? Good pics showing the difference?
  15. Nov 20, 2018 at 7:22 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Use caution with your dome/map lights. Some guys have turned 5 min jobs into 3 hr jobs. Tricky. I haven't messed with mine yet.
  16. Nov 20, 2018 at 7:49 PM
    Omohundro
    Jody
    McMinnville TN
    VLEDS 6k interior. It’s pitch black outside. C100CDFC-24D7-4933-8044-FD1345764F66.jpg
    MotoTundra likes this.
  17. Nov 20, 2018 at 7:56 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    As I had hoped the BF sale has come through on VLEDS, ordered the complete set for the rear of my 18 CM for 25% off. I did not order the resistor for the turns in the rear. I have read here that in a single circuit per side that the front 6 ohm front would cover, from the Tritons that are installed for the front signals. Will post before and after picts. Of course will do the cargo lights and third brake later. Like the look of LED's.
    Cost with free shipping was 165.00, sure beats the cost of new "Spyders".
  18. Nov 20, 2018 at 7:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I have front and rear leds and the 6ohm per side wasn’t enough. I had to go to 3ohm per side.
  19. Nov 20, 2018 at 8:00 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    would a second 6 ohm in the rear be enough per side or overkill?
  20. Nov 20, 2018 at 8:00 PM
    Spitfire
    Spitfire New Member
    Long Island
    2018 Cement Limited Trd off road
    Want to get plug and play brake leds? Anyone have the vleds? I have the reverse ones.. like them
  21. Nov 20, 2018 at 8:02 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Have the p&p on the front signals, really sweet set up.
  22. Nov 20, 2018 at 8:07 PM
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    misread the post from @Spitfire the brakes use 3157 and shouldn't need resistors just the turns.
    Spitfire likes this.
  23. Nov 20, 2018 at 8:17 PM
    GreatAvalon
    GreatAvalon New Member
    2016 Tundra Limited DC
    Good stuff here!
    Don't forget about their new LPR...so cool and really bright. Pairs well with their 7440HO reverse lights.
  24. Nov 24, 2018 at 8:13 PM
    mr_clark
    mr_clark New Member
    Ordered my interior replacement bulbs and license plate bulbs. Looking forward to the upgrade.
  25. Nov 25, 2018 at 7:07 PM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    how hard is the install on this?
  26. Nov 25, 2018 at 8:07 PM
    GreatAvalon
    Easy. Comes with a tap, tap the reverse light wires, plug LPR into plug on the wire that you tapped, good to go. Hardest part would be to get the tap the right way (positive wire where it needs to be on the duotap). But if it doesn't light, just take it up and tap again in an area very near the other spot and should be good to go. If you're familiar with wiring/Tundras, it will take you 20 mins. If you're not and need to learn where to run the wires and how to get the tail lights off, etc, it might be 45 mins install.
  27. Nov 25, 2018 at 8:13 PM
    wmchaseb
    wmchaseb New Member
    Chase
    Louisiana
    2018 Plat MGM
    Thanks appreciate the response! I think I’m going to get one.
  28. Dec 1, 2018 at 10:22 AM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    Had to replace a burned out HR build. Ordered the new headlights on sale. Question is should the led’s be vertical or horizontal? These new ones have a clocking system so you can adjust them. Now I’m 2nd guessing myself. Anyway got the truck torn down and replacing another HR switchback that worked but when I took it out of the housing it is in 2 pieces.
Thread Status:
