Differential Fluid
Discussion in '2nd Gen Tundras (2007-2013)' started by Apollothetundra, Nov 25, 2018.
  1. Nov 25, 2018 at 10:58 AM
    Apollothetundra
    Apollothetundra [OP] New Member
    Trevor
    07 Super White 5.7l V8 337,000
  2. Nov 25, 2018 at 12:36 PM
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I use the royal purple differential fluid.It has the limited slip additive already in it.It comes in the correct weight. I just changed mine in my 2013 tundra last month.
    Apollothetundra[OP] likes this.
  3. Nov 25, 2018 at 12:40 PM
    Apollothetundra
    Trevor
    On the rear or did you change both ?
  4. Nov 25, 2018 at 12:43 PM
    tenntundra
    Walter
    Tennessee
    I have just changed the rear so far.A little over 3.5 qts.my truck just has 79,000 miles. I will change the front in the spring after the snow season
  5. Nov 25, 2018 at 12:46 PM
    A side note.....We do not have a true LSD. We have an open diff.
    Rica25, ColoradoTJ and landphil like this.
  6. Nov 25, 2018 at 1:25 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    ^^ What Matt said, unless 1st gen.
    I run synthetic 75w90 in mine.
    Rica25, Black Wolf and OR18TRD like this.
  7. Nov 25, 2018 at 1:55 PM
    SteyrM40A1
    SteyrM40A1 New Member
    Gregg
    2018 Toyota Tundra Crew Max SR5 TRD Sport, Magnetic Grey
    Air flow accelerator mod, charcoal filter delete. LED interior lights.
    So would adding a limited slip additive hurt anything?
  8. Nov 25, 2018 at 2:00 PM
    Professional Hand Model
    Fred
    Hand Protectors
    1st Gen’r here. 02’ spec’d at straight 90w LSD in the rear. I put in Mobil1 75w-90 synthetic as the straight 90w cannot be found anywhere even the stealership. Had some grumbling going on after the Mobil 75w-90 install, so went to the heavier weight Lucas Dino 80w-90 LSD. No problems.
    Probably best to follow as close to the manual in your case 75w-85.
    BTW the Mobil 75w-90 works great in the front diff and transfer, as its spec’d for those areas of the 02’. For some reason, the back diff no likey.
  9. Nov 25, 2018 at 2:03 PM
    Fred
    Hand Protectors
    I’ve heard too much is not good. Study your manual and trust it. You don’t need LSD if its not spec’d. Stay 75w-85 if you can get it.
    SteyrM40A1[QUOTED] likes this.
  10. Nov 25, 2018 at 2:37 PM
    tenntundra
    Walter
    Tennessee
    Lsd additive won't hurt anything.It just gives better lubrication to the clutches.It will also help on bearing life.
    SteyrM40A1 likes this.
  11. Nov 25, 2018 at 2:44 PM
    Did you put a limited slip in your truck?
    Rica25, landphil and BTBAKER like this.
  12. Nov 25, 2018 at 2:50 PM
    tenntundra
    Walter
    Tennessee
    I used the royal purple differential fluid. It's already in it and it is full synthetic. I use it in my 2000 tundra and the royal purple trans fluid and it has 370,000 miles.
    SteyrM40A1 and ColoradoTJ like this.
