2011 Tundra 5.7 Crewmax name that sensor!
Discussion in '2nd Gen Tundras (2007-2013)' started by Skezix, Nov 23, 2018.
  1. Nov 23, 2018 at 3:42 PM
    Skezix
    Skezix [OP] New Member
    2011 Tundra Crewmax
    Hi everyone, long time Toyota owner new Tundra owner. Recently got a really sweet deal on a 2011 Tundra. During my purchase I requested the valve cover gaskets be replaced so I could rule out the cam tower leak issues that have been found. It was a bit grimy and I was concerned so the gaskets replaced was part of the deal. In the end it was valve covers and the towers are fine. Long winded.. Lets get to the point, I decided to change out my spark plugs as they wanted way to much to do it while doing the valve covers gaskets, 265$ while they were in there?? .. never mind.. Upon changing my right side I noticed a nice piece of white tape holding some wires in place on a sensor. Nice bright white tape so it was a recent "fix" due to valve cover gasket replacement... As I was unplugging some sensors to make space the wires popped right out of this particular one. Cam sensor? Not sure and I cannot seem to find it. In the end I need to find out what order the wires go back into the clip but in order to find that out I need to know what sensor i am looking at or possibly someone here may be able to tell me the color order.
    Anyhow thank you very much for reading my novel and thank you in advance for any input here.
  2. Nov 23, 2018 at 3:45 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Looks like cam sensor
    Casper421 likes this.
  3. Nov 23, 2018 at 4:37 PM
    fliberto38
    fliberto38 New Member
    Frank
    Ft. Worth, Texas
    2019 Silver Tundra TSS Off-Road
    Toytec/Radflo coil overs, SPC UCAs, Diff drop, Toytec/Deaver AAL, Toytec Boss rear shocks
  4. Nov 23, 2018 at 4:38 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    Definatly a cam postition sensor
  5. Nov 23, 2018 at 4:42 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    since the wires are pulled out of the pins, you will probably need the repair wires. 82998-24250 x3. the will have the pins already crimped on. They list for $7.93 each at your local Toyota dealer.
  6. Nov 23, 2018 at 4:51 PM
    Mwray8909
    Mwray8909 New Member
    Chino Valley
    18 TRD offroad cement CM
    I just did this repair.... due to squirrels
  7. Nov 23, 2018 at 4:53 PM
    Skezix
    2011 Tundra Crewmax
    Perfect, thank you very much for the help. Red/Black/yellow although it appears I will have to get a new plug as there does not seem to be a way to open this one or pull the pins so I can re-crimp. Ahh Thank you Fliberto, I missed your message above the diagram.
    Ouch squirrels.. Did ya end up getting a new plug?
  8. Nov 23, 2018 at 4:54 PM
    Mwray8909
    Chino Valley
    I did off Amazon I believe I will check
    EDIT: It was amazon
  9. Nov 23, 2018 at 4:57 PM
    fliberto38
    Frank
    Ft. Worth, Texas
    The only way to get the pins out at this point is with a pin tool and a small pick to push them out. The connector part number is on the first pick. 90980-12353. It's $7.99
  10. Nov 23, 2018 at 5:06 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Id say repin the original wiring over butt connecting. Looks like you have enough factory wiring there to make it happen.
  11. Nov 23, 2018 at 5:10 PM
    Mwray8909
    Chino Valley
    I can say with heat shrink and solder mine is holding up perfectly. Just like factory infact.
  12. Nov 23, 2018 at 6:02 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Solder and butt connect is different. Solder should do well, I'm not necessarily a fan of butt connects which is what I mentioned (but I'm an ass man otherwise ;))
    fliberto38 likes this.
  13. Nov 24, 2018 at 3:41 PM
    Skezix
    2011 Tundra Crewmax
    Thanks everyone, I went with the Doorman kit.. locally 45$!! yet its done correctly and now I do not have to worry about it. I am not a fan of crimp connectors no matter the project, always solder/shrink.
    Thank you once again
