2008 Frame recall- doing spray
Discussion in '2nd Gen Tundras (2007-2013)' started by Bnthere1213, Oct 23, 2018.
  1. Oct 23, 2018 at 3:39 PM
    Bnthere1213
    Bnthere1213 [OP] New Member
    2008 Tundra
    Toyota approved my frame as part of recall to be sprayed. Dealer called and said they would need truck for 2 weeks, and they will sandblast frame inside and out and put the coating on.
    Has anyone had this done? 2 weeks seems like long time. Are they taking everything off frame to do this? I asked person who set up appointment and they did not know.
    Thank you
  2. Oct 23, 2018 at 5:08 PM
    Dabutcher
    Dabutcher New Member
    D
    Twin Cities
    2022 Tundra 1794 Supersonic Red
    Nitto Ridgegrapplers 175/60/20
    My truck is from Nashville so it was not listed in recall. I saw the underside of one Tundra that it was done to and it looked like a big fn gookie black mess. I do not know if it was sandblasted or not first. Looked like sheeeeeeet underneath in MHO. Good luck. D
  3. Oct 23, 2018 at 6:22 PM
    Woodguy65
    Woodguy65 New Member
    If you are getting a new frame - no its not a long time, if they are just spraying - seems like a long time.
    My wife got a new frame for her Sequoia under recall and they had it for just over a week, and yes they took everything off.
    I had a Tacoma (recall) that did not need a new frame but they sprayed it with the black goo you refer to, more like tar that never seemed to dry. Anyway, that was just one day to get sprayed, they did not take everything off.
  4. Oct 23, 2018 at 6:33 PM
    Vizsla
    Vizsla pretend2send
    If they are sandblasting it, it would be pulled apart just like a replacement frame. The sandblasting itself would be outsourced likely, so I do not doubt the timeline. Definitely longer than a frame replacement.
  5. Oct 23, 2018 at 7:43 PM
    Bnthere1213
    2008 Tundra
    That's what I was thinking. Hopefully I can talk to someone at dealership who knows process. If they are taking everything off, it may be good time to replace some parts. Got 185,000 miles on her with no major issues.
  6. Oct 24, 2018 at 2:30 PM
    Dr_Al
    Dr_Al New Member
    Al
    Toyota replaced the frame on my 1st gen Tundra and it was over a week. When the cab rusted out and I was looking for a replacement all of the older 2nd gen Tundras around here had their frame covered in undercoating. Even then I could still see scale that didn't look like it was attached very well. I gave up and just bought a truck from down south that has a frame that looks like new. I doubt they are going to pull the cab and bed but maybe. Seams like at that point in time they might as well replace the frame. Either way hopefully they do sandblast it as just covering rust isn't a great solution.
  7. Nov 29, 2018 at 3:28 AM
    Rudy4536
    Rudy4536 New Member
    2007 sr5
    Dealer just told me there going to be doing a sandblast on my 2007. said -2- weeks with a loner.
    How did yours turn out? i was impressed the way my truck frame was holding up, till the last year or 2.
    Just wondering how it turned out.
    Thanks
  8. Nov 29, 2018 at 6:17 AM
    tnbndr
    tnbndr New Member
    New Berlin, WI
    2012 White Rock Warrior CrewMax
    I had the frame sprayed on my 2005 Tundra and they just sprayed over everything. A big mess and rust was back shortly. It's a joke. If they are going to sandblast why not just replace frame or better yet give you a great value towards a different truck.
