  1. Nov 30, 2018 at 1:46 PM
    #2191
    Sunnier
    Sunny
    San Diego, CA
    Thanks! I got over my incredible laziness, printed the instructions for Skid Row plates (only one with a pic of it installed is the trans skid), crawled under, and figured it out.
    Rheywood456 likes this.
  2. Nov 30, 2018 at 1:49 PM
    #2192
    Casper421
    In the woods
    06 DC
    It’s an unbelievable deal they are having right now. Shipping alone was $290, which is now free.
  3. Nov 30, 2018 at 2:07 PM
    #2193
    Sunnier
    Sunny
    San Diego, CA
    So... I figured it's my turn to crawl around under a truck to help someone, but I don't have a definitive answer.
    My 2002 came with cheap-ass 285 75 R16 mud tires. When I measure them on the truck, they're about 32". So I crawled under to check clearance but (I'm not surprised), the mounted spare is a BFG 265 70 R16, which I measured mounted up under the truck as 29" across. Here's a pic of the place this spare is closest to something:
    I thought, 'well, maybe if your 33's aren't really 33".'
    So I looked all around for other possible interference, and noticed that the metal frame or whatever that forms the circular area for the spare to fit, starts to curve at enough angle, that you'd potentially be able to carry the tire below the curve, but I don't think it will fit all the at in:
    And I looked at how much threaded bolt is left where the spare bolts, and I don't see enough that you could drop a 33+ " spare down enough to fit.
    It's close enough, and our trucks are uncluttered enough, it seems it kinda depends on degree of optimism (Edit: or whether I'd already bought the tires :boink:).
    If you want them badly enough, I think you could do it (probably by replacing that center attachment that holds the spare up understand the truck). But, even if you make it work, it'd mess with departure angle; you'd more likely smack down on the spare, coming off of rocks. But, if you're not planning to go off-roading....
  4. Nov 30, 2018 at 2:20 PM
    #2194
    Sunnier
    Sunny
    San Diego, CA
    Yeah, learning about this awesome deal was almost bad news, because I have so much committed already that I plan to finance, I really cannot buy the whole set.
    I bought the trans skid to prevent my truck getting caught high centered in Teeter-totter fashion, which looks more likely on the first GEN, then the third.
    The truck already has a steel front skid that is fairly wide and seems pretty durable, and the space to catch something behind it is not big, and the tires should always hold that portion of the truck up over any obstacle.... :fingerscrossed:
    I'll hope to have another opportunity next year to pick up the remaining deal at some other crazy reduced price....
  5. Nov 30, 2018 at 2:57 PM
    #2195
    because_wumbo-truck
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    You've raised some very good points. And thank you for your time and effort!
    Darkness and Sunnier[QUOTED] like this.
  6. Nov 30, 2018 at 3:03 PM
    #2196
    Professional Hand Model
    Fred
    Hand Protectors
    My 285/75/r16 spare is very snug. Any bigger and those frame curves that nestle the tire come into play (negatively). I do not thing any bigger will work as the spare will ‘wobble’ in the bay. Won’t lay flat underneath.
    You might be able to retro fit by adding spacers to drop the tire to avoid the curves on frame, but the tire will then be (lower) seen. Spacers will need to be secured as well. Not doable as is, but maybe you can make it happen.
  7. Nov 30, 2018 at 3:06 PM
    #2197
    Casper421
    In the woods
    06 DC
    Take a bfh to the rear crossmember and it’ll fit.
  8. Nov 30, 2018 at 3:08 PM
    #2198
    Fred
    Hand Protectors
    AKA ‘The Persuader’?
    MDobb79 and Casper421[QUOTED] like this.
  9. Nov 30, 2018 at 3:53 PM
    #2199
    Fred
    Hand Protectors
    Worked a little on the lights today. Swapped out old LED brake (3rd light) bulbs with standard incandescents. FOB now works proper.
    Installed new courtesy lights and one dome light with LED Sylvania. So far so good. Now have confidence to do the rest of the interior and panel bulbs tomorrow.
    Before
    AFTER
    bmf4069, Jerry311SD and Darkness like this.
  10. Nov 30, 2018 at 3:55 PM
    #2200
    Fred
    Hand Protectors
    Anybody have a shortcut on how to remove that ‘step’ bulb under the steering wheel? Looks to have a metal shroud around it. Will look better tomorrow when sun is shining.
    jnevill likes this.
  11. Nov 30, 2018 at 4:25 PM
    #2201
    jnevill
    jnevill New Member
    2005 Tundra SR5 TRD 2wd
    Stereo, steps, more stereo
    Yeah, I'm looking at mine too, I think you have to start disassembling at the front bumper, hood, inner fenders, ...
  12. Nov 30, 2018 at 5:12 PM
    #2202
    Fred
    Hand Protectors
  13. Nov 30, 2018 at 5:57 PM
    #2203
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    If theres one thing I'm not afraid of it's working on my truck in the dark. Having a reassembly session with no lights, gives me a jump start on tomorrow.
  14. Nov 30, 2018 at 5:58 PM
    #2204
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    I got the H4(9003) model from Amazon https://www.amazon.com/gp/product/B077B3SNJR/ref=oh_aui_detailpage_o02_s02?ie=UTF8&psc=1
    The install was super easy, all I did was take out the old ones and put in the new ones. It wouldn't fit through like the old ones though, so I had to maneuver it in behind the rubber that attaches to the back of the headlight housing. I also removed the metal wire that was holding the halogens in because it was too small to hold the Hikari led. All it prob took me about less than 10 minutes for both sides and it's my first time installing new lights lol.
  15. Nov 30, 2018 at 6:01 PM
    #2205
    Sunnier
    Sunny
    San Diego, CA
    So was it plug and play, no twisting wires, soldering stuff? Asking for a friend. Who should probably replace headlights on a 2002. :anonymous:
  16. Nov 30, 2018 at 6:03 PM
    #2206
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    It was completely plug and play, super easy to do.
  17. Nov 30, 2018 at 6:05 PM
    #2207
    Sunnier
    Sunny
    San Diego, CA
  18. Nov 30, 2018 at 6:06 PM
    #2208
    Sunnier
    Sunny
    San Diego, CA
    Awesome! I love how inexpensive the headlights are! Not like that 3rd gen....
    I may replace the entire set.
  19. Nov 30, 2018 at 7:29 PM
    #2209
    because_wumbo-truck
    Jon
    Houston, Texas
    Twist and pull. It's a 74
  20. Dec 1, 2018 at 11:07 AM
    #2210
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    I have a 285/70/17 under my bed. Hopefully 295/70/17 or 285/75/17s fit... that’ll be my next jump
  21. Dec 1, 2018 at 11:08 AM
    #2211
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    Yeah hard deal to pass up!! Hopefully you jumped on it!
    I have the Front Engine Skid now. The oil pan and transmission skid get here Tuesday.
    Theo pictures aren’t very good on their website unfortunately.
    Sunnier[QUOTED] likes this.
  22. Dec 1, 2018 at 11:12 AM
    #2212
    Rheywood456
    Rheywood456 Sup
    Riley
    Kansas City
    First Gen Tundra
    That’s another reason I added rock lights. Working on the truck at night is a little easier. Especially out on the trails. I also have these small cube lights called Lume Cubes. They are awesome for this application.
    Darkness[QUOTED] likes this.
  23. Dec 1, 2018 at 11:15 AM
    #2213
    Sunnier
    Sunny
    San Diego, CA
    Awesome!
    I have what I decided is a workable front skid (based mainly on other financial priorities) but the SR oil skid won't work with the one I have. So I only bought a transmission skid this time around (a major score at -20% and free shipping), and will hope for another opportunity in future to buy the rest.
    Do you not have a transfer case skid?
    Rheywood456[QUOTED] likes this.
  24. Dec 1, 2018 at 11:21 AM
    #2214
    Sunnier
    Sunny
    San Diego, CA
    Thanks for posting this. I'd never heard of Lume cubes but they look handy, maybe for camping as well as night-time truck repair. It'd be good to have directional lighting; a lot of camp lanterns cast light all around which effectively kills night vision.
    I'll share what I found with a quick search. I know @ccdawnpatrol is looking for some good, inexpensive camp lighting ideas:
    https://www.google.com/search?q=lume+cubes&ie=UTF-8&oe=UTF-8&hl=en-us&client=safari
  25. Dec 1, 2018 at 11:32 AM
    #2215
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    I have a 20" led stick lamp but didn't bother charging it. I keep that in the truck usually. Truck battery is dead too, I really need to get this moving again.
    Rheywood456[QUOTED] and Sunnier like this.
  26. Dec 1, 2018 at 3:20 PM
    #2216
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Realized it's been my lower arm bushings squeaking up a storm all these years.
    Got my outside TREs out, got the lower ball joints off, got the spindles and brake calipers off. Now need to have the bearing press work done and I'll pick a fight with the lower arm bushings tonight. If I lose that fight I guess I'll have a shop do that press work too.
    Lower arms coming off next, wish me luck.
    bmf4069, Sunnier, Rheywood456 and 4 others like this.
  27. Dec 1, 2018 at 3:26 PM
    #2217
    Casper421
    In the woods
    06 DC
    You got this! :thumbsup:
    Feel free to give some tips since I’ll be doing the same in a few weeks. :fingerscrossed:
    Sunnier and Rheywood456 like this.
  28. Dec 1, 2018 at 4:11 PM
    #2218
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    @Casper421 @Darkness
    Do you guys know if they make the Spartan locker for our trucks. I know they have one for most Toyota axles but I can't seem to find one for the 8.4"... :notsure:
    Darkness and Casper421 like this.
  29. Dec 1, 2018 at 4:27 PM
    #2219
    Casper421
    In the woods
    06 DC
    I haven’t seen it for the 8.4”, just the 8”.
  30. Dec 1, 2018 at 4:31 PM
    #2220
    BestGen
    BestGen New Member
    Paul
    Crap. I wonder if the V6 model thru 09 might work..? Guess I'm getting one for the front of the 4Runner. I'd rather get one for the rear of the Tundra. :annoyed:
