Ronin Build (2016 PLTUNDRA BBP)
Discussion in '2.5 Gen Builds (2014-2021)' started by Komodo Instincts, Jul 25, 2016.
  1. Jul 25, 2016 at 8:55 PM
    Komodo Instincts
    Komodo Instincts [OP] New Member
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Dark Blue Carbon Fiber Tailgate Insert, Husky Xact Floor Mats, Lund Wind Deflectors
    image.jpg Finally starting the build page for Ronin. Spent the past 8 months researching and deciding on the parts and mods. Ordered in April. Ordered most of the parts and accessories in June. Finally received the truck at the dealership on July 19th, and got to work.image.jpg
    Ancient1, Law323, Black Wolf and 2 others like this.
  2. Jul 25, 2016 at 9:02 PM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    First to go on was the TBL U.S. Flag and Blue Carbon Fiber Tailgate Inserts.
  3. Jul 25, 2016 at 9:08 PM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    image.jpg 18x9 Black Rhino Selkirks wrapped with 285/65 Nitto Trail Grapplers, loaded for the 3-1 Lift and mounting.
    Of course I had to open one up to catch a glimpse of what she'll look like!
    rons23 and Law323 like this.
  4. Jul 25, 2016 at 9:12 PM
  5. Jul 25, 2016 at 9:19 PM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Installed Wade In-channel Wind Deflectors, Husky Xact Contour Mats, and dropped her off for the lift and wheels.
    Came out better than I had visioned all these months.
  6. Jul 25, 2016 at 9:49 PM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    I LOVE that color. I've only seen a couple in person. Looks good man! wheels, tires, lift combo on the truck too
    Komodo Instincts[OP] likes this.
  7. Jul 26, 2016 at 2:15 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Had the front windows tinted (legal - VA. Sucks but at least it'll keep some UV out) and a quick photo op.
    Harris1881 likes this.
  8. Jul 26, 2016 at 2:39 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Back to it. Installed 2 ESP Rear Underseat Storage units; One in my friend's '14 Limited. The install was pretty easy and had taken about 40 mins for his. Mine had taken a little longer because I wanted to keep the Husky liner tucked under, but still maintain removability of the rear mat, without having to remove the storage unit.
    First I lined up the template over the Husky liner and measured/marked 1/2in and 1/4in lines from where the edge of the storage unit would be. Then cut the liner using a framing square to keep it straight.
    Placed the template back into place with the liner cut out, to mark the box cutouts.
    Ready for install.
    One of the bolts would not go back in. Seemed to be factory stripped. Since I didn't have a tapping set, and didn't want to purchase one just for this, I took it back to the dealership. They checked it out and retapped the hole.
    Law323 and Black Wolf like this.
  9. Jul 26, 2016 at 2:42 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Appreciate it TNT! I wasn't sure on the color when I ordered it, but I absolutely love it.
  10. Jul 26, 2016 at 3:13 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I like how they are finally color matching the center plastic of the front bumper! Sharp looking truck! :thumbsup:
  11. Jul 26, 2016 at 3:16 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    You most likely put the wrong bolts in the wrong spots and thus fucked up the threading. IIRC, one or both of the center bolts are a different thread than the outside bolts.
  12. Jul 26, 2016 at 3:27 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Yeah 100% sure I did not; I watched the video on the install prior to and saw that the driver rear center bolt is different; it's physically wider and won't fit in any of the other holes. Plus I actually placed all the bolts in their respective spots on the floor board to prevent any issues to begin with, but I'd agree that one could fuck up the threading doing so, which is why I didn't push it and why I think it was a factory issue.
  13. Jul 26, 2016 at 3:36 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Instead of the stubby antenna, I opted for a 13in Metra Carbon Fiber. No issues with reception in the cities, but have to take a road trip to really notice any difference with reception or range.
    boardude likes this.
  14. Jul 26, 2016 at 3:48 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    While my broheim and I were installing the rear storage units, a UPS truck pulled up and delivered the bull bar! Of course it had to go straight on.
    What I didn't know about the Venum Bull Bar is that the mounting brackets were designed so you can still keep your tow hooks mounted. They turn out 90 deg, and bolt in with 1 of the OEM bolts and 1 bolt provided with the hardware. Haven't decided on a LED setup yet.
    iHacker and NMOKTundra like this.
  15. Jul 26, 2016 at 4:03 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    I don't peticularly like the almost overwhelming Brake lights on the blue, so I ordered the 3rd brake light and Rear Brake assemblies. I thought that replacing the 3rd brake light would be a simple unscrew/screw in with the Recon smoked. Come to find out I need to get into the headliner to get to the two bolts. Decided to look into it some more before doing it, and shifted to the rear assemblies which were easy plug and play - Spyder Auto LEDs Smoke.
    Wvmoonshiner and Okie like this.
  16. Jul 26, 2016 at 4:04 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Linex'd the bed.
    NewImprovedRon and mdavis like this.
  17. Jul 26, 2016 at 7:09 AM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
  18. Jul 26, 2016 at 7:51 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Looking NICE brother!! Loving the bull bar!!
  19. Jul 26, 2016 at 7:56 AM
    Okie
    Okie I'd rather be fishing!
    Patrick
    Tecumseh, Oklahoma
    2016 Black Tundra Crewmax
    Thanks! Now I got to get tail lights because The red ones never bothered me till now. Lol
    If I may ask what did they cost? I've found several different sites selling them ranging from $312-414$
    Oh and now I have a little buyers remorse! I went with black but had that blue one in the driveway twice!!
    Nice looking truck sir!
  20. Jul 26, 2016 at 8:28 AM
    frogger
    frogger just boost it
    Stephen
    Louisville Ky
    2008 S/C Tim Mica SR5 5.7L DC 4X4
    too much to list
    Looking real good...that bull bar is sick!! I love the paint matched everything too. Man I need to get rid of my chrome fast.
  21. Jul 26, 2016 at 8:48 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Thanks man.
  22. Jul 26, 2016 at 8:51 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Thanks brother! Just waiting on the matching side steps to get finalized and cut. First time Spyder Industries is making them for the CM. Should have them in a couple of weeks once they get done tweaking the right mounting distance.
  23. Jul 26, 2016 at 8:55 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Thanks Okie! I found them for 345, so if you've found them below that, good stuff.
    I've always had charcoal color vics, initially I was thinking black, but blue's my fav color and I don't have the time on my hands to do justice in keeping the black clean all the time.
  24. Jul 26, 2016 at 9:02 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Appreciate it man! 9/10 dudes would agree that it's a sick bull bar. The remaining 1 has a vagina.
    The paint matching is another reason why I went with the platinum. The grill and side emblems are satin so they don't scream out like the chrome. I like a little chrome to tie everything together, but I'm going to do something with the mirror covers and also plasti dip the 4x4 emblem on the tailgate.
    frogger[QUOTED] likes this.
  25. Jul 26, 2016 at 9:26 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Always a smart move getting matching steps to go with your Bulls!! You could get ICI magnum steps. Those look similar with the same sharp edges if you don't want to wait! (Getting mine sometime soon)
    I'd love that bar on my 12, but the grill aesthetics just wouldn't mesh well IMO.
  26. Jul 26, 2016 at 9:36 AM
    Or just go with the @sdhq_offroad sliders that can be used for steps too. :stirthepot:
  27. Jul 26, 2016 at 10:28 AM
    BlueFalconActual
    BlueFalconActual Field Day Inspector Extraordinaire
    Kevin
    29 Palms, CA
    Tundra-less
    BBP is an awesome color. Adding black/color matched stuff really makes it pop.
  28. Jul 26, 2016 at 12:34 PM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    You would know, brother!
  29. Jul 27, 2016 at 8:01 AM
    Komodo Instincts
    Chesapeake, VA
    2016 BBP PLTUNDRA
    Ronin wouldn't be complete w/o the Katana! (Well, the Katana and Side Steps.)
    frogger and Law323 like this.
  30. Jul 27, 2016 at 9:13 AM
    frogger
    Stephen
    Louisville Ky
    too much to list
    That's awesome
