Steering rack bushing help!
Discussion in '2nd Gen Tundras (2007-2013)' started by TexasTundra27, Jul 4, 2018.
  1. Oct 3, 2018 at 8:13 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Black '14 CM SR5 w/ SC; 40s on 17s; 5.29s
    Well, you only need to disconnect the tie rod ends from the spindle for this swap so I think I should be fine as long as I don't touch the eccentrics then.
    dcsleeper408 likes this.
  2. Oct 4, 2018 at 2:47 AM
    TexasTundra27
    TexasTundra27 [OP] Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I don’t think it’s 100% needed, but I did since it was the week before a 3500 mile trip
    831Tun and dcsleeper408 like this.
  3. Nov 28, 2018 at 8:37 AM
    OBXTundra
    OBXTundra Member
    Southeast USA
    2018 Nissan Armada, 4x4
    Is there a good write-up on the bushing replacement, step by step?
    What size fork is required?
    I'm heading down this road sometime this winter. My front end has been checked out twice in the last 3 months. Once for inspection and then once when i had new wheels installed/alignment. The 2nd time i specifically asked them to inspect every front end component for wear/play. The only thing they came up with was the steering rack bushings. I've checked them, there's play.
  4. Nov 28, 2018 at 1:20 PM
    TexasTundra27
    Mark
    OBXTundra and 831Tun like this.
  5. Nov 28, 2018 at 3:17 PM
    OBXTundra
    OBXTundra Member
    Southeast USA
    @TexasTundra27 thanks for the reply. I'm looking for a pretty good write-up or a video. I'm very mechanically inclined. I just always like to know what to expect and have the exact tools/supplies I need on hand.
  6. Sep 3, 2019 at 10:59 AM
    jaymar88
    jaymar88 New Member
    @TexasTundra27 just wanted to follow up. Did this resolve the front end clunk? I already spoke with @Spvrtan and based on his recc. I ordered the pickle fork set. once you get the bottom bushings out, did you just knock the uppers out from the inside?
    Thanks!
  7. Sep 3, 2019 at 11:06 AM
    TexasTundra27
    Mark
    Yes it did, I used the pickle fork for the lower bushing and a socket and extension to get the top one out
    jaymar88 likes this.
